#6470140 - 07/20/12 02:04 PM
So, I'm finally building an engine... *new dyno # 2/7/2014*
ReplicaR
#6470197 - 07/20/12 02:31 PM
[Re: FCobra94]
ReplicaR
#6470218 - 07/20/12 02:40 PM
[Re: ReplicaR]
LowTech302
#6470346 - 07/20/12 03:33 PM
[Re: LowTech302]
hustler
yeah watch out you will want a big windsor soon you should check out this american iron video of paul brown with a n/a 5.7 ex cup motor.
#6470356 - 07/20/12 03:39 PM
[Re: hustler]
ReplicaR
#6470461 - 07/20/12 04:22 PM
[Re: UglyValiant]
ReplicaR
#6470592 - 07/20/12 05:21 PM
[Re: ReplicaR]
hustler
That will be a healthy motor and the 185's are a good match for a naturally aspirated 331. a 205 or a 210 edel vic jr head would have been a good match too, that thing will make power. What intake are you going to use? Don't say stock either stock intake manifold is a cork. I finally gave in and upgraded to a 96 exploder intake after i grabbed some gt40 heads. For your motor I would look at an Edel Performer RPM 2 intake. That is a great midrange rpm intake and would make the most usable power throughout the powerband on that n/a 331. I had a systemax intake which was similar to the vortech/saleen intake and i just felt like the runners were so big that the velocity suffered with my stock 302 and the e7 heads which were so small. My HP went up by 40+ with the e303 cam but torque dropped considerably and felt like a dud off the line. it definitely ran better with the blower, but the e7 heads and my 19lb injectors with FMU still held me back to 340whp @ 10psi. Not very impressive. would guess you will need 36lb injectors for your new setup. 24lb'ers might just be a tad small.
#6470669 - 07/20/12 06:17 PM
[Re: hustler]
ReplicaR
#6471589 - 07/21/12 01:33 PM
[Re: ScottsWeedKiller]
GB
Sharesies!
Loc: Craigslist
#6472215 - 07/21/12 11:30 PM
[Re: ReplicaR]
UglyValiant
I'd like to see 350whp or so, but who knows how much I'll really get. Well, the parts are there...it'll depend on the cam you select. For a fuel-injected engine w/ this many cubic inches, I'd look to something in the 228-234 @.050 range (intake side) w/ a 112-114 LSA for a hyd. roller. You'll want to spin this thing to 6500 rpm for those cubes to make the target practice.
#6472446 - 07/22/12 09:39 AM
[Re: UglyValiant]
ReplicaR
#6503513 - 08/05/12 05:02 AM
[Re: UglyValiant]
ReplicaR
#6521898 - 08/13/12 01:06 PM
[Re: ReplicaR]
hustler
Love watching a new build happen just got back from vacation, so will keep checking your progress.
#6545578 - 08/24/12 01:11 AM
[Re: hustler]
ReplicaR
#6546581 - 08/24/12 02:56 PM
[Re: hustler]
ReplicaR
#6548242 - 08/25/12 04:34 PM
[Re: GB]
ReplicaR
#6571790 - 09/06/12 09:59 PM
[Re: ReplicaR]
ReplicaR
#6576897 - 09/10/12 01:39 AM
ReplicaR
#6577353 - 09/10/12 11:02 AM
[Re: ReplicaR]
hustler
Some nice additions The Innovators West is a nice piece.
#6577737 - 09/10/12 03:55 PM
[Re: hustler]
ReplicaR
#6577759 - 09/10/12 04:20 PM
[Re: ReplicaR]
hustler
An ATI came with the race shortblock I had, very nice unit, I ended up using my motorsport piece since it had more material and figured it would hold up better with the large blower crank pulley after I had it double keyed. It had a removable counterweight as well. Romac's are good as well I'm told. Funny part is i was looking for something cheap to go back on my stock shortblock so I bought an ebay special old stock Lunati unit for around 80 dollars. Seems to be working so far
#6589802 - 09/16/12 11:36 AM
[Re: hustler]
ReplicaR
Stage 8 bolts for headers.
#6590357 - 09/16/12 05:33 PM
[Re: PsychoEBPSiR]
ReplicaR
