#7033418 - 04/24/13 09:07 PM
Re: Sit-ups are kicking my ass...literally.
[Re: Silock]
dirtyS13drifta
dirtyS13drifta
I'll agree, most ab routines can. I'll say this. Weighted you can always go lighter, like most weights. And focus on form.
Leg lifts there's no real "lighter".
#7033913 - 04/25/13 08:03 AM
Lost^
Lost^
Get an exercise ball to do ab exercises, gets you off the ground and easier on the lower back I find.
#7034122 - 04/25/13 09:52 AM
[Re: 98V-TeC]
137
Loc: Newsomville, CA
Toe to bar raises are no fucking joke. I first attempted them about 6 months ago, it was laughable. I had to work my way up...it took a while, I still suck at them overall.
all you have to do is hollow body rocks, learn how to properly engage the core before doing the leg lift.
http://gymnasticswod.com/content/hollow-body
Wayne
#7034251 - 04/25/13 10:30 AM
dirtyS13drifta
dirtyS13drifta
I can't do more than like 12 hanging leg raises per set... But I take my ankles up to my hands... I said I do 50...not all at once. That said, I can't say for sure everything is perfect...I do know my abs are burning bad enough to where I can't stand straight when I come down. I do bitch raises too...I use loops.
Not saying it's 100%, but Lower Abdominal Myth
It is widely believed the lower abs are exercised during the leg raise or other hip flexor exercises. However, it can be misleading to judge the mechanics of an exercise based on localized muscular fatigue. The primary muscle used in hip flexion is actually the Iliopsoas one of many hip flexors. The Iliopsoas, particularly the Psoas portion, happens to lie deep below the lower portion of the Rectus Abdominous. During the leg raise, the entire abdominal musculature isometrically contracts (contracts with no significant movement) to:
Posture the spine and pelvis Supports the weight of the lower body so the lumbar spine does not hyperextend excessively Maintains optimal biomechanics of the Iliopsoas Hips are kept from prematurely flexing if the lumbar spine and pelvis does not hyperextend excessively Iliopsoas can contract more forcefully in a relatively slight stretched position Bent knee (and hip) sit-ups actually place Iliopsoas at a mechanical disadvantage Counteracts Iliopsoas's pull on spine Many people with weak abdominal muscles are not able to perform hip flexor exercises without acute lower back pain or discomfort The combination of the local muscular fatigue, or a burning sensation from the isometrically contracted abdominal muscles, and from the working hip flexors produces fatigue in the pelvis area which we mistakenly interpret as the lower portion of the Rectus Abdominous being exercised. In movements where the Rectus Abdominous does Isotonically contract (contracts with movement), it flexes the spine by contracting the entire muscle from origin to insertion. The spine is not significantly flexed during the leg raise. Incidentally, both the spine and hip flexes during the full range op motion Sit Up and Leg Hip Raise. See Spot Reduction Myth above. http://www.exrx.net/WeightTraining/Myths.html
#7034259 - 04/25/13 10:32 AM
[Re: 137]
dirtyS13drifta
dirtyS13drifta
The hollow body highlights OPs issue. A full sit-up your butt receives all the pressure, which makes it at least decently a hip exercises. If your lower back leaves whatever your crunching/pressing against, then your hips are used. If you keep your belly button pushed against it(and thus the lower back "pinned" down), you'll be working your actual abdominals much more.
If he's got already tight flexors, doing more workout here won't help his lower back, but could aggravate it.
#7034323 - 04/25/13 10:59 AM
[Re: 137]
dirtyS13drifta
dirtyS13drifta
Also the Hollow body encourages active recruitment of the transversus adbominus. Those are your "sucking in" muscles. This is what actually gives one a flatter midsection as well, it provide no definition, but helps you limit the "gut" effect even for those with 6-packs. Yoga beleives that working the muscles is good for digestion as it literally can compress your internal abdomen.
There is also the theory that this muscles helps a lot with core stabilization for lifting big(though it's still being debated).
#7055926 - 05/07/13 07:12 PM
98V-TeC
Loc: Denver, CO
Wayne isn't completely clueless folks!
I"ve been doing the hollow body exercise and I'm liking it. It says to aim to hold for 3 min...no fucking chance, I can get a minute max. I've just been doing reps not to work my way up. It's good shit, really feeling it in da coreeeeee.
#7057012 - 05/08/13 10:16 AM
137
It's not a theory, it's fact. If my core were stronger, I wouldn't use a belt and I wouldn't noodle forward on these front squats.
http://www.youtube.com/watch?v=66Mm3uP6sGk
I now specifically am rotating front squats, and an ab circuit into my training. to correct this, I should be front squatting 300lbs by now and I am barely above 250.
Wayne
#7057307 - 05/08/13 11:51 AM
[Re: 137]
dirtyS13drifta
dirtyS13drifta
It's not a theory, it's fact. If my core were stronger, I wouldn't use a belt and I wouldn't noodle forward on these front squats. http://www.youtube.com/watch?v=66Mm3uP6sGkI now specifically am rotating front squats, and an ab circuit into my training. to correct this, I should be front squatting 300lbs by now and I am barely above 250. Some might argue that's your normal abs, rather than the traverse(girdle muscles).
#7057554 - 05/08/13 01:24 PM
dirtyS13drifta
dirtyS13drifta
everything will be working for that exercise. Well last I'd seen the jury was still out on girdle muscles vs abs. But who needs sciense, we've got csi on the case!
#7057612 - 05/08/13 01:51 PM
137
Calm down bro, do you do front squats. I'd like to hear your opinion rather than google science on what you feel is working and not working on this particular lift.
I think it's great that everyone has all of their own input from shit they read, but who is actually doing stuff and feels said things are being applied, not applied?
imo if you're going to give advice on something in here at least have some personal experience involved with the myth debunking.
Wayne
#7057712 - 05/08/13 02:25 PM
dirtyS13drifta
dirtyS13drifta
I'm not debunking any myth. I'm merely commenting on the science I've read. If you've got links, fine. Otherwise bro-science. Hey, I work my girdles too, maybe it's aesthetics, maybe it's good for the back, maybe it helps with other lifts. But I won't claim those things as facts.
Furthermore, OP isn't likely to be doing front squats anytime soon. I don't know why we're discussing them. I was actually agreeing that the hollow body is probably a good idea for one's core, probably much better than leg-lifts or weighted declinces, Regardless of big lifts(which again don't even matter for OP's goals).
And not listening to science is how you end up with advice like leg lifts being the best ab exercises when they're actually hips exercises...
Moderator: Silock, The Mad Paki
