#354887 - 08/19/06 01:41 AM vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!!!!!
G0TB00ST Offline
Loc: NEW JERZ
last week i was driving my 2000 si and i was at about 6700 rpms in second gear (getting on the highway) while all of a sudden my rpms dropped suddenly and my check engine light came on... vtec would work..... so i disconnected my battery for like 5 minutes.... turned the car back on and the light came off and the car was back to normal....... now last night (friday) i was getting on the highway again and in second gear and as i approached 5700 where vtec should kick in....... the car just seemed to rev..... and like the car never hit vtec. it just revved and then abnout 7000 the car sounded like vtec kicked in and then the rpms dropped again and another check engone light came on........ i disconnected the battery again and the light came off..... now i drove the car and everytime vtec kicked in it would kick in strong (normal) and then the sound would die off and then 2 seconds later kick in again.... everytime the sound dissapeared the power would not be felt....... what should i do........ im going to take it to work in the morning and have them take a look at it since i bought the car a month ago from my dealership ... the car has only 31000 miles and i bought it with 29500...... i dont think problems should occur... but hey......... every car has problems... please help me...
#354888 - 08/19/06 01:57 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
super_nguyen Offline
Loc: winnipeg manitoba canada
so you know somethings not right with your car and you still push it to 7000 rpm, instead of resetting the CEL why don't you just get it checked, everytime you unbolt the battery you lose the CEL so if its not lit up anymore you lost the fault code. have you checked the basic things such as the oil? vtec runs off oil pressure, make sure the oil is clean, check the oil pressure sending unit for leaks. also when the CEL is on vtec won't engage, your car sorta goes into limp mode, so revving the piss outta your engine won't help matters. take it to a trustworthy shop to diagnose your problems.
#354889 - 08/19/06 02:34 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
JoshuaVTEC Offline
Loc: Neither here, nor there.
Uhhh which CEL is it.........
#354890 - 08/19/06 08:53 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
iPood Offline
Loc: Green Bay, WI
Yes, +1
#354891 - 08/19/06 10:22 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
Speedfreaksi Offline
Loc: Denton, Tx
anytime it goes into limp/fail safe mode DONT try to rev it..that will do ALOT of damage but if it really is in limp/fail safe mode it shouldnt let you rev past like 5k or 5500 if remember right...i had a 00 gsr this happened to and with in 24 hrs i had engine knock...failed rod bearing..pray its nothing that serious..i think honda should put in oil pressure guages from the factory cuz it can only take on time of losing oil pressure and you can do REAL damage..hope it nothing serious..best wishes
2000 EBP Honda Civic Si 06redsi: ive got 33wtq over stock baseline with my 3'' exhaust!!
#354892 - 08/19/06 02:32 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
HCivic02 Offline
Loc: CA
sounds like a Code 22.
Chris
06' Evo IX - E85@29psi
13' FRS
#354893 - 08/19/06 09:24 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
00civicsiboy Offline
Loc: Tennessee
what would a p1259 mean? I know it is a vtec failure but is it just the solenoid?
AIR ASSAULT!!
#354894 - 08/21/06 12:05 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
Dr. BrokenLimits Offline
Loc: Austin, TX
did you check the oil?
/Brandon
#354895 - 08/21/06 01:09 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
HCivic02 Offline
Loc: CA
May be the solenoid, the screen is clogged, pressue unit is funkd...low oil etc
Chris
13' FRS
#354896 - 08/21/06 03:24 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
Loc: Tennessee
If it is the screen, how would the screen get clogged?
AIR ASSAULT!!
#354897 - 08/21/06 04:25 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
jellydoughnutt Offline
gunk in the oil,if you are near nashville i can take a look at it for ya.send me a pm of somthing ive taken mine apart so i could give you some ideas on how to fix it.
EDIT:nevermind your not the op didnt notice that
Edited by jellydoughnutt (08/21/06 05:10 PM)
#354898 - 08/21/06 06:37 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
Loc: Tennessee
Like I said I am throwing a p1259 and it lets me rev past 5500...
AIR ASSAULT!!
#354899 - 08/21/06 09:01 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
look here for more info on your code
#354900 - 08/21/06 09:42 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
Runnin@Redline Jr Offline
Loc: Midwest Eh?
Sounds like your VTEC Solenoid is failing, do what everyone else says check your oil / filter screen then check the solenoid.
Adam
#354901 - 08/23/06 09:13 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
G0TB00ST Offline
Loc: NEW JERZ
it was extrememly low on oil.............. i put like 2.5 quarts in it..... i only had the car for like 2000 miles...... and i am surprised to see the car consuming oil like that...... but from what i hear...... its normal....... if your beating the piss out of the car. which i am guilty of. i also spoke to someone who said that the exhaust i have can make it consume oil like that. he said to rub my hand along the rear bumper by the exhaust and see if i have a hand full of black residue........ which i have and he said that can be the cause. i dunno... now im more careful. i bought the car last month with 29500 on it and now i have 31800.... im just gonna take it easy now. but once again thank u all for ya help
b**st
#354902 - 08/23/06 11:33 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
wait your 2000 si only has 31800 miles? are you sure the odometer wasn't rolled back?
#354903 - 08/23/06 01:36 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
and he olny had 1 quart of oil in your car and you were driving it hard,thats not going to last very long
#354904 - 08/23/06 06:10 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
G0TB00ST Offline
Loc: NEW JERZ
the mileage wasnt rolled back....... the person who had the car worked at my dealership.... he never drove the car and it used to sit in his garage for months at a time before he drove the car... and as for the oil........ im checking it every 2 days now.... im not gonna let anything happen like that anymore...
#354905 - 08/23/06 09:55 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
Yeah, IF you still have a stock rear bumper, get that thing off of there...
They've been known to pull oil out of your motor...
Donny
Import Specialty Automotive
#354906 - 08/25/06 04:50 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
G0TB00ST Offline
Loc: NEW JERZ
lol.......... im just repeating what the service writer told me at the dealer i work for..... eh.. fuk it.......... no problems anymore...... lets just hope everything keeps on going smoothly
#354907 - 09/29/06 07:23 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
Mr2000Si Offline
Loc: CA
IF YOU HAVE THE MONEY PUT A OIL PRESSURE GUAGE ON YOUR CAR. THAT SAMETHING HAPPEN TO ME SORT OF. MY CODE WAS P1259 SO, I DID THE FLOW CHART AND EVERYTHING CAME OUT FINE. I SWAP VTEC SOLENOID VALVE ASSEMBLY SAME THING HAPPEN. MY PROBLEM WAS A WORN OUT OIL PUMP. ONCE THAT WAS REPLACED EVERYTHING WAS FINE.
#354908 - 09/29/06 08:44 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!!
thats a new one for me,mines not working either and its been like that for a while now.there is no CEL and it will let me rev up to 8k but it wont kick in.ive done all the trouble shooting (except re-wiring it)even bought a new solenoid and still no worky.this is the first time ive heard of an oil pump going out.im gonna have to look into this
#9189918 - 11/17/17 08:45 AM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!! [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9235963 - 01/21/18 09:14 PM Re: vtec not engaging properly......PLEASE HELP!!!!!!!!!!!!! [Re: ]
Andada
colts jerseys
coach factory outlet
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
michael kors handbags sale
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
nfl jerseys wholesale
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
discount oakley sunglasses
buffalo bills jerseys
fitflops sale
polo ralph lauren outlet
canada goose jackets
nike huarache
seattle seahawks jerseys
jaguars jersey
Moderator:  The Mad Paki, KenNN
