#4314272 - 12/07/09 01:29 PM BMtroubleU strikes again!
Quad4_driver Offline
Loc: B.C. Canada
Odd issue with the E39. It had been having a little bit of a rough start up, and not smooth idle for a few seconds. Almost like not all cylinders were fireing. So i decided to change the plugs for the heck of it. Sure enough they were the OE plugs that even said BMW on them still, 130k miles old and all. They weren't in terrible shape but certianly were not performing like new either.
After the plugs were replaced it ran great and fixed the rough idle. However 3 weeks later it has this for lack of a better term a cough. It would almost stall,and this morning it did stall. Upon second crank over it fired right up, no problem and ran like normal. It's not throwing codes and running smooth otherwise.
Any ideas???
#4314483 - 12/07/09 02:27 PM Re: BMtroubleU strikes again! [Re: Quad4_driver]
Z24 lol Offline
and Fuck you for the new name lol
Loc: Lovely CONROE, TX! YEE-HA!
fuel pump?
#4315124 - 12/07/09 05:08 PM Re: BMtroubleU strikes again! [Re: Z24 lol]
AMG SiR Offline
Loc: Abbotsford B.C. CANADA
Is the air mass an issue on BMW's like every other German car?
#4315233 - 12/07/09 06:00 PM Re: BMtroubleU strikes again! [Re: AMG SiR]
Loc: B.C. Canada
They are somtimes. The mass air is clean though.
#4315737 - 12/07/09 08:29 PM Re: BMtroubleU strikes again! [Re: Quad4_driver]
Sounds like a vacuum leak, but if it disappears...well.... it's not a vacuum leak, lol.
#4315751 - 12/07/09 08:35 PM Re: BMtroubleU strikes again! [Re: LNXGUY]
Loc: B.C. Canada
Yeah, its like its starving for fuel.
Just been doing some reading on bimmer forums, looks like it could be the VANOS unit , fuck my life that'll cost me over a grand to fix.
#4315819 - 12/07/09 09:02 PM Re: BMtroubleU strikes again! [Re: LNXGUY]
fuel filter?
#4315945 - 12/07/09 09:52 PM Re: BMtroubleU strikes again! [Re: Euphoricuck]
theLoon Offline
Loc: MN
fuel filter?
I'm a badge whore
#4315949 - 12/07/09 09:52 PM Re: BMtroubleU strikes again! [Re: Quad4_driver]
DPG23 Offline
Loc: Los Angeles, CA
Was it sitting for a while? Those M54s run like dogshit on cold starts sometimes.
Do you have Bosch or Bremi coils? The Bremi coils are junk and should've been replaced by now. (E39 with M54 from 9/02 up to 7/03)
If possible i'd put a fuel pressure gauge on during cold start and see what the pressure is...should be around 50psi. Fuel filter should've been replaced at 100k also.
Or...have you been losing any coolant slowly? Seen slow head gasket leaks cause cold start misfires and then run decent afterwards. Fails leakdown test tho.
#4316251 - 12/07/09 11:19 PM Re: BMtroubleU strikes again! [Re: DPG23]
Loc: B.C. Canada
I have not noticed coolent loss. I was a little worried that it could be a small head gasket leak though, as for the last few days there was quite a lot of condensation comming out of the exhaust. However it has been just above freezing with tons of moisture in the air. Today its dropped below freeing with little moisture and no more exhaust steam. I also figured that the plugs would have had a sign of buring coolant on them, they didn't.
Could be a fuel filter I haven't done that yet, and i believe the pressure reg is built into them.
My car was built 9/00 so its a very early 530, i'll pull off the cover again ,because I did not look at which coils were in it.
BTW it was only sitting over night.
#4316253 - 12/07/09 11:20 PM Re: BMtroubleU strikes again! [Re: DPG23]
EclipseGT Offline
Loc: Lenexa, KS
like mentioned above replace fuel filter if it has not been done. Did you replace the coil boots when you did the plugs? Every bmw I have owned runs like shit on cold starts this time of year, even the MINI its rough and sounds like a diesel in the winter till it warms up.
Do yourself a favor and invest in Carsoft, here is a link to the knockoff china cables: http://www.thee85.com/bmw_multiplexer_carsoft_65
You can download 6.5 for free online. Even though you may not have a check engine light chances are it recorded a fault or two when it stalled. I pulled about a dozen faults on the M3 after I installed the supercharger and the tune, none triggered the check engine light.
Carsoft allows you to print the data off, store it, provides details on the fault and possible reasons, sometimes tells you how to correct it, and allows you to clear them. It also allows you to clear any adaptation values, check all systems, recode keys, reset service lights, recode ecu's, configure iDrive on new models, watch and record live data when the car is running such as o2 values, temp, throttle position, air intake temp, etc.
98 e36 M3/4/5 VF Supercharger
06 Porsche Cayenne S
06 Mercedes C280
#4316276 - 12/07/09 11:27 PM Re: BMtroubleU strikes again! [Re: Quad4_driver]
EclipseGT Offline
Loc: Lenexa, KS
http://www.drvanos.com
$300+gasket kit
chances are you would hear the vanos unit going out. Change the filter and honestly if it were me unless it gets worse dont worry about it...
