#3192152 - 11/08/08 06:11 PM Dyno'd my Suzuki Bandit :(
vwkaferman Offline
Loc: Mesa, AZ
Well, finally got the pig dyno'd. I never did do a baseline, so I have no idea how much power my goodies added.
No sense in farting around:
Looks like 106 HP @ around 8800rpm & 71ft-lbs of torque almost across the board.
Now, why the sad face? I've got Dale's Stage II jet kit, K&N pods, timing advancer, and his high pipe slip on. I installed all with the recommended base settings, and over a period of 6 months, adjusted the needles up and down to get rid of stumble.
I thought I'd be closer to 115hp and a little bit more torque. The Dyno guy said that it was corrected HP for sea level and all that but to be honest, I've seen a million dyno graphs and this one just doesn't seem to have much info. No Barometric pressure, humidity, temp so I could at least plug some #'s in and recalculate. I think we're at around 1100 feet or so, and it was about 60ish this morning.
Looks like I'll be getting Dale's stepped header (Dale Walker, Holeshot Performance) sooner than I thought. The only thing the Dyno operator mentioned that it looked a little lean at cruise. So, I can dial in maybe a 1/4 turn out on the A/F screws to see if it helps that but otherwise, I think I have everything set to where it needs to be.
James
'74 Beetle, 0-60, probably
'97 Jeap XJ, '05 Bandit 1200
maPiH
#3192281 - 11/08/08 07:30 PM Re: Dyno'd my Suzuki Bandit :( [Re: ]
I've read that you want to be slightly richer than stoich to make sure all the air has access to fuel for max power. Somewhere in the 13.5-14:1 range.
Maybe it's a tiny bit leaner than it should be through the whole range.
#3192288 - 11/08/08 07:40 PM Re: Dyno'd my Suzuki Bandit :( [Re: Impulsive]
vwkaferman Offline
Loc: Mesa, AZ
Thanks fellas. Well, I've got the biggest jets installed that came with the kit. I wonder if turning my Air/Fuel screws out a 1/4 at a time and maybe adjusting the needles one more notch towards the richer side would help. I thought it was running rich to begin with (before the Dyno). Hmmm might have to take a look at a few things.
I tuned it using a link Factory Pro has, it seems to be pretty much dialed in per that. Can't hurt to play, as long as I make the changes, it's free and Dyno is only $30.
Thanks again.
James
*Edit* Adding link in case others out there haven't seen it or wanted to take a look: Factory Pro Carb tuning
Edited by vwkaferman (11/08/08 07:44 PM)
maPiH
#3192433 - 11/08/08 09:37 PM Re: Dyno'd my Suzuki Bandit :( [Re: vwkaferman]
Too bad you didn't get a baseline. What's your butt dyno tell you about the mods?
#3192968 - 11/09/08 10:09 AM Re: Dyno'd my Suzuki Bandit :( [Re: ScottStaypuff]
daemon Offline
Loc: West Columbia, SC
Time to get some GSX-R1100 goodies.
#3193523 - 11/09/08 02:39 PM Re: Dyno'd my Suzuki Bandit :( [Re: ]
Scargoes Offline
Loc: High Dessert
 Originally Posted By: 98_1LE
If the dashed line on your air/fuel is stoichiometric, it looks a little leaner than I like across the board, especially 4-6k rpm.
I think the dashed line is supposed to represent 13:1. Anyway, iirc, for best power on an N/A setup the AF should be near 12.8:1. At least that was always my understanding.
#3195501 - 11/10/08 11:08 AM Re: Dyno'd my Suzuki Bandit :( [Re: ]
silentfurymm Offline
Loc: SoCal....again
Seems strong to me, but I have a warped view. If I had another 40 wheel hp and 30lb/ft I would have to redifine fast for myself. Actually I keep knocking around the idea of either buying a new Bandit 1250S for a second bike, or selling they SV to get a Bandit. I kind of want something better suited to long hauls.
#3195560 - 11/10/08 11:28 AM Re: Dyno'd my Suzuki Bandit :( [Re: ]
SamuraiSam Offline
Loc: Bellingham, WA
Going about tuning fuel by specifying a target AFR is not the best idea.
Also, I can't comment about your cruise AFR, since it is not indicated on a dyno chart. The best thing you could do, is get a wideband o2 controller, put it on the bike, and make some changes. Cruise & idle = stoichiometric or leaner, unless it doesn't idle nicely at stoich. With carbs everything is a balancing act and you probably couldn't make any changes without fucking up the top-end perfection you've achieved.
