Page 1 of 2 12>
#5768229 - 08/27/11 06:30 PM I <3 VWs
Ok, 1985 GTI is giving me a cyclical rubbing sound from the right front end on left hand turns. My first thought was outer CV joint, but it's not clicking and doesn't happen at low speeds (meaning no weight transfer). So next I figured it was the bearing and there's a fair bit of shake at the steering wheel, so if so, I'm one trip from the grocery store from dead - but I jacked it up and there's no unusual play. I did notice that the front right tire (Toyo T1-R) had high spots (flatspotted on a track day years ago), so I rotated it to the right rear. Just did a short test drive (in case I'm still going to flip over and die like a Lotus 7 taking a corner, I want my body to be found close to home) and it felt better, but I still heard the wub-wub-wubbing sound.
I don't think it's the plastic wheelhouse liner, but I can't rule it out. And it's possible that it's now coming from the right rear and I'm just fooling myself that it's still up front (in which case, the next move would be to swap the rear tires and see what happens then, but I'll probably flip over and die anyway because the tires will be on backwards).
Could the bearing be bad, but just barely so that it doesn't show obvious play but cries under cornering load?
Could it be something else entirely? The car is as much of a pos as you'd assume an '85 GTI to be, but all the rubber in the suspension is less than 2 years old, so it's not likely to be suspension pieces wandering around.
Should I just ignore it and let the accident forensics team figure out how I died?
Oh, and gratuitous GTI pic to piss off SiRkid (there's a skateboard in the way back, so it still counts):
Beater GTI by scottspaeth, on Flickr
#5768364 - 08/27/11 07:23 PM Re: need help... wubba wubba wubba [Re: scootergeek]
southjerseyTSI Offline
I dont know anything about vw's but had something very similar on my gf's trailblazer, it turned out one of the caliper bolts backed out or was never tight from the last person who did the brakes.
#5768408 - 08/27/11 07:43 PM Re: need help... wubba wubba wubba [Re: southjerseyTSI]
Hmmm, it's been a while since the brakes were done, but maybe the out-of-round tire vibrated something loose. I'll check that next. Thanks.
#5769080 - 08/28/11 08:32 AM Re: need help... wubba wubba wubba [Re: scootergeek]
Could still be a wheel bearing even if it doesn't have play when you check it on stands.
#5769147 - 08/28/11 10:24 AM Re: need help... wubba wubba wubba [Re: LNXGUY]
Quad4_driver Offline
Loc: B.C. Canada
Another for bearing.
#5769150 - 08/28/11 10:28 AM Re: need help... wubba wubba wubba [Re: scootergeek]
cacasesi Offline
Say my name!
I did notice that the front right tire had high spots, so I rotated it to the right rear. Just did a short test drive and it felt better, but I still heard the wub-wub-wubbing sound.
Did the sound follow the tire/wheel? If you have a spare, I'd throw that on in lieu of the suspect tire/wheel, just to eliminate a variable.
#5770113 - 08/28/11 10:15 PM Re: need help... wubba wubba wubba [Re: cacasesi]
Warped rotor?
#5770129 - 08/28/11 10:23 PM Re: need help... wubba wubba wubba [Re: LNXGUY]
Check your grounds.
2020 Taycan Turbo
2014 SLK55 AMG
#5772341 - 08/29/11 08:59 PM Re: need help... wubba wubba wubba [Re: Impulsive]
Looks seriously like the wheel bearing. Driving home from work tonight the vibrations at 60mph+ scared me enough that I drove to the garage (about 9 miles closer to work than my apartment) and had my son pick me up.
Still no visible play, but it does feel as if the right side wheel is dragging ever so slightly.
I'll take it all apart tomorrow evening and figure out where I stand.
#5772881 - 08/30/11 07:48 AM Re: need help... wubba wubba wubba [Re: scootergeek]
I assume you'll do both?
#5772926 - 08/30/11 08:29 AM Re: need help... wubba wubba wubba [Re: LNXGUY]
I should, but I won't. I'll just clean and re-pack the driver's side. That's how tight my financial situation is.
