#7568326 - 02/21/14 10:30 PM
Re: Anyone here Nest? vCommonWire
Who the hell can buy within their means these days? Even a few yrs ago?
Everyone else in this province not living in the GTA
#7568426 - 02/21/14 11:23 PM
Barrie still falls under retarded pricing. :p
You can't afford to live in Barrie? Shit man, it's not that expensive.
#7568622 - 02/22/14 09:42 AM
civic13
Loc: You Know
Was thinking of getting a Honeywell Tstat and my current wire config doesn't have a c-wire. But Honeywell says the g-wire can be used as a sub. Is this the same issue as Nest's? http://youtu.be/jniws7wqeY4
#7568655 - 02/22/14 10:16 AM
Euphoricuck
Barrie still falls under retarded pricing. :p You can't afford to live in Barrie? Shit man, it's not that expensive. prices have seen similar retarded increases
#7568668 - 02/22/14 10:23 AM
loudsubz
I understand prices have rocketed, but there are many affordable places still available, maybe not in the most desirable locations but not in tim buck too
#7568688 - 02/22/14 10:36 AM
#7576976 - 02/26/14 07:00 PM
[Re: civic13]
robbbby
master electrician
Loc: Canada
do you want to lose control of your ability to run the fan manually?
all they are doing is swapping wires because they need a common wire for proper current consumption that the wifi draws from the board. since it only had 4 wires they can't lose control of the fan so that jumper tricks the fan to come on when heating/cooling is called for.
I would rather just run a new wire for common to the board and still have control. if your basement isn't finished it would be a good idea. Thanks. I really have no need to run the fan manually. My basement is finished but where the furnace is it's not so I'm not sure how easy/hard it would be to run the extra wire. Do you do this kinda thing for work?
It's a super easy fix, swap G to C on both the furnace board and thermostat.
please paypal me my standard fee of $95/hour.
#7577128 - 02/26/14 07:55 PM
[Re: civic13]
loudsubz
how far is your tstat from the furnace?
Edited by loudsubz (02/26/14 07:55 PM)
#7577136 - 02/26/14 07:59 PM
[Re: loudsubz]
civic13
Loc: You Know
I would rather just run a new wire for common to the board and still have control. if your basement isn't finished it would be a good idea. Thanks. I really have no need to run the fan manually. My basement is finished but where the furnace is it's not so I'm not sure how easy/hard it would be to run the extra wire. Do you do this kinda thing for work? how far is your tstat from the furnace? It's almost right above it.
#7577143 - 02/26/14 08:01 PM
[Re: robbbby]
civic13
Loc: You Know
I would rather just run a new wire for common to the board and still have control. if your basement isn't finished it would be a good idea. Thanks. I really have no need to run the fan manually. My basement is finished but where the furnace is it's not so I'm not sure how easy/hard it would be to run the extra wire. Do you do this kinda thing for work? It's a super easy fix, swap G to C on both the furnace board and thermostat. please paypal me my standard fee of $95/hour. That's what I mentioned before in my post above with the link to a YouTube vid. Is the only issue not being able to manually control the fan? Anything else?
#7577172 - 02/26/14 08:13 PM
[Re: civic13]
loudsubz
if you can see the existing tstat wire going through the floor up the wall from the furnace room you can just re pull a new one, super easy. Should cost like $10 in wire max
#7577250 - 02/26/14 08:41 PM
[Re: civic13]
robbbby
master electrician
Loc: Canada
just no manual fan control like loudsubz mentioned.
#9256696 - 02/17/18 09:29 AM
[Re: furball]
RobJohn
There are other options than installing the wire. In fact, if your thermostat does not have a common wire (C-Wire) you have the following alternatives:
- The Venstar Add-a-Wire Adapter - Stealing Power - The Fan Wire Hack - External Transformer Method
And of course, you can run a new wire or hire an HVAC professional. You can read more about the before mentioned methods here: https://roboauthority.com/guides/thermostat-c-wire/
#9257718 - 02/19/18 01:15 PM
[Re: Hatorade]
I banned him
