#4216595 - 11/03/09 12:53 PM 1998 2.5RS running problem
allan r Offline
Loc: the land of cheese
Someone I work with has a 1998 Subaru Impreza 2.5RS with a running problem.
Symptoms:
Sometimes hesitant around town, is hesitant on the highway between speeds of around 40-60. At higher speeds like 80 car runs smooth. After driving on highway, returning to town, there is ittadic idle and hesitation. A number of times the car has died while driving.
There is an intermittent CEL, one code is for the speed sensor, when the fault is detected and the CEL turns on, the symptoms are present. If the code is cleared the car will run fine until the CEL shows up again. Sometimes, they can shut the car off for 10 minutes and restart and it will then run better.
Replaced the front speed sensor but still has the code (there are two speed sensors, the front one is on the transmission and sends a signal to the ECU for fuel/timing while the rear is by the rear propshaft to read the rear wheel speed). Front O2 sensor, fuel filter, plugs/wires, coil had also been replaced during this time and they cleaned the MAF sensor.
Make a diagnosis!
tuna on white no crust
#4216676 - 11/03/09 01:11 PM Re: 1998 2.5RS running problem [Re: allan r]
I don't think I'll be the only one to tell you to also replace the rear speed sensor.
#4216720 - 11/03/09 01:21 PM Re: 1998 2.5RS running problem [Re: LNXGUY]
allan r Offline
I questioned that myself. But does anyone know if the two speed sensors are or are not dependant on each other? Either way, the symptoms do point toward the front which, as I understand it, is the one that has input to the ECU for fuel or timing.
#4216833 - 11/03/09 01:53 PM Re: 1998 2.5RS running problem [Re: ]
OnyxEros Online   nohc
sounds to me like he has the wrong motor in it ;\)
#4216848 - 11/03/09 01:57 PM Re: 1998 2.5RS running problem [Re: ]
allan r Offline
^^ Not me, it's not my car. When they replaced the speed sensor the car ran well for a short time, maybe a week. Then it started all over. Which makes me think that something is causing the sensor to read wrong and/or it's not the true problem. What about the symptoms of restarting the car after 10 minutes and it running better? Is that long enough to, say, let an overheated fuel pump cool down?
#4217933 - 11/03/09 07:17 PM Re: 1998 2.5RS running problem [Re: allan r]
allan r Offline
Wow, so I'm reading the owner's accounts on NASIOC and the situation may have been different (the account above is from his wife who I work with). Makes for an interesting story...
Seems as though he had a CEL for the front o2 sensor (only that), and so he decided to drive with it disconnected. He says the bad o2 caused the highway hesitations, once he disconnected it it drove fine.
Then the car died while driving. Would crank but not fire and he could hear the fuel pump turn on. Towed to the dealership, who told him either the ECU flooded the engine due to the absent o2, or his crank position sensor is bad.
Then he says the dealership says the timing belt skipped, the waterpump tensioner failed due to a bad bearing. (His wife told me about this but I thought it didn't make sense to what she told me). Got the car back after that and a day later it died while driving again. It did start but with erratic idle and hesitation so they had it towed again to the stealership.
So at this point as the wife told me the dealer first said the fuel pump is shot. Then said nope, it's out of gas. (which does not make sense since it did run, though erratically, after the last incident). Dealer drives it 11 miles with fresh gas incident free. Owner picks up the car last night and it dies before it leaves the lot.
So I don't know what is truth... or what. I don't know how a failed water pump tensioner fits in unless its coincidental. She told me about the VSS code and that they replaced the sensor on the tranny, but he did not mention it at all. Another thread on NASIOC about VSS describes some of these same symptoms and says that there is another VSS in the instrument cluster.
http://forums.nasioc.com/forums/showthread.php?t=1785548&highlight=VSS quote from thread:
"The code P0500 sends the ECU into limp mode, which causes the fuel
cut and a low idle. The car then gets confused and interprets this
fuel cut and low idle as a problem with the IACV, thus causing the
P1540".