06 Mercedes C280
#4316299 - 12/07/09 11:35 PM Re: BMtroubleU strikes again! [Re: EclipseGT]
NOT spotch... Offline
Breakdowns aside, how's the 530 drive?
#4316337 - 12/07/09 11:49 PM Re: BMtroubleU strikes again! [Re: NOT spotch...]
Loc: B.C. Canada
$300+gasket kit
Hrmm that is intertesting. Far cheaper then the 880 dollar one from Bimmerparts.ca.
It drives fairly nice. It has decent power , although in the low RPM it sounds like a vacuum , upper RPM makes an ok noise, but its so muted its not that fun.
Handles like the near 3400lbs car that it is. It does understeer badly if you dump it into a corner, however take the traction controll off and you can get the rear to rotate and keep the front end going where you want it, it would be a lot more fun with an LSD. It has nice steering feel, but honestly I thought the grand am was just as good.
It has grown on me over the last 2 years. I still feel that the my GA was much more fun to drive. However it had super loud exhuast, the power windows didn't work, nor did the inteior lights. And it was huge handfull to drive fast always trying to change lanes on you every shift.
The bimmer was a good buy, although I prolly paid to much for it, lol BMW resale blows.
#4318242 - 12/08/09 02:38 PM Re: BMtroubleU strikes again! [Re: Quad4_driver]
Loc: B.C. Canada
Update:
Still has the problem it coughed really bad this morining, sounded like metal parts hitting each other.
I'm thinking it's the vanos unit. Anyone done one before?
#9142368 - 09/27/17 05:40 AM Re: BMtroubleU strikes again! [Re: Quad4_driver]
lzm Offline
payless shoes online store
Mizuno Shoes
Nike Blazer
pandora rings
Air Max 87 Homme
pandora rings
kate spade outlet bags on Sale
Nike Air Max LTD
Air MAX SKYLINE
mlb shop
puma outlet online
kate spade outlet canada
ray-ban eyeglasses
classic
pandora charms sale
michael kors outlet sale
hermes outlet store
best website directory
birkenstock outlet store
Longchamp Sale
under armour on sale
Prada Outlet
kate spade sale
timberland boots on sale
louis vuitton bags
ray ban outlet store
pandora rings
Nike Air Max 90
Promise Rings - Official
clb sports shoes
moncler clothing
Lisinopril 2.5 Mg Cost
coach
michael kors australia
prada outlet online sale
fake sunglasses sale
louis vuitton uk
talons
Coach Sunglasses Outlet
pandora online outlet
casio watches for women
Air Max 180
michael kors purses
Air Jordan
birkenstock outlet
ray ban online
prada online
cool math games
spendless shoes sale
pandora charms outlet
Birkin Bag Hermes
under armour shoes online
prada bags
birkenstock sale
Wholesale Outlet Sale
Mizuno Shop Japan
Engagement Rings - Official
payless shoes store
authentic shoes
chaussures pas cher en ligne
pandora bracelet
Kaufen Nike Air Max 1
brand sunglasses
ray ban prescription sunglasses
Nike Air Jordan Femme
Nike Air Max TN
hermes outlet sale online
coach carter
pandora rings
Mens Sunglasses
Nike Air Max BW
pandora bracelet uk
canada goose outlet online store
michael kors uk sale
black friday sales online
moncler us
michael kors bags online
Prada Bags
Salomon Shoes
Nike Air Max LTD
yeezy shoes kids
Nike Schuhe
oakley outlet online store
birkenstock outlet online
pandora rings
wordpress
ray ban erika sunglasses
Premier Jewelry. - Official
Nike Roshe Run Femme
timberland sale
Coach Handbags
snow boots
pandora charms uk
oakley australia
coach shoes
zales jewelry outlet
import sunglasses
timberland boots
Nike Schuhe Jungen
Air Jordan Flight
black friday 2016
chrome store
tiffany
Nike Air Max 95
Markenschuhe
trazodone100mg
pandora bracelet
Prada Shoes - Official
Michael Kors Canada
puma outlet
nba shop
Air Max Femme
kate spade outlet sale
breitling watches for sale
Nike Air Max LTD
Nike Schuhe Mädchen
mcm outlet
Nike Air Presto
pandora rings uk
michael kors bags outlet
Add Your Link Free
Nike Air Jordan
boulder shoes sale
Black Friday Ads
small business
pandora jewelry charms
Oakley Sunglasses
prada factory outlet
kate spade online sale
Air Max BW Femme
goose outlet sale
buy under armour stock
adidas yeezy boost 350
omega watches for sale
Nike Free Run
Nike DUNKSB
shoes sale
ugg boots outlet
louis vuitton outle sale
abercrombie canada
Air Jordan
Air Max 90 Femme
puma shoes online sale
pandora necklace sale
louis vuitton bags
chrome store
ray ban polarized
puma sneakers online store
louis vuitton outlet store
kate spade bags store
michael kors factory outlet
vêtements de mode
