#70963 - 01/13/05 12:50 PM b18c5 in an Si??
2000REDSI Offline
Loc: Kentucky
I was wondering who had a ITR motor swap in there Si. I was just wondering alittle bit about it. If you liked it or had dislikes about it. Maybe your mods and times. I am seriously thinking about doing this swap, just making sure this would be a good decision. Any input would be greatly appreciated. Thanks!
Daniel
Edited by 2000REDSI (01/13/05 12:52 PM)
2000 MR Honda Civic Si Vortech Equipped!! http://my.prostreetonline.com/member/2000redsi/ Rate my Ride. Thanks!!
#70964 - 01/20/05 09:50 PM Re: b18c5 in an Si??
2000REDSI Offline
Loc: Kentucky
Doesn't anyone have this swap???
#70965 - 01/20/05 10:27 PM Re: b18c5 in an Si??
Sik_intensions Offline
Loc: South Texas
$$$ I say go for it and let me know how it turns out $$$
* 2006 RR CIVIC SI * * 2000 MR CIVIC SI *
#70966 - 01/21/05 08:26 AM Re: b18c5 in an Si??
2000REDSI Offline
Loc: Kentucky
I believe i am just going to have to do it. I was looking for some numbers that way i could decide if i wanted to go turbo instead ( greddy kit). I was just looking for the most reliable HP gain, i drive mine everyday.
#70967 - 01/21/05 11:47 PM Re: b18c5 in an Si??
Loc: South Texas
Well in my opinion, a turbo kit should be much cheaper than a itr swap unless your getting a hook up.
#70968 - 01/22/05 10:47 AM Re: b18c5 in an Si??
slowpoke Offline
Loc: Tx
its not worth doing, you will only be a little bit faster, i know someone with a itr ek coupe and he runs mid 14s, si's run mid 15s just get a turbo, and build it for boost. its alot more fun that way, if you insists on getting an itr, pm mouse_si on this forum he has one.
#70969 - 01/28/05 09:12 PM Re: b18c5 in an Si??
RedHondaSi Offline
I swapped in a B18C(97 JDM Teg-R) in mine last summer.
More power than the B16A2
Got to know my car a little better
LSD
Higher Revs
Lower miles
Dislikes:
II have to swap my Passenger side inner CV Joint, it is knocking
Issues/Workarounds:
Got a Plug-N-Play wiring harness for ECU
Reused 3 my old B16A2 mounts
Had to widen my Random-Tech Cat to fit the 2.5 collector from the header
Make sure you tag/mark your electrical connections to all your sensors.. I didn;t and had thought they would only plug into one place. Boy was I wrong.
That's all I can think of for now. I did take some pics though. I could email them or post them, but I would have to resize them cause they are all about 800K's apiece.
#70970 - 01/30/05 12:26 AM Re: b18c5 in an Si??
BluSi19 Offline
Loc: Miami, Fl
could you email me the pics of the swap ultimatemusic1@aol.com
2000 EBP SI
#70971 - 03/23/05 02:07 PM Re: b18c5 in an Si??
ElectronSiR Offline
Loc: Columbia, MO
I have got the swap done in mine. it pulls a lot harder than a lightly modified Si. Uberpollo had the car before me and he had a supercharged b16 in it and then swaped the ITR in. I think its a good strong motor and up the comp and some cams....its a beast. (worth it thought...)
#70972 - 04/12/05 11:32 AM Re: b18c5 in an Si??
nova chris Offline
Loc: virgina
i know a standard greddy turbo runs anywhere from 3-4k how much does the b18c5 coast? cause Im having a hard time choosing eighter or.. my friends are telling me to just get the b16a2 turboed.. and later down the road get the b18
#70973 - 04/12/05 03:41 PM Re: b18c5 in an Si??
slowpoke Offline
Loc: Tx
a standard greddy turbo can be had for about 2500 with intercooler.
A complete b18c5 swap is going to be about 5k shipped.
#70974 - 04/13/05 05:31 AM Re: b18c5 in an Si??
137 Offline
Loc: Newsomville, CA
why even bother when he can just buy a brand new longblock and all of the other parts necessary for the swap just under 2500 and can save the money on the itr tranny since its the same as the si tranny and dump in a quaife lsd instead of a shitty stock itr lsd.
the jdm itr final drive tranny is all hype and the loss of fuel efficiency isnt even worth having it unless you like to brag about how thick your pocketbooks are.
IMO if I had the money I would build a fully blueprinted b16 turbocharged engine with a nice small dual ball bearing turbo, mild intercooler set up, no huge front mount with about 300 hp on tap and a smooth as glass power curve. I would be a happy camper. To make power with a b16 is easy turbocharged, but to have managable streetable power is a bit harder to obtain.
Wayne
#70975 - 04/13/05 07:12 PM Re: b18c5 in an Si??
nova chris Offline
Loc: virgina
so with 2,500 i can get a greddy turbo kit? does anyone know a good site i can order it off of, and how much would a shop as for in terms of labor to install the kit?
#70976 - 01/08/06 03:17 PM Re: b18c5 in an Si??
RyCeRoCkEtZ Offline
*back from the dead*
I'm considering to get a Type R swap for my Si, but as far as passing emissions, would there any problems? I'm from CA so smogging and stuff are going to be a pain in the ass. And since the swap doesnt contain the VIN number on the tranny, is it possible to place the vin number on the swap just to avoid trouble when cops pulls me over? And last but not least, is a BAR sticker really necessary???