#5781821 - 09/03/11 03:22 PM Re: need help... wubba wubba wubba [Re: scootergeek]
g96nt Offline
Loc: Annapolis MD
with the non-feathered tire swapped out, it's going to be a while before you hear the sound again. My old car used to be silent on new tires, but howl like a bad wheel bearing once the alignment feathered the rear tires. Check the toe, and work from there. if the toe's out, it eventually *will* kill a bearing.
2000 Saab 9-5 wagon
#5781823 - 09/03/11 03:25 PM Re: need help... wubba wubba wubba [Re: g96nt]
g96nt Offline
Loc: Annapolis MD
also.. new bearings aren't *that* expensive
http://www.fcpeuro.com/products/volkswagen-wheel-bearing-jetta-golf-051-3930
2000 Saab 9-5 wagon
#5832345 - 09/29/11 10:51 PM Re: need help... wubba wubba wubba [Re: g96nt]
So after repeatedly throwing the car on the lift with no evidence of a worsening bearing (I've been driving it less lately, but harder trying to get the problem to become more identifiable), I'm starting to think the bearings aren't the problem.
I am almost certain that the right front caliper is not cleaning sliding anymore - a little tug to the right on acceleration and a matching slight tug to the left under braking. The lines are braided, so it's likely the caliper (which I think is original). I'll do that Friday or Saturday.
New tires arrive tomorrow. Going from T1-Rs that I haven't swapped out during the winters (eek) to Ecsta ASXs. But 205 section anything on a 2k lbs./110hp car is going to grip pretty well.
#5833049 - 09/30/11 10:21 AM Re: need help... wubba wubba wubba [Re: scootergeek]
Could it be a motor mount?
#5834109 - 09/30/11 06:55 PM Re: need help... wubba wubba wubba [Re: UglyValiant]
Already replaced all three.
#5834967 - 10/01/11 09:44 AM Re: need help... wubba wubba wubba [Re: scootergeek]
g96nt Offline
Loc: Annapolis MD
Have you tried replacing the motor?
2000 Saab 9-5 wagon
#5835209 - 10/01/11 01:33 PM Re: need help... wubba wubba wubba [Re: g96nt]
narf.
I think the short block is the only original mechanical bit left on the car. I keep saying it'll get a 1.8T someday, but probably it won't.
#5835352 - 10/01/11 03:50 PM Re: need help... wubba wubba wubba [Re: scootergeek]
Is the whole damn unibody flexing that bad, lol?
#5835417 - 10/01/11 05:29 PM Re: need help... wubba wubba wubba [Re: UglyValiant]
guy who did the tires says the left control arm bushing is bad (but he also killed my wheel bolt tool - it's got weird anti-theft wheel bolts - and the opinion of anybody who cranks the shit out of an air impact on wheel bolts is suspect). I don't see how that's possible as they were replaced 6 months ago, BUT one did get slightly mangled when it walked sideways in the press. I thought I fixed it, but maybe not.
Anyway, ball joints look ok, but old as dirt, so they're getting replaced and the upper strut bushing/bearings are probably original, so they've been ordered as well. Round tires have gone a long way to fixing 60% of the issues.
#5859356 - 10/13/11 07:59 PM Re: need help... wubba wubba wubba [Re: scootergeek]
ok, passenger side inner cv joint had play. Replaced the entire driveshaft since that's the only way oreillys sells them. No play in the driver side or appreciable bearing play. Re-assemble and wubba wubba wubba. 80% of the vibration is gone and in general it feels better, but not right. I'm starting to think it's the differential, which will make me very sad indeed. I know the tranny was bought used, and have no idea how many miles are on it. At this point, I'm going to finish the repairs of bits I've already bought (ball joints, upper strut mounts and some other piddly stuff) and just drive until a wheel falls off or the tranny blows up. I wonder what good condition O2A transaxles go for vs. the price of an lsd.
And to top it off, I bet the Alfa would have been done and on the road for the money I've sunk into this wrong wheel drive shitbox over the last five years. And comparing the quality of the mechanical parts, there's no way the Alfa would be less durable.
#5859427 - 10/13/11 08:32 PM Re: need help... wubba wubba wubba [Re: scootergeek]
Hytec Offline
Sounds like its time to invest in a 1st gen DOHC Neon beater.
