#6994111 - 04/05/1307:45 AMInstalled intake manifold on 03 PTGT now cranks but no start
ScottsWeedKillerScottsWeedKiller
Certified Dude Beater Offer
Maybe some ex SRT4 guys can help with this one.
I installed a plastic intake manifold to replace my aluminum version on my 03 PT GT, its supposed to be worth ~9whp. Also replaced the injectors with "stage 1", the only other non stock part is the MAP sensor that was attached to the manifold.
Now it turns over fine but won't even sputter. Sounds like the fuel pump powers up and I pulled a plug, it seemed to be firing ok. The plug was dry as a bone too. Leads me to believe I don't have fuel.
Any suggestions? The only code I get is 0522, oil pressure sensor voltage low. I'm not sure this would cause a no start though. (the sensors go bad fairly often on these)
You don't need a tune to go along with those stage I injectors?
#6996327 - 04/06/1303:54 PMRe: Installed intake manifold on 03 PTGT now cranks but no start
[Re: ScottsWeedKiller]
I pissed around with it this afternoon and sensors, plugs, fuses and relays checked out. Reset the pcm with no luck either. So I went ahead and swapped back to the stock fuel rail/injectors and it fired right up.