Maximum power AFR is a function of brake specific fuel consumption (which is influenced by VE, other efficiencies and losses, combustion chamber shape, etc.) On a bike, maybe you are able to really play with fuel to a point of perfection, but on a car, fueling is a means of thermal management and ignition timing determines power. You always run rich of WOT best power.
#3282312 - 12/09/08 04:13 PM Re: Dyno'd my Suzuki Bandit :( [Re: SamuraiSam]
GB Offline
Sharesies!
Loc: Craigslist
bump because he got a header.
#3283130 - 12/09/08 08:09 PM Re: Dyno'd my Suzuki Bandit :( [Re: GB]
vwkaferman Offline
Loc: Mesa, AZ
Haha fucker! \:\) Yeah, I really hope I can sneak away from work this week to get another run in on the dyno. It seems to scream towards redline a bit faster. Both due to the header and minor tweaks I did to the needles (tad richer). Of course it could all be in my head as the weather is even cooler.
Maybe Friday?
Gotta post a pic, old vs. new:
James
maPiH
#3283518 - 12/09/08 10:05 PM Re: Dyno'd my Suzuki Bandit :( [Re: vwkaferman]
Noob4Life Offline
Loc: IL, USA
Shoulda got a Suzuki Escudo Pike's Peak Version if you wanted megahuge HP's.
#3283969 - 12/10/08 12:40 AM Re: Dyno'd my Suzuki Bandit :( [Re: Noob4Life]
MrManGuy Offline
LOL, reppin' the GT2?
'09 Toyota Tacoma 4x4 Access Cab
#3284362 - 12/10/08 08:32 AM Re: Dyno'd my Suzuki Bandit :( [Re: MrManGuy]
Well, yep...as far as car's go, you're shooting for ~12.5:1 or so...if you were at 12.8, it would be a big deal to try and get another few tenths on way or the other.
The thing I'd caution you against doing is trying to fiddle with air/fuel mixture screws in any way, shape, or form to get the AFR you want. 1) It won't make a significant difference in the mixture at full power. 2) It may significantly worsen the part throttle/idle performance of the bike. 3) It may worsen the throttle response, likely inducing another bog/stumble. From the sounds of it, you didn't do too much...BUT, you could be being crutched along by colder/denser/less humid air too. Always approach fiddling with mixture screws VERY cautiously.
IF for some reason you can't find the jet's you need....do it the old school way. Drill them out. There are generally reference charts that'll show what each jet correlates to as far as drill bit sizes. IF the red line is truly 13:1 (which it perhaps is...you might actually get a little back-fire running 14.7:1 under full power), I'm not so sure I'd touch it...perhaps going up one, perhaps two sizes at most. If the line DOES represent 14.7:1, then safely go up two sizes and leave alone until you can check the full-power AFR on a dyno again. You might go anywhere from 2-6 sizes bigger (though I think 2-3 would net you something pretty close).
#3286563 - 12/10/08 08:02 PM Re: Dyno'd my Suzuki Bandit :( [Re: MrManGuy]
Noob4Life Offline
Loc: IL, USA
wasn't it GT1? or was a fully built 3000GT still the king of HP in GT1?
#3286627 - 12/10/08 08:26 PM Re: Dyno'd my Suzuki Bandit :( [Re: Noob4Life]
daemon Offline
I think the Viper was king in GT1.
#3288653 - 12/11/08 01:48 PM Re: Dyno'd my Suzuki Bandit :( [Re: daemon]
Chris_82 Offline
Loc: San Diego, CA
Hp was everything in that shit, 3kgt was the king.
[BobBarker] basically, I hate everything
[Texas House Wife] if you dont like mazda you are a shitty car enthusiast imo
I have no enemies but even if I did they would be served QUALITY -Paki
#3289001 - 12/11/08 03:11 PM Re: Dyno'd my Suzuki Bandit :( [Re: Chris_82]
CommonGutterTrash Offline
Not at all. The cebera LM was THE car....
Edited by g96nt (12/11/08 03:11 PM)
Craig R.