#5860473 - 10/14/11 11:12 AM Re: need help... wubba wubba wubba [Re: ]
Love 80's GTI's, hate all other VW's.
-Rex B16, June 11 2024
#5861233 - 10/14/11 05:31 PM Re: need help... wubba wubba wubba [Re: Hytec]
#5861236 - 10/14/11 05:34 PM Re: need help... wubba wubba wubba [Re: danl]
Honestly, I love the car when it isn't broke. I hate working on it though, it's all so fucking dinky and half-assed. And a friend sent me this pic on fb:
And instead of thinking "Hey, an exploded pile of shit", I thought "Damn, I wish we got the four door Mk II GTI in the US". I think I've been thoroughly infected.
#5861429 - 10/14/11 08:06 PM Re: need help... wubba wubba wubba [Re: scootergeek]
Scott, ALH swap man, you know you wanna do it \:\)
#5861488 - 10/14/11 08:38 PM Re: need help... wubba wubba wubba [Re: LNXGUY]
cacasesi Offline
Say my name!
Your noise problem is somewhere in that picture... where's Waldo?
#5880064 - 10/23/11 07:46 PM Re: need help... wubba wubba wubba [Re: cacasesi]
fixed.
new front hub bearings
new ball joints (passenger side had play at the clamp, not the socket)
new tie rod ends (old ones were ok, but damaged in removal)
new passenger side axle complete (old inner cv joint bad - $60 for the whole thing)
new upper strut mounts (looked ok on removal but probably original - upgraded to Corrado VR6 mounts)
Finally mounted an autotech strut tower bar that I got with the car while I had the struts out.
Did the alignment with a hunk of mdf, a plumb line, a ruler and a tape measure. Probably more toe out (1/4") than is called for, but it feels good and I'll deal with it if the wear becomes excessive.
Driving it this afternoon after getting it sorted reminded me why I love the car.
#5880068 - 10/23/11 07:54 PM Re: need help... wubba wubba wubba [Re: scootergeek]
ElectronVTEC2 Offline
Way to go man!
2011 Edge (Wife's appliance)
EVO IX MR, minor mods
#5880154 - 10/23/11 08:52 PM Re: need help... wubba wubba wubba [Re: scootergeek]
theLoon Offline
Loc: MN
I had no idea there were magical levitating headliners involved. No wonder GTIs handled so well.
I'm a badge whore
#5880407 - 10/23/11 11:07 PM Re: need help... wubba wubba wubba [Re: theLoon]
All the stuff in the back is suspiciously floaty.
The Mk II looks better as a four door hatch.
#5890710 - 10/27/11 11:09 PM Re: need help... wubba wubba wubba [Re: scootergeek]
Just noticed, the exploded pic has the gas door on the wrong side. Somebody must have flipped it to make the IP look right to Brits. *EDIT* fixed that.
Fixed the toe today.
And the headlights - both the bottom adjusters were broken and I kept putting it off telling myself that I was going to convert to rounds, but I never had the disposable money, so for 5 years now I've had useless headlights pointed at the ground about 4 feet from the car. On a hunch I tried the plastic nuts that BMW used on the E34 and though not perfect, I now have reasonably aimed headlights.
Afterwards I was trying to bleed the brakes on a '63 Ford Falcon (289 with ported GT40 heads) and took a full splash back of brake cleaner to the eyes. That sucked. It was also the fourth car I worked on this week. I can't get away from this shit.
Edited by scootergeek (10/27/11 11:11 PM)
#5893047 - 10/28/11 08:29 PM Re: need help... wubba wubba wubba [Re: scootergeek]
theLoon Offline
Loc: MN
I don't envy you the brake fluid in the eye, but I'm in that place where I *wish* I was spending more time working on my cars. I like your headlight fix, one of those "well shit, shoulda done that 5 years ago" moments. Amazing how the mind works sometimes.
I'm a badge whore
#5893064 - 10/28/11 08:43 PM Re: need help... wubba wubba wubba [Re: theLoon]
NOT spotch... Offline
I wonder what lens they used to take that picture.
#5893207 - 10/28/11 10:10 PM Re: need help... wubba wubba wubba [Re: NOT spotch...]
Probably something like a 10" lens on an 8x10 large format camera
Page 1 of 2 12>
