#4413630 - 01/10/10 07:10 PM
3 sets of 10 vs. 2 sets of 15 - same results?
needs a Charger
authentic and adventurous
Loc: O H! I O!
Will I see any difference in results if I'm doing 3 sets of 10 vs. 2 sets of 15 using the same amount of weight?
Formerly known as "not a charger," "not a wrangler," and thanks to my sunburned penis, "Tan Dong Phuc."
#4414937 - 01/11/10 09:52 AM
Re: 3 sets of 10 vs. 2 sets of 15 - same results?
[Re: Silock]
NateD
Loc: Atlanta, GA
Do the reps as fast as you can, and then you get all the benefits.
#4416530 - 01/11/10 04:45 PM
[Re: NateD]
Silock
Loc: Jayhawk Country
Not really
#4416729 - 01/11/10 05:28 PM
[Re: Silock]
NateD
Loc: Atlanta, GA
Well shit it's sure worked for me. Although it probably depends on the particular lift you're doing, but doing workouts more intensely is better for you IMO.
#4417725 - 01/11/10 09:56 PM
[Re: NateD]
Silock
Intense and doing the reps as fast as possible are two different things.
How long have you been lifting? Just curious.
There are a lot of negative things that can happen when you rush a lift. For one thing, if you're lifting heavy, you're not going to be able to explode into it like you would a lighter lift. Also, if you're not very strict on your form, doing lighter weights faster will make you move the weights in an unnatural way.
I'm sure that's not a problem for you, but it can happen to anyone.
If you're training for strength, sure you don't want to take 10 minute breaks, but you won't give your muscle adequate recovery time by working them every 60 seconds. That works for hypertrophy, but again, those are two different goals.
Also, a good way to train your nervous system for heavier loads is to lift lighter weights more slowly, but pretend they're heavy. By making sure you engage all of your muscles, and concentrating on a slow, deliberate lift of lighter weight, you can get your nervous system to better adapt to higher loads and thus, higher intensity.
I'm not saying you're wrong, because there's certainly a time and place for explosive lifting. But I am saying it depends on your goals. It works great in things like Crossfit, but then, *most* (not all, because there are absolutely exceptions) of the time, you're not using really heavy weights like someone purely training for strength would be.
You can vary the intensity of your workouts and still give adequate recovery time when training for strength. A good way to do this is to work opposite muscle groups. Do Bench, and then Rows. Incline, and then Pull-ups. Dips and then cable rows. That sort of thing. You can get in a quality, heavy weight, low rep, low tempo set, then move on to another quality, heavy weight, low rep, low tempo set on an opposing muscle group. By the time you get back to the first one, your muscle have had adequate recovery time for strength training, and you've kept up the intensity.
#4420581 - 01/12/10 05:17 PM
[Re: Silock]
NateD
Loc: Atlanta, GA
Lol, I'm not so sure I like your question about how long I've been lifting. The answer is 11 years, started in high school at 16, now 27.
I agree with you on form being important. And I agree with most of your conventional wisdom but I think explosive lifts and intensity with workouts have a lot more benefit than most people realize (especially the olympic lifts). Kinda like how doing sprints often bring more benefits than meets the eye.
That all said, I'm glad I gave up the whole traditional way of lifting that most of us are used to.
#4420935 - 01/12/10 06:47 PM
[Re: NateD]
Silock
I was really just curious.
IMO, intense workouts are a product of your overall effort, not how quickly you lift the weight. Like I said, though, that kind of thing has its place; it just depends on your goals.
Moderator: Silock, Professor Paki
