#4314272 - 12/07/09 01:29 PM
BMtroubleU strikes again!
Quad4_driver
Loc: B.C. Canada
Odd issue with the E39. It had been having a little bit of a rough start up, and not smooth idle for a few seconds. Almost like not all cylinders were fireing. So i decided to change the plugs for the heck of it. Sure enough they were the OE plugs that even said BMW on them still, 130k miles old and all. They weren't in terrible shape but certianly were not performing like new either.
After the plugs were replaced it ran great and fixed the rough idle. However 3 weeks later it has this for lack of a better term a cough. It would almost stall,and this morning it did stall. Upon second crank over it fired right up, no problem and ran like normal. It's not throwing codes and running smooth otherwise.
Any ideas???
#4314483 - 12/07/09 02:27 PM
Re: BMtroubleU strikes again!
[Re: Quad4_driver]
Z24 lol
and Fuck you for the new name lol
Loc: Lovely CONROE, TX! YEE-HA!
fuel pump?
#4315737 - 12/07/09 08:29 PM
[Re: Quad4_driver]
Sounds like a vacuum leak, but if it disappears...well.... it's not a vacuum leak, lol.
#4315945 - 12/07/09 09:52 PM
theLoon
Loc: MN
I'm a badge whore
#4316253 - 12/07/09 11:20 PM
[Re: DPG23]
EclipseGT
Loc: Lenexa, KS
like mentioned above replace fuel filter if it has not been done. Did you replace the coil boots when you did the plugs? Every bmw I have owned runs like shit on cold starts this time of year, even the MINI its rough and sounds like a diesel in the winter till it warms up.
Do yourself a favor and invest in Carsoft, here is a link to the knockoff china cables: http://www.thee85.com/bmw_multiplexer_carsoft_65
You can download 6.5 for free online. Even though you may not have a check engine light chances are it recorded a fault or two when it stalled. I pulled about a dozen faults on the M3 after I installed the supercharger and the tune, none triggered the check engine light.
Carsoft allows you to print the data off, store it, provides details on the fault and possible reasons, sometimes tells you how to correct it, and allows you to clear them. It also allows you to clear any adaptation values, check all systems, recode keys, reset service lights, recode ecu's, configure iDrive on new models, watch and record live data when the car is running such as o2 values, temp, throttle position, air intake temp, etc.
98 e36 M3/4/5 VF Supercharger 06 Porsche Cayenne S 06 Mercedes C280
#4316276 - 12/07/09 11:27 PM
[Re: Quad4_driver]
EclipseGT
Loc: Lenexa, KS
Yeah, its like its starving for fuel.
Just been doing some reading on bimmer forums, looks like it could be the VANOS unit , fuck my life that'll cost me over a grand to fix.
http://www.drvanos.com
$300+gasket kit
chances are you would hear the vanos unit going out. Change the filter and honestly if it were me unless it gets worse dont worry about it...
#4316337 - 12/07/09 11:49 PM
[Re: NOT spotch...]
Quad4_driver
Loc: B.C. Canada
Just been doing some reading on bimmer forums, looks like it could be the VANOS unit , fuck my life that'll cost me over a grand to fix. http://www.drvanos.com$300+gasket kit chances are you would hear the vanos unit going out. Change the filter and honestly if it were me unless it gets worse dont worry about it...
Hrmm that is intertesting. Far cheaper then the 880 dollar one from Bimmerparts.ca.
Breakdowns aside, how's the 530 drive?
It drives fairly nice. It has decent power , although in the low RPM it sounds like a vacuum , upper RPM makes an ok noise, but its so muted its not that fun.
Handles like the near 3400lbs car that it is. It does understeer badly if you dump it into a corner, however take the traction controll off and you can get the rear to rotate and keep the front end going where you want it, it would be a lot more fun with an LSD. It has nice steering feel, but honestly I thought the grand am was just as good.
It has grown on me over the last 2 years. I still feel that the my GA was much more fun to drive. However it had super loud exhuast, the power windows didn't work, nor did the inteior lights. And it was huge handfull to drive fast always trying to change lanes on you every shift.
The bimmer was a good buy, although I prolly paid to much for it, lol BMW resale blows.
#9142368 - 09/27/17 05:40 AM
[Re: Quad4_driver]
lzm
#9173978 - 10/31/17 03:26 AM
[Re: lzm]
HYst
