#5768229 - 08/27/11 06:30 PM
I <3 VWs
scootergeek
Ok, 1985 GTI is giving me a cyclical rubbing sound from the right front end on left hand turns. My first thought was outer CV joint, but it's not clicking and doesn't happen at low speeds (meaning no weight transfer). So next I figured it was the bearing and there's a fair bit of shake at the steering wheel, so if so, I'm one trip from the grocery store from dead - but I jacked it up and there's no unusual play. I did notice that the front right tire (Toyo T1-R) had high spots (flatspotted on a track day years ago), so I rotated it to the right rear. Just did a short test drive (in case I'm still going to flip over and die like a Lotus 7 taking a corner, I want my body to be found close to home) and it felt better, but I still heard the wub-wub-wubbing sound.
I don't think it's the plastic wheelhouse liner, but I can't rule it out. And it's possible that it's now coming from the right rear and I'm just fooling myself that it's still up front (in which case, the next move would be to swap the rear tires and see what happens then, but I'll probably flip over and die anyway because the tires will be on backwards).
Could the bearing be bad, but just barely so that it doesn't show obvious play but cries under cornering load?
Could it be something else entirely? The car is as much of a pos as you'd assume an '85 GTI to be, but all the rubber in the suspension is less than 2 years old, so it's not likely to be suspension pieces wandering around.
Should I just ignore it and let the accident forensics team figure out how I died?
Oh, and gratuitous GTI pic to piss off SiRkid (there's a skateboard in the way back, so it still counts):
 Beater GTI by scottspaeth, on Flickr
#5768364 - 08/27/11 07:23 PM
Re: need help... wubba wubba wubba
[Re: scootergeek]
southjerseyTSI
I dont know anything about vw's but had something very similar on my gf's trailblazer, it turned out one of the caliper bolts backed out or was never tight from the last person who did the brakes.
#5769080 - 08/28/11 08:32 AM
[Re: scootergeek]
Could still be a wheel bearing even if it doesn't have play when you check it on stands.
#5770113 - 08/28/11 10:15 PM
[Re: cacasesi]
Warped rotor?
#5772881 - 08/30/11 07:48 AM
[Re: scootergeek]
I assume you'll do both?
#5781821 - 09/03/11 03:22 PM
[Re: scootergeek]
g96nt
Loc: Annapolis MD
Hmmm, it's been a while since the brakes were done, but maybe the out-of-round tire vibrated something loose. I'll check that next. Thanks.
with the non-feathered tire swapped out, it's going to be a while before you hear the sound again. My old car used to be silent on new tires, but howl like a bad wheel bearing once the alignment feathered the rear tires. Check the toe, and work from there. if the toe's out, it eventually *will* kill a bearing.
2000 Saab 9-5 wagon
#5834109 - 09/30/11 06:55 PM
[Re: UglyValiant]
scootergeek
Could it be a motor mount?
Already replaced all three.
#5834967 - 10/01/11 09:44 AM
[Re: scootergeek]
g96nt
Loc: Annapolis MD
Have you tried replacing the motor?
2000 Saab 9-5 wagon
#5835209 - 10/01/11 01:33 PM
[Re: g96nt]
scootergeek
narf.
I think the short block is the only original mechanical bit left on the car. I keep saying it'll get a 1.8T someday, but probably it won't.
#5861429 - 10/14/11 08:06 PM
[Re: scootergeek]
Scott, ALH swap man, you know you wanna do it
#5880068 - 10/23/11 07:54 PM
[Re: scootergeek]
ElectronVTEC2
Way to go man!
2011 Edge (Wife's appliance) EVO IX MR, minor mods
#5880154 - 10/23/11 08:52 PM
[Re: scootergeek]
theLoon
Loc: MN
I had no idea there were magical levitating headliners involved. No wonder GTIs handled so well.
 I'm a badge whore
#5893047 - 10/28/11 08:29 PM
[Re: scootergeek]
theLoon
Loc: MN
I don't envy you the brake fluid in the eye, but I'm in that place where I *wish* I was spending more time working on my cars. I like your headlight fix, one of those "well shit, shoulda done that 5 years ago" moments. Amazing how the mind works sometimes.
 I'm a badge whore
