#7760757 - 07/04/14 02:17 AM Pentax SMC-K 85mm f2.2 Soft
skierd Offline
Loc: Fairbanks, AK
Picked up an interesting new-to-me lens this week, a Pentax SMC-K 85mm f2.2 soft. "soft" of course means its a soft focus lens, and the soft focus feature is controlled by the aperture. The aperture range is only f2.2 to f5.6, with four click stops and fully variable between stops. At wide open (2.2) it's at its softest and at f5.6 it's actually fairly sharp.
http://www.bdimitrov.de/kmp/lenses/primes/short-tele/K85f2.2-Soft.html
It's a fully manual lens of course. Manual focus only of course, and no stop down coupler so you get to see the actual depth of field and softness through the viewfinder. Focus peaking seems to work "ok", not great but close enough. Metering via the green button seems accurate so far.
All shots are straight out of the camera jpgs out of a Pentax K30, going from softest (2.2) to sharpest (5.6), shot on the aperture detents at 2.2, 3.3ish, 4.5ish, and 5.6.
Bike rack at Chena Hot Springs Resort outside of Fairbanks, AK
Yellow flower, also at the Hot Springs
It definitely is going to take some getting used to, and it's certainly not an everyday lens.
#7760758 - 07/04/14 02:19 AM Re: Pentax SMC-K 85mm f2.2 Soft [Re: skierd]
skierd Offline
Loc: Fairbanks, AK
One more set, comparing it to my normal 18-135 zoom set at 88mm
K85mm @5.6
18-135 @88mm
#7760759 - 07/04/14 02:20 AM Re: Pentax SMC-K 85mm f2.2 Soft [Re: skierd]
Kierf Offline
You're going to make so much 1980s porn with that lens.
#7761039 - 07/04/14 11:06 AM Re: Pentax SMC-K 85mm f2.2 Soft [Re: Kierf]
GSParker
i just dont' get the point of these types of lenses...they just give off the appearance that you misfocused.
But then again, most of today's photos with people's phones aren't focused or even exposed well and they love them so maybe this will fit in perfectly.
#7761314 - 07/04/14 03:33 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: ]
Hope you didn't spend too much money on it.
#7761320 - 07/04/14 03:36 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: skierd]
ewraven Offline
Interesting effect. It actually looks the same as when a lens is fogged up.
#7761338 - 07/04/14 03:52 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: ewraven]
Kierf Offline
...or with petroleum jelly (Vaseline) on it.
#7761361 - 07/04/14 04:51 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: ]
It was damn near impossible to fix bad skin in portraits in film, soft focus lenses fixed that. Photoshop fixed it better (well, provided the user isn't a dumbass who thinks skin should look like porcelain).
#7761671 - 07/05/14 05:58 AM Re: Pentax SMC-K 85mm f2.2 Soft [Re: scootergeek]
ewraven Offline
Very cool. Seems like a soft focus lens must be what they used in old school movies also. Like they would use that effect anytime a hot dame appeared in the movie. I always wondered how they did that.
#7761747 - 07/05/14 09:16 AM Re: Pentax SMC-K 85mm f2.2 Soft [Re: skierd]
NOT spotch... Offline
K85mm @5.6
18-135 @88mm
Great comparison, thanks. Definitely seems to show it's potential usefulness more here.
#7761870 - 07/05/14 01:15 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: NOT spotch...]
Huggy Offline
Ummmmmmmm.... I'm seeing nothing worth anything here... but I'm not an Instagram/Facebooks photoist either...
Kevin
- Owner and Driver of Cars -
#7762186 - 07/05/14 09:06 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: Huggy]
Seems like the soft focus doesn't just blur stuff ahead and behind the plane of focus, but also shit on the plane but not in the center of the frame (somewhat). Seems like it might be possible to make use of this to isolate the subject a little more in some circumstances? Not a walkaround lens, or even something I would choose over a pricey 85~mm 1.2-1.8 prime if I could only have one, but I bet you could make some cool pics with this.
#7762191 - 07/05/14 09:15 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: NOT spotch...]
Built in hipster.
#7762563 - 07/06/14 03:39 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: NOT spotch...]
skierd Offline
Loc: Fairbanks, AK
Its still in focus, but the lens has a built in spherical abberation to cause the softness. Since it was originally intended to be a portrait lens that makes sense. If I could afford a 85mm f1.4 I would get it in a heartbeat of course...
#7762617 - 07/06/14 05:26 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: skierd]
change that to f1.2 (for Canon) and I'm with you. F'ing $$$ lenses.
#7762801 - 07/06/14 09:20 PM Re: Pentax SMC-K 85mm f2.2 Soft [Re: NOT spotch...]
Canon 85 f/1.2 - because who doesn't love lots and lots of purple fringing?