Coach Outlet
prada outlet online
pandora rings
eznara
pandora rings uk
rayban glasses
prada sale
Nike Air Max Lebron 10
ray ban outlet online
Online Oyun
kate spade outlet online sale
Louis Vuitton USA
the beat
pandora earrings on sale
nike running
timberland boots sale
Nike Schuhe
puma sale
coach factory outlet
michael kors online
chanel bag
birkenstock canada sale
ray ban glasses frames
kanye west shoes sale
pandora rings
Nike Air Max 90
moncler jacket
coach factory outlet online store
evbid
diesel watches for men
Air Max 90 Enfant
ray ban justin sunglasses
chrome hearts
timberland shoes online sale
pandora charm necklace
puma sneakers sale
louis vuitton online
swatch store
Dreamland Jewelry - Official
Air Jordan
Nike Air Max TN
Green Cleaned
Wedding Rings- Official
Prada Sunglasses - Official
Diamond Rings - Official
ugg
nike jordan
mk,australia
outlet sale online
coach usa
school bags online store
Burberry Shirt - Official
moncler jacket
nike huarache shoes
louis vuitton bags
tiffany
Nike Air Max
chrome hearts jewelry
Air Max 90
michael kors bags
mode damenschuhe
ray ban clubmaster sunglasses
sunglasses hut
ermes bag for sale
handbags online
Jewelry Armoire - Official
rayban sunglasses
Nike Blazer
Nike Free Homme
pandora bracelet
louis vuitton bags online sale
pandora bracelet
kate spade official
celine outlet
sac louis vuitton
Air Max 95 Femme
payless shoes outlet sale
Nike Air Jordan Femmes
[/b]
oakley outlet sale
burberry outlet sale online
school bags store
Abercrombie Nederland
sunglasses online
Nike Blazer Homme
puma shoes online store
under armour outlet store
Ray Ban Outlet store
Lunette Oakley Ducati Scalpel en soldes
ups tracking number
payless coupons
ray ban sunglasses outlet sale
michael kors bags
payless shoes store
nike chaussure
rayban wayfarer
hermes belt men
[b]80's,eighties fashion
louis vuitton
birkenstock australia
CHanel Factory Outlet
ugg outlet sale
Family Name Research
Nike Jordan Shoes
adidas yeezy boost
Doxycycline
Nike Air Max Light
new yeezy shoes
kate spade australia
Pembesar Penis
KD 8 shoes
AIR MAX LTD 2
coach bags
puma sale
kate spade wallet
coach handbags
ugg
michael kors bags
gucci women watches
payless
China Wholesale
ray-ban outlet
Nike Air Max BW
Burberry Australia
louis vuitton sale
birkenstock sandals online
Nike Air Max 90 Damen
black friday online
gold michele watch
nike outlet sale
Nike Air Max 95
pandora charms sale
michael kors handbags sale
burberry bags outlet on sale
michael kors shoes outlet
coach outlet online sale
birkenstock sandals sale
kay jewelers
Prada bags
coach handbags
Brighton Jewelry - Official
Pharmacy Discount Network
hermes uk
skechers shoes sale
kate spade purses outlet sale
Louis Vuitton Outlet Online
longchamp outlet online
puma outlet sale
rayban wayfarer
mens sunglasses
fulam shoes sale
ray ban shop sale
Nike Air Max Flywire
chaussures asics homme
Jared Jewelry - Official
Air Jordan 1
Air Jordan Fusion
coach australia online shop
pandora rings sale
pandora bracelet
asics gel kayano
ugg slippers sale
tạp chí ẩm thực
balenciaga outlet online store
Premier Jewelry - Official
search
pandora rings
Jordan Fusion Homme
Nike Air Max 2017
rayban prescription glasses
chrome hearts
prada outlet online
kate spade bags
birkenstock sandals outlet sale
rolex watches for men
louis vuitton shop
ray ban sale online
louis vuitton factory outlet
Air Max Homme
north face outlet sale
official prada site
ray ban wayfarer
cartier watches for men
ray ban outlet on sale
louis vuitton sale
ray ban sunglasses sale
coachs outlet sale
Nike Air Max TN Femme
black friday ads
pandora charms uk sale
burberry outlet store
puma online store
Nike Free,Nike Shox
Louis Vuitton outlet
coach factory outlet sale
Nike Air Max 90
Jordan Aero Mania Homme
adidas online
Nike Air Max Lunar 90 Damen
kate spade bags outlet
louis vuitton outlet sale
baseball jerseys
coach sale online
prada outlet online
Air Max TN Homme
rayban aviator
Nike Air Griffey Max Homme
Cheap Ray Ban
school bags online sale store
seiko automatic watches
hermes belt for sale
birkenstock gizeh sale
mk outlet online
Nike Air Jordan Homme
Nike Air Max TN
mk outlet online store
michael kors bags on sale
michael kors bags
hermes bag birkin
Air Jordan 4 Femme
puma suede online
2015 Nike Dunk
Air Jordan Femme
pandora charms sale
Nike Air Max 95 Homme
lzm9.27
#9173978 - 10/31/17 03:26 AM Re: BMtroubleU strikes again! [Re: lzm]
HYst Offline