'08 TYB YZF R6 - 02-12-08
fAsT cAr aRe fOr dRaG rAcInG
fAsT dRiVeR aRe foR aUtOcRoSs
#70977 - 01/29/06 01:59 AM Re: b18c5 in an Si??
RyCeRoCkEtZ Offline
#70978 - 02/01/06 12:52 PM Re: b18c5 in an Si??
killaj12 Offline
Loc: somewhere
i was interested in this swap too ...
but do u need new motor mounts/ axles/ ecu etc ?
i drive an em1 btw ...
i know i can use the b16 tranny ...
if its just the longblock i need, i think im gonna have this done soon
also, isnt it bad to run boost w/o strengthening the internals ?
unless u plan to run like ... only 5 lbs of boost ... ?
"i think of crime, when im in a New York state of mind" -Nas
#70979 - 02/01/06 03:41 PM Re: b18c5 in an Si??
HCivic02 Offline
Loc: CA
As long as you get a 00 or 01(or 99 if you have a 99si) USDM ITR motor you will be legally fine. After you get it swapped take your car to a smog ref and have them ref your car and you will be LEGAL
Remember, motor has to be the same year or newer to be swapped and refd legal in CA. So....im not haha
First off, I would just get the short block and put the b16 head on instead and save a bit of money...
You should only need a new rear mount for the b18. You would probably want to get a chipped p28 or something anyway and get you car tuned at the same time as the stock b16 would run you a bit lean.
If you are going to run boost I would not be using a b18c5 motor but rather a b18c1 or keep your b16. Stock motors are good up until around 350whp...which is around 12 or so psi.
Edited by HCivic02 (02/01/06 03:42 PM)
Chris
06' Evo IX - E85@29psi
13' FRS
#70980 - 02/02/06 07:30 AM Re: b18c5 in an Si??
RyCeRoCkEtZ Offline
Thanks man, but do you have to get a BAR Sticker in order for the swap to be legit? I was thinking of swapping the VIN number from the stock si and place it on the swap.
#70981 - 02/06/06 10:09 PM Re: b18c5 in an Si??
cobyk Offline
Loc: texas
definately worth doing. that's exactly what i have, only its a b18c, the jdm one. very fun car, especially paired up with my teins. nothing is better than going all motor. such a good motor to start your modding or just leave it stock like me. well almost stock. lol either way it is lots of fun
It's gonna be the biggest thing to hit these little kids. Bigger than guns. Bigger than cigarettes.
#70982 - 09/15/06 10:51 PM Re: b18c5 in an Si??
RyCeRoCkEtZ Offline
Back from the dead again
Well I finally got the USDM B18C5 Motor, the only thing I'm really concerned about is the ECU. I was told that you cannot use the USDM ITR P73 Ecu cause of the immobilizer. Is there any other way around in order to use the original usdm type r ecu?
#70983 - 09/21/06 09:34 AM Re: b18c5 in an Si??
dansred2000si Offline
Loc: El Paso, Texas
I say get yourself a B18 block build it up with internals, piece a turbo kit together, slap on your B16A2 head, get a good engine management system and a good tune and you will be good to go!!!!!! cost can be about the same as a ITR motor swap but you will have more hp and more fun doing it!!!!!!!
1995 GSR **under construction**
2000Si/Champ White/Gram Lights SOLD
LS/VTEC GT3076R Turbo[/color] *Under construction*
B18A1|CP's81.5mm|Eagle|ACL|Moroso|Cometic hg|Hasport|ARP|B16A head|
GSR cams|BDL cam gears|Supertech valvetrain|Vic X|RLD Ramhorn mani|3"DP|
Tial44mm WG|GT3076R .82a/r|Apexi IC|HKS SSQ BOV|HONDATA S300|ACT 6puck|
#70984 - 09/21/06 03:55 PM Re: b18c5 in an Si??
RyCeRoCkEtZ Offline
it was a deal i couldnt pass on
#70985 - 10/06/06 04:07 AM Re: b18c5 in an Si??
00CivicSI-R Offline
Loc: westchester county, NY
Juno aim: iamyatypema
#1012864 - 02/07/07 12:28 PM Re: b18c5 in an Si?? [Re: 00CivicSI-R]
jwyoung Offline
Loc: Ca, USA
you got the full engine? head and block? how much did you pay for that beast?
00' E95P Si 178whp, 122tq on 89 octane - B16 all motor
#1025845 - 02/10/07 10:54 PM Re: b18c5 in an Si?? [Re: jwyoung]
RyCeRoCkEtZ Offline
yeah its off of my friends '01 ITR b4 he trashed it. He claimed insurance, basically covered everything, bought the car back and i took the motor.
#1026168 - 02/11/07 02:05 AM Re: b18c5 in an Si?? [Re: 2000REDSI]
SiRed Offline
Loc: Cruising the South Bay Area
[color:#FF0000][/color] Yo gee; if you have a B16A2 in your car, just swap the cams for CTR cams, and get retainers for the head. You'll probably be faster than the actual ITR...Look into it so you can put the extra money somewhere else. Or you could just get a B20B Long block. Hella tourque from my point of view. You save alot of money too. B20 bottom with a B16 head...Shiiiiiiiiiiiiiiiiiiiiiiit
Edited by SiRed (02/11/07 02:15 AM)
2.0 Turbo A.K.A Frankenstein
B20B bottom w/16 head ( Built to last)
Boost creep from 7 all the way to 11.53 p.s.i
270 whp / 217.8 torque @ 7250 rpm
http://www.myspace.com/picolemon
Moderator:  Slurp56, The Mad Paki
