Page 4 of 9 « First<23456>Last »
#6763053 - 12/10/12 10:35 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
PsychoEBPSiR Offline
Loc: Vancity,Canada
Good kill, those are nice cars IMO
#6790297 - 12/24/12 04:42 PM Re: So, I'm finally building an engine... [Re: PsychoEBPSiR]
#6807985 - 01/03/13 05:17 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
#6808086 - 01/03/13 06:10 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
OnyxEros Offline
Glad you got it back and it's running well
maybe run it like it is for a season (with hydraboost)and see if you can pick up the performance parts you need on the used market at the end of the racing season for cheap
#6808179 - 01/03/13 07:03 PM Re: So, I'm finally building an engine... [Re: OnyxEros]
Glad to hear you're making progress!
#6808629 - 01/03/13 11:09 PM Re: So, I'm finally building an engine... [Re: ScottStaypuff]
with the necessary changes (proper intake, ignition, timing), sounds like 350whp would be a cinch.
#6809483 - 01/04/13 10:47 AM Re: So, I'm finally building an engine... [Re: UglyValiant]
I'm not sure why tuning this seems to be such an issue. I would have figured Mustang tuning would be very simple.
#6809607 - 01/04/13 11:25 AM Re: So, I'm finally building an engine... [Re: Impulsive]
#6809668 - 01/04/13 11:42 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
When are you going to change your sig to reflect a new acceleration ratings? This I've been waiting for...
#6809703 - 01/04/13 11:53 AM Re: So, I'm finally building an engine... [Re: UglyValiant]
#6840072 - 01/17/13 06:08 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
#6842354 - 01/18/13 02:26 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
stickaz_old Offline
Loc: Nor Cal, Hella hurr durr
huh thats about ~9 hp more than my 302 made with TFS heads an intake and a cam through a Tr-3550
maybe a different dyno callib tho, seems about right tho based on track performance (11.9s @ 114-ish for 3050# raceweight)
and a little less TQ
super old dyno if anybody cares. For a streetable AFR-185 headed 331, I'd hope for 400 rwhp personally. perhaps it's in the tune/installation/a mechanical issue
Swim->Bike->Cry
#6842596 - 01/18/13 04:32 PM Re: So, I'm finally building an engine... [Re: stickaz_old]
#6842659 - 01/18/13 05:16 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
stickaz_old Offline
Swim->Bike->Cry
#6842700 - 01/18/13 05:40 PM Re: So, I'm finally building an engine... [Re: stickaz_old]
#6842718 - 01/18/13 05:57 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
stickaz_old Offline
rice maths:
cats = -5
no underdrive pulley = -8
timing = -10 (??)
Swim->Bike->Cry
#6842787 - 01/18/13 06:43 PM Re: So, I'm finally building an engine... [Re: stickaz_old]
#6848914 - 01/22/13 09:08 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
Why did you choose to skip the long tubes? Aren't they good for another ~25whp or so? Would going long tubes -> x pipe -> hi flow cats be a big issue? (I'm assuming it won't be cheap though)
#6849158 - 01/22/13 10:56 AM Re: So, I'm finally building an engine... [Re: FCobra94]
#6849273 - 01/22/13 11:42 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
I've heard the same - similar HP, much better torque on the long tubes.
The Performer RPM usually seemed to do the best in a lot of mag tests, but on a 331 - perhaps a bit bigger is better. I'm not sure what's out there anymore though.
#6849367 - 01/22/13 12:21 PM Re: So, I'm finally building an engine... [Re: Impulsive]
#6849785 - 01/22/13 02:30 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
#6849885 - 01/22/13 03:41 PM Re: So, I'm finally building an engine... [Re: Impulsive]
I think you forgot the link.
#6850458 - 01/22/13 08:25 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
Lol.
http://www.mustang50magazine.com/techarticles/m5lp_0601_mustang_intake_manifold_test/viewall.html
#6851532 - 01/23/13 11:29 AM Re: So, I'm finally building an engine... [Re: Impulsive]
#6855153 - 01/24/13 08:12 PM Re: So, I'm finally building an engine... [Re: ]
stickaz_old Offline
Swim->Bike->Cry
#6899398 - 02/14/13 10:59 PM Re: So, I'm finally building an engine... [Re: stickaz_old]
Bit of an update.
#6899636 - 02/15/13 07:42 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
My guess is either a pushrod bent or one or more of the rocker bolts backed out and is now out of adjustment (more likely)....even w/ locking nuts, it's not terribly uncommon for one or two to back out once or twice after initial assembly and running for a 100+ miles or so...
#6900328 - 02/15/13 11:25 AM Re: So, I'm finally building an engine... [Re: UglyValiant]
#6900892 - 02/15/13 02:37 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
What a pain. I've had issues with shops before and it turned into a nightmare. Hopefully this is not an issue in your case and everything gets buttoned tuned up soon.
#6918875 - 02/25/13 02:05 PM Re: So, I'm finally building an engine... [Re: Impulsive]
Update 02/25/2013
Rear seat removal: -40 lbs
Spare tire and jack: -32 lbs
Torino II to Evo swap: -30 lbs
Aluminum side mount brakets: +5 lbs
Cobra R to RPF1 wheel change: -16 lbs
Reinstall strut tower brace and K-member brace: +15 lbs
Rear floor mats: -2 lbs
#6920394 - 02/26/13 11:45 AM Re: So, I'm finally building an engine... [Re: ReplicaR]
#6920488 - 02/26/13 12:26 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
nice....
I take it since it's still at the engine building shop it's still missing/backfiring? Another good possibility is another vacuum leak...which maybe found/addressed by the installation of the new manifold.
#6920495 - 02/26/13 12:28 PM Re: So, I'm finally building an engine... [Re: UglyValiant]
#6926072 - 02/28/13 05:28 PM Re: So, I'm finally building an engine... [Re: ReplicaR]
The shop called, and the leaks are fixed according to them. They've used dye this time, and found that some bolts were loose by the rear of the oil pan. The transmission was resealed as well, since it was out of the car. Picking it up today, and it's going to sit in the garage until it goes to the tuning shop for intake manifold swap, and retune.
Intake manifold arrived yesterday, and the ports look a good deal bigger. I'm pretty stoked to see what will happen now.
