#6790297 - 12/24/12 04:42 PM
[Re: PsychoEBPSiR]
ReplicaR
#6807985 - 01/03/13 05:17 PM
[Re: ReplicaR]
ReplicaR
#6809607 - 01/04/13 11:25 AM
[Re: Impulsive]
ReplicaR
#6809703 - 01/04/13 11:53 AM
[Re: UglyValiant]
ReplicaR
#6840072 - 01/17/13 06:08 PM
[Re: ReplicaR]
ReplicaR
#6842596 - 01/18/13 04:32 PM
[Re: stickaz_old]
ReplicaR
#6842659 - 01/18/13 05:16 PM
[Re: ReplicaR]
stickaz_old
Loc: Nor Cal, Hella hurr durr
#6842700 - 01/18/13 05:40 PM
[Re: stickaz_old]
ReplicaR
#6842718 - 01/18/13 05:57 PM
[Re: ReplicaR]
stickaz_old
rice maths: cats = -5 no underdrive pulley = -8 timing = -10 (??)
#6842787 - 01/18/13 06:43 PM
[Re: stickaz_old]
ReplicaR
#6849158 - 01/22/13 10:56 AM
[Re: FCobra94]
ReplicaR
#6849367 - 01/22/13 12:21 PM
[Re: Impulsive]
ReplicaR
#6849885 - 01/22/13 03:41 PM
[Re: Impulsive]
ReplicaR
I think you forgot the link.
#6850458 - 01/22/13 08:25 PM
[Re: ReplicaR]
Impulsive
#6851532 - 01/23/13 11:29 AM
[Re: Impulsive]
ReplicaR
#6855153 - 01/24/13 08:12 PM
stickaz_old
#6899398 - 02/14/13 10:59 PM
[Re: stickaz_old]
ReplicaR
Bit of an update.
#6899636 - 02/15/13 07:42 AM
[Re: ReplicaR]
UglyValiant
Something has happened to it, and it's running very rich at idle, idle is unstable, and it backfires through intake on sudden throttle. My guess is either a pushrod bent or one or more of the rocker bolts backed out and is now out of adjustment (more likely)....even w/ locking nuts, it's not terribly uncommon for one or two to back out once or twice after initial assembly and running for a 100+ miles or so...
#6900328 - 02/15/13 11:25 AM
[Re: UglyValiant]
ReplicaR
#6918875 - 02/25/13 02:05 PM
[Re: Impulsive]
ReplicaR
Update 02/25/2013
Rear seat removal: -40 lbs Spare tire and jack: -32 lbs Torino II to Evo swap: -30 lbs Aluminum side mount brakets: +5 lbs Cobra R to RPF1 wheel change: -16 lbs Reinstall strut tower brace and K-member brace: +15 lbs Rear floor mats: -2 lbs
#6920394 - 02/26/13 11:45 AM
[Re: ReplicaR]
ReplicaR
#6920495 - 02/26/13 12:28 PM
[Re: UglyValiant]
ReplicaR
#6926072 - 02/28/13 05:28 PM
[Re: ReplicaR]
ReplicaR
The shop called, and the leaks are fixed according to them. They've used dye this time, and found that some bolts were loose by the rear of the oil pan. The transmission was resealed as well, since it was out of the car. Picking it up today, and it's going to sit in the garage until it goes to the tuning shop for intake manifold swap, and retune.
Intake manifold arrived yesterday, and the ports look a good deal bigger. I'm pretty stoked to see what will happen now.