2000 9-5 Gary Fisher Wagon
1995 850 T-5R
1996 Galant
AIM = gclipse96
#9142370 - 09/27/17 05:41 AM Re: Dyno'd my Suzuki Bandit :( [Re: CommonGutterTrash]
lzm Offline
payless shoes online store
Mizuno Shoes
Nike Blazer
pandora rings
Air Max 87 Homme
pandora rings
kate spade outlet bags on Sale
Nike Air Max LTD
Air MAX SKYLINE
mlb shop
puma outlet online
kate spade outlet canada
ray-ban eyeglasses
classic
pandora charms sale
michael kors outlet sale
hermes outlet store
best website directory
birkenstock outlet store
Longchamp Sale
under armour on sale
Prada Outlet
kate spade sale
timberland boots on sale
louis vuitton bags
ray ban outlet store
pandora rings
Nike Air Max 90
Promise Rings - Official
clb sports shoes
moncler clothing
Lisinopril 2.5 Mg Cost
coach
michael kors australia
prada outlet online sale
fake sunglasses sale
louis vuitton uk
talons
Coach Sunglasses Outlet
pandora online outlet
casio watches for women
Air Max 180
michael kors purses
Air Jordan
birkenstock outlet
ray ban online
prada online
cool math games
spendless shoes sale
pandora charms outlet
Birkin Bag Hermes
under armour shoes online
prada bags
birkenstock sale
Wholesale Outlet Sale
Mizuno Shop Japan
Engagement Rings - Official
payless shoes store
authentic shoes
chaussures pas cher en ligne
pandora bracelet
Kaufen Nike Air Max 1
brand sunglasses
ray ban prescription sunglasses
Nike Air Jordan Femme
Nike Air Max TN
hermes outlet sale online
coach carter
pandora rings
Mens Sunglasses
Nike Air Max BW
pandora bracelet uk
canada goose outlet online store
michael kors uk sale
black friday sales online
moncler us
michael kors bags online
Prada Bags
Salomon Shoes
Nike Air Max LTD
yeezy shoes kids
Nike Schuhe
oakley outlet online store
birkenstock outlet online
pandora rings
wordpress
ray ban erika sunglasses
Premier Jewelry. - Official
Nike Roshe Run Femme
timberland sale
Coach Handbags
snow boots
pandora charms uk
oakley australia
coach shoes
zales jewelry outlet
import sunglasses
timberland boots
Nike Schuhe Jungen
Air Jordan Flight
black friday 2016
chrome store
tiffany
Nike Air Max 95
Markenschuhe
trazodone100mg
pandora bracelet
Prada Shoes - Official
Michael Kors Canada
puma outlet
nba shop
Air Max Femme
kate spade outlet sale
breitling watches for sale
Nike Air Max LTD
Nike Schuhe Mädchen
mcm outlet
Nike Air Presto
pandora rings uk
michael kors bags outlet
Add Your Link Free
Nike Air Jordan
boulder shoes sale
Black Friday Ads
small business
pandora jewelry charms
Oakley Sunglasses
prada factory outlet
kate spade online sale
Air Max BW Femme
goose outlet sale
buy under armour stock
adidas yeezy boost 350
omega watches for sale
Nike Free Run
Nike DUNKSB
shoes sale
ugg boots outlet
louis vuitton outle sale
abercrombie canada
Air Jordan
Air Max 90 Femme
puma shoes online sale
pandora necklace sale
louis vuitton bags
chrome store
ray ban polarized
puma sneakers online store
louis vuitton outlet store
kate spade bags store
michael kors factory outlet
vêtements de mode
Coach Outlet
prada outlet online
pandora rings
eznara
pandora rings uk
rayban glasses
prada sale
Nike Air Max Lebron 10
ray ban outlet online
Online Oyun
kate spade outlet online sale
Louis Vuitton USA
the beat
pandora earrings on sale
nike running
timberland boots sale
Nike Schuhe
puma sale
coach factory outlet
michael kors online
chanel bag
birkenstock canada sale
ray ban glasses frames
kanye west shoes sale
pandora rings
Nike Air Max 90
moncler jacket
coach factory outlet online store
evbid
diesel watches for men
Air Max 90 Enfant
ray ban justin sunglasses
chrome hearts
timberland shoes online sale
pandora charm necklace
puma sneakers sale
louis vuitton online
swatch store
Dreamland Jewelry - Official
Air Jordan
Nike Air Max TN
Green Cleaned
Wedding Rings- Official
Prada Sunglasses - Official
Diamond Rings - Official
ugg
nike jordan
mk,australia
outlet sale online
coach usa
school bags online store
Burberry Shirt - Official
moncler jacket
nike huarache shoes
louis vuitton bags
tiffany
Nike Air Max
chrome hearts jewelry
Air Max 90
michael kors bags
mode damenschuhe
ray ban clubmaster sunglasses
sunglasses hut
ermes bag for sale
handbags online
Jewelry Armoire - Official
rayban sunglasses
Nike Blazer
Nike Free Homme
pandora bracelet
louis vuitton bags online sale
pandora bracelet
kate spade official
celine outlet
sac louis vuitton
Air Max 95 Femme
