#6590700 - 09/16/12 08:38 PM
[Re: UglyValiant]
ReplicaR
Cometic MLS for head gasket. OEM for everything else. I've got a set of copper header gaskets that I've had for years, maybe I'll use those. I'll talk to the engine builder. I'm using stage 8 stuff because I've heard that BBK headers tend to loosen the bolts up. I really don't like how stiff the e clip is on those.
#6606073 - 09/23/12 11:03 PM
[Re: beerslurpy]
ReplicaR
Less heat, less weight, less parts to break, and I don't like turbo cars.
#6608559 - 09/25/12 12:28 AM
[Re: ReplicaR]
ReplicaR
Droppped the car off at the shop. No turning back now
#6610132 - 09/25/12 07:34 PM
[Re: hustler]
ReplicaR
Yesterday I couldn't really sleep. I kept tossing and turning, pondering if I have ruined my car, what if the cam was too big, what if it will get on my nerves by being too much to deal with in traffic. Don't forget, I've ruined a car before with bad engine work on a small budget. This time things are a little different. I'm having a shop do this, which is immaculate with their work, fit and finish. I've spent a very significant amount on parts. All I have to do now is wait. I'm still hoping to see at least 350whp
#6610510 - 09/25/12 10:42 PM
[Re: ReplicaR]
UglyValiant
Yesterday I couldn't really sleep. I kept tossing and turning, pondering if I have ruined my car, what if the cam was too big, what if it will get on my nerves by being too much to deal with in traffic. meh...looking over the parts, nothing you've got is *really radical* so I wouldn't worry too much. Is the cam big? Yep! But being designed for fuel injection, and having aforementioned Fuel injection as well as extra cubic inches really will obviate your concerns.
-it'll start good. -it'll run good -extra cubic inches (heck, even stock cubed), you'll have more than enough low-end for satisfying driving. -fuel injection will help it run pretty well at low rpm's, even *if* the cam is "too big".
It's not like you're running an AFR 225 headed 302 with a 250 @ .050 cam with narrow 106 LSA, big headers, and an auto transmission.
Say you're cam is "too big" though...swapping 'em isn't the end of the world; or you could use it as an excuse to up the gears (though, not a huge fan of that, since THAT is what makes a car seem less streetable to me). With the deep OD of your car though, hwy cruising would still be fine, and city driving may become easier with shorter gears.
But, it appears to me that this is a good balanced engine that will sacrifice a little low-end that the extra cubes will help considerably (so loss of low-end should really be minimal), that will have a very strong mid/upper ranges and pull much longer than you can imagine...
#6617140 - 09/28/12 03:29 PM
[Re: ReplicaR]
SpcNA[ZX]
Loc: Omaha, Nebraska
May I suggest a set of these for your header bolts? https://www.youtube.com/watch?v=mgwmuZuJ02I
I use them on my intake bolts, exhaust studs, flywheel bolts..... Essentially everything I never want to come undone and they work awesome; I put them on ANYTHING that I don't want to come loose and have replaced almost every lockwasher on the car with them.
Edited by SpcNA[ZX] (09/28/12 03:30 PM)
'92 Galant VR-4 '93 Nissan 300ZX
#6617472 - 09/28/12 07:19 PM
[Re: SpcNA[ZX]]
ReplicaR
Looks like an interesting system. Where does one purchase something like that?
#6620871 - 10/01/12 12:24 PM
[Re: hustler]
ReplicaR
The shop is starting on it today. ET completion is two weeks. Meanwhile I'm driving shop loaner, which is an all manual yellow Focus... with hood pins.
#6635266 - 10/08/12 06:20 PM
[Re: SpcNA[ZX]]
ReplicaR
#6635297 - 10/08/12 06:36 PM
[Re: ReplicaR]
madmatt
yesssss
#6636485 - 10/09/12 10:16 AM
[Re: Impulsive]
UglyValiant
To me it's strikes me as terrific that the chassis of this particular car has been so thoroughly gone through and modified to the owner's personal taste; in many respects, it almost seemed as if the engine was the lagging feature, if anything, on this car...odd given that when new, it was certainly one of the most important, if not the key feature of this era mustang.
That it will hit the road with such a well-thought out engine, high performance yet tractable, will in my mind make it like a new car to the owner almost...it's amazing what a thoroughly revamped engine can do for a vehicle, especially when so far from stock.
#6657807 - 10/19/12 11:25 AM
[Re: UglyValiant]
hustler
car done yet?
#6657893 - 10/19/12 11:48 AM
[Re: hustler]
ReplicaR
Nope. Gonna call the shop today to see where they are at. Last I've checked, they broke heater core trying to pull the hose off it, and the Innovators West balancer did not line up with the other accessories.
#6658497 - 10/19/12 03:54 PM
[Re: madmatt]
ReplicaR
I've changed it myself about two years back. Took me 11 hours by myself, but I was also changing the AC condenser at the same time. I remember how much fun it was. Yeah, they are going to replace it.
Bit of an update. They finished cleaning the engine bay, so the motor should be in the car this by the end of the day. From there on they will cut 1 inch from exhaust, because engine is set back an inch, move the battery in the trunk, replace fuel pump, install gauges and dimmer switch, install larger fan, move the overflow bottle to the side where the battery used to be, clean the whole mess up, and give it a small tune to make it driveable. Then I will drive it for couple of weeks breaking it in, and give it back for a tune.
#6659053 - 10/19/12 09:39 PM
[Re: ReplicaR]
ReplicaR
Couple of more images.
Clean engine bay
Fully dressed engine.
The images are small, they were taken by someone else.
#6669568 - 10/24/12 06:16 PM
[Re: ReplicaR]
ReplicaR
Motor is in the car, and set back an inch as off this morning. Probably will get the car back next week, or so I hope. Then break in period, and give it back for tune.
#6678912 - 10/29/12 06:52 PM
[Re: PsychoEBPSiR]
ReplicaR
They almost fired it up friday, but some other stuff got in the way. A lot of custom work being done while the car is there.
#6679844 - 10/30/12 09:38 AM
[Re: ReplicaR]
madmatt
$$$ custom
#6680178 - 10/30/12 11:43 AM
[Re: madmatt]
ReplicaR
Car was fired up last night, but did not idle. The shop owner is going to throw a chip in it today, give it a slight tune, check the timing and such, and see how it goes.
#6681785 - 10/30/12 11:11 PM
[Re: Impulsive]
ReplicaR
I'm getting anxious just to have my damn car back.
#6682034 - 10/31/12 08:03 AM
[Re: ReplicaR]
OnyxEros
I wish you the best of luck and I want it to turn out to be awesome but i personally trust most guys to take as much care assembling as I would/have
I do hope your builder is taking care of you and treating you right and you get a kick ass motor back
#6695299 - 11/06/12 01:08 PM
[Re: hustler]
ReplicaR
Everything is buttoned up, and it has been fired up, but it keeps cutting out almost immediately after firing up. TPS readings are all out of whack. They are working on it still. I've looked into this issue on my own, and looks like a bad ground.