This could explains their VSS code and running problems. Right now my head hurts, any thoughts?
#9089839 - 07/27/17 02:49 AM Re: 1998 2.5RS running problem [Re: allan r]
zhengjx Offline
zhengjx20170727
burberry canada
marc jacobs sale
michael kors outlet clearance
true religion jeans sale
nike outlet online
ysl outlet online
ferragamo shoes sale
true religion outlet uk
cheap football shirts
coach outlet clearance
nfl jersey wholesale
ray ban sunglasses uk
chrome hearts outlet
louis vuitton uk
oakley sunglasses sale
louis vuitton outlet
converse shoes sale
coach factory outlet
cazal outlet
cartier watches
cheap jordans for sale
mulberry uk
burberry outlet store
pandora jewelery
adidas wings shoes
supra shoes sale
tory burch outlet online
tory burch handbags
polo outlet store
ray ban wayfarer
cheap jordans free shipping
canada goose jackets
max 90
links of london jewellery
louis vuitton borse
louis vuitton outlet stores
louis vuitton
camisetas futbol baratas
louis vuitton
jerseys wholesale
cheap replica watches
michael kors outlet store
mulberry handbags sale
nike outle
nike shoes uk
nfl jersey
kobe shoes
mizuno shoes
ralph?lauren?polo?shirts
air force 1 shoes
gucci outlet online
cheap jerseys wholesale
adidas nmd runner
pandora jewellery
swarovski jewellery
Nike Free shoes
tods outlet online
adidas uk store
true religion canada
nhl jerseys wholesale
nba jerseys wholesale
louis vuitton
thomas sabo charms
rolex orologi
ralph lauren outlet stores
louis vuitton
juicy couture tracksuit
max 1
nike air max 1
swarovski outlet
tory burch sandals
mont blanc outlet
gucci outlet online
lacoste polo
ecco outlet
louis vuitton
nike outlet store online
nike uk store
ed hardy outlet
cartier outlet
polo ralph lauren outlet
canada goose coats
sac louis vuitton pas cher
swarovski crystal
polo outlet stores
bottega veneta outlet online
ray-ban sunglasses
swarovski crystal
polo pas cher
gucci outlet online
Basketball Shoes
swarovski jewelry
gucci borse
chrome hearts online store
snapback hats
nike free running
soccer jerseys wholesale
ray-ban sunglasses
adidas nmd
burberry outlet sale
omega outlet
polo outlet
canada goose outlet store
cheap soccer jerseys
lacoste pas cher
louis vuitton
cartier watches for women
polo outlet
mulberry outlet
tory burch outlet stores
hermes outlet
rolex watches for sale
longchamp outlet online
true religion uk
nike shoes for women
hollister clothing store
foamposite shoes
louis vuitton
giuseppe zanotti shoes
nike shoes outlet
true religion jeans outlet
polo outlet
louis vuitton bags
coach handbags outlet
louis vuitton
lacoste outlet
ray bans
mulberry bags
prada sunglasses for women
tory burch outlet
birkenstock shoes
pandora bracelet
hermes birkin bag
air max 2015
air max shoes
kobe bryants shoes
louis vuitton
ralph lauren?uk
kate spade outlet online
kd shoes
gucci outlet
prada outlet online
soccer cleats
gucci outlet online
nike store uk
new balance outlet
mulberry outlet
rolex watches outlet
fitflops uk
polo outlet
cartier watches
ralph?lauren
cartier watches for sale
mac cosmetics sale
polo outlet stores
lacoste shirts
michael kors outlet stores
ray ban sunglasses wholesale
swarovski jewelry
valentino shoes
rolex outlet
michael kors factory outlet
gucci bags
salomon outlet
louis vuitton
fitflops uk
air max trainers
yeezy boost 350
gucci outlet store
ralph lauren shirts
rolex uk
fred perry polo
canada goose outlet online
birkenstock shoes
hermes outlet store
mcm backpacks
#9173985 - 10/31/17 03:26 AM Re: 1998 2.5RS running problem [Re: zhengjx]
HYst Offline