payless shoes outlet sale
Nike Air Jordan Femmes
[/b]
oakley outlet sale
burberry outlet sale online
school bags store
Abercrombie Nederland
sunglasses online
Nike Blazer Homme
puma shoes online store
under armour outlet store
Ray Ban Outlet store
Lunette Oakley Ducati Scalpel en soldes
ups tracking number
payless coupons
ray ban sunglasses outlet sale
michael kors bags
payless shoes store
nike chaussure
rayban wayfarer
hermes belt men
[b]80's,eighties fashion
louis vuitton
birkenstock australia
CHanel Factory Outlet
ugg outlet sale
Family Name Research
Nike Jordan Shoes
adidas yeezy boost
Doxycycline
Nike Air Max Light
new yeezy shoes
kate spade australia
Pembesar Penis
KD 8 shoes
AIR MAX LTD 2
coach bags
puma sale
kate spade wallet
coach handbags
ugg
michael kors bags
gucci women watches
payless
China Wholesale
ray-ban outlet
Nike Air Max BW
Burberry Australia
louis vuitton sale
birkenstock sandals online
Nike Air Max 90 Damen
black friday online
gold michele watch
nike outlet sale
Nike Air Max 95
pandora charms sale
michael kors handbags sale
burberry bags outlet on sale
michael kors shoes outlet
coach outlet online sale
birkenstock sandals sale
kay jewelers
Prada bags
coach handbags
Brighton Jewelry - Official
Pharmacy Discount Network
hermes uk
skechers shoes sale
kate spade purses outlet sale
Louis Vuitton Outlet Online
longchamp outlet online
puma outlet sale
rayban wayfarer
mens sunglasses
fulam shoes sale
ray ban shop sale
Nike Air Max Flywire
chaussures asics homme
Jared Jewelry - Official
Air Jordan 1
Air Jordan Fusion
coach australia online shop
pandora rings sale
pandora bracelet
asics gel kayano
ugg slippers sale
tạp chí ẩm thực
balenciaga outlet online store
Premier Jewelry - Official
search
pandora rings
Jordan Fusion Homme
Nike Air Max 2017
rayban prescription glasses
chrome hearts
prada outlet online
kate spade bags
birkenstock sandals outlet sale
rolex watches for men
louis vuitton shop
ray ban sale online
louis vuitton factory outlet
Air Max Homme
north face outlet sale
official prada site
ray ban wayfarer
cartier watches for men
ray ban outlet on sale
louis vuitton sale
ray ban sunglasses sale
coachs outlet sale
Nike Air Max TN Femme
black friday ads
pandora charms uk sale
burberry outlet store
puma online store
Nike Free,Nike Shox
Louis Vuitton outlet
coach factory outlet sale
Nike Air Max 90
Jordan Aero Mania Homme
adidas online
Nike Air Max Lunar 90 Damen
kate spade bags outlet
louis vuitton outlet sale
baseball jerseys
coach sale online
prada outlet online
Air Max TN Homme
rayban aviator
Nike Air Griffey Max Homme
Cheap Ray Ban
school bags online sale store
seiko automatic watches
hermes belt for sale
birkenstock gizeh sale
mk outlet online
Nike Air Jordan Homme
Nike Air Max TN
mk outlet online store
michael kors bags on sale
michael kors bags
hermes bag birkin
Air Jordan 4 Femme
puma suede online
2015 Nike Dunk
Air Jordan Femme
pandora charms sale
Nike Air Max 95 Homme
lzm9.27
#9173977 - 10/31/17 03:26 AM Re: Dyno'd my Suzuki Bandit :( [Re: lzm]
HYst Offline
#9235998 - 01/21/18 09:20 PM Re: Dyno'd my Suzuki Bandit :( [Re: HYst]
Andada
colts jerseys
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
true religion outlet
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
nfl jerseys wholesale
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
cheap basketball shoes
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
discount oakley sunglasses
buffalo bills jerseys
fitflops sale
polo ralph lauren outlet
nike huarache
seattle seahawks jerseys
jaguars jersey
#9236018 - 01/21/18 09:24 PM Re: Dyno'd my Suzuki Bandit :( [Re: ]
Andada
colts jerseys
bengals jersey
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
nike huarache
nike factory store
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
nike air jordan
patriots jerseys
carolina jerseys
eagles jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
steelers jerseys
air jordan uk
kate spade sale
nike blazer
adidas yeezy
jets jersey
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
ecco sandals
new york knicks
bears jerseys
kate spade sale
jimmy choo shoes
bills jerseys
redskins jerseys
tods shoes
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
cowboys jerseys
miami heat jersey
fitflops shoes
cheap nhl jerseys
nike roshe
boston celtics
fitflops sale
nike huarache
jaguars jersey
