#7852757 - 09/08/14 09:49 AM
Re: S4 sees track time!
[Re: Screamin Type ARGH!]
4age
XD XD XD XD
I got no rubber. My tires are totally done So I won't be at ddt. sniff the new ddt looks fuuuuun
#7852774 - 09/08/14 10:02 AM
4age
XD XD XD XD
I am buying new tires -- winter tires :p No need for summers till next year bra!
#7852850 - 09/08/14 10:27 AM
[Re: 4age]
Does that mean you are getting new wheels for next season? XD OOooOOOOoooOo
#7852857 - 09/08/14 10:29 AM
bauce!
#7853077 - 09/08/14 12:39 PM
[Re: 4age]
gotta time my R, think im quicker in it vs the s2k i had before lol. our race car i think first was at 2:02's shanny full, then modded a bit more to get 2.00 range. i also recall a 1:58 (not me driving), forget which car/driver.
the s4 must haaauulll on the back straight. WOW! What car was doing 1:58? Another ITR? i know of one that did 1:58. k swap, crazy gearset and final drive...cage and mega stripped out. The S4 is actually a turtle down the back straight. Bc if it's awful understeer, it pushes slowly through the turn leading onto the straight. per my lap timer, my exit speed on that corner is a pathetic 38. Top speed on the straight is 179--and I brake around the 75ft mark. pretty slow. Boss hit like 195-200 (i could shift to 5th gear!)
Euphoric told me you brake a little past the 50 mark...I tried it yesterday and almost flipped the car entering the turn. dat late brake, dat locked up rear end, dat russian dash cam, dat drift. XD
#7853142 - 09/08/14 01:09 PM
[Re: 4age]
ROFL! I did brake a little past the 50 mark in the E36. Is your rear end locking up bc they're drag radials? I never had rear end lock up issues (my E36 also had no ABS fwiw). Car is broken. Give it to me
Pretty sure it's because of the disconnected ABS, seems like it's a common issue from what I've read, hence why people keep their ABS plugged. All the weight up front, hard on the brakes, no weight in the back, rear will lock before the front...ABS prevents that.
You probably didn't brake hard enough XD
#7853239 - 09/08/14 01:43 PM
[Re: 4age]
You probably didn't brake improperly XD
fixed XD It's how you get on and off the pedal that counts. Like I said, I also disconnected ABS in my E36 bc my rear speed sensor was broken. I fortunately never locked a tire. Shrug. Maybe something else is funky in your car? Maybe your drag radials are 10 years old and shouldn't be used? XD I ran square tires too--235 front and rear.
Entire brake system has been overhauled on the car from lines to pads, to calipers to rotors, sensors, etc. It's the ABS bruh, maybe you didn't have enough watts in your legs to lock up the wheels
I've seen another fool like me lock up like that at the track before, didn't really click in until Euphoric brought it up
#7853350 - 09/08/14 02:23 PM
4age
XD XD XD XD
he's butthurt, now he's calling out my lack of watts on the bike XD
My M3 had the exact same amount of overhauled components It's how you get on and off the pedal. Not how hard you press it that matters bruh! Oh and seriously, maybe ur rear tires are too facking old compared with the fronts? or maybe i am 90 lbs and you are 900lbs, thus your front weight distribution is much greater...thus locking up rears hahaha.
#7853394 - 09/08/14 02:42 PM
[Re: Risky Business]
titty sprinkles
You can battle risky. same cars. lame i'd donate 5 bucks to make that happen. Battle happened, I ran off the track and lost a center cap as Euphoric was breathing up my ass This track is perfect for the M3, made me fall in love with the car all over again. It has been a while that i've driven something this fun Back to indefinite storage it goes I only timed one lap, was a few seconds behind 4 age's time. Not sure what my fastest lap was doe. Euphoric was faster than me, his car is setup pretty badass overall + mad skillz
those turds look good.
#7853492 - 09/08/14 03:18 PM
[Re: 4age]
he's butthurt, now he's calling out my lack of watts on the bike XD My M3 had the exact same amount of overhauled components It's how you get on and off the pedal. Not how hard you press it that matters bruh! Oh and seriously, maybe ur rear tires are too facking old compared with the fronts? or maybe i am 90 lbs and you are 900lbs, thus your front weight distribution is much greater...thus locking up rears hahaha.
#7854604 - 09/09/14 04:53 AM
4age
XD XD XD XD
Hahahaha risky is the best. That was amazing XD those lock ups were magnificent!!! And he drove the course in a very special way XD XD XD
Nice lap Btw. 2:05 is mad fast. I still see some time left on the table too. If it's the low 2:05s then I think u have a 2:04 in you!
#7854641 - 09/09/14 06:52 AM
[Re: 4age]
the sound effects
That 2nd last turn before the front straight, I don't think there was a single time I took that in any respectable way. Kept misjudging it/going in too hot, again didn't help that euphoric was stressing me out lulz
