#6212361 - 03/15/12 09:27 PM
Re: Gauging interest: SVA want to help turbo the 4Runner?
[Re: No Runners]
GaragePC
Loc: the 6th borough, ny
Gonna rebuild it myself and will rotate the center section accordingly (>30° from horizontal)
yessssssssss good to hear
find the pdf manual for your model and read up, its all pretty simple.
#6286529 - 04/18/12 08:10 AM
[Re: No Runners]
ElectronVTEC2
I bought the rebuild kit off of ebay and the guy emailed me the manual in pdf format. I need to buy really big snap ring pliers, but the auto parts stores don't have anything large enough. I'm going to Harbor Freight today to pick up their pliers set. I'll post pics as I progress.
Edit: Also, while everything is off I was thinking about restricting the oil inlet.
What are your thoughts on filling the oil feed fitting on the turbo with JB Weld and then drilling it out with a 1/16th bit? Too ghetto?
If it were actual weld, I'd give you the thumbs up. JBW in that environment, knowing where it's going if it fails? I wouldn't. They sell fittings that haven't been drilled for just the purpose you're talking about though. Not sure where, but I've seen lots of the Holset DSM'ers use them.
2011 Edge (Wife's appliance) EVO IX MR, minor mods
#6286927 - 04/18/12 10:54 AM
[Re: kyden]
SamuraiSam
Loc: Bellingham, WA
The directions may say within 30° but try to get it as close to straight down as possible.
Holsets, at least the HX35 which is similar to the HY, are more like $100 to rebuild and way easier than a Garrett. I would also take Denmah's advice and restrict it, even if it's only down to 040 it's better than no restrictor when the engine is cold and oil is really thick: Not using a restrictor like this can blow your seals. You should be able to find any fitting and restrictor you need @ atpturbo.com
#6286995 - 04/18/12 11:30 AM
[Re: SamuraiSam]
No Runners
Loc: dirty jersey
Rather than go to the store for a third time trying to get a decent large snap ring plier I used a small pry bar to jimmy the giant snap ring out. Mission accomplished. I'll try to finish the rest in a bit.
#6287019 - 04/18/12 11:39 AM
[Re: No Runners]
SamuraiSam
Loc: Bellingham, WA
Does it have a GIANT snap-ring holding the compressor housing on? Try a pair of big Vice-Grips, especially for reinstallation. Then put another pair of small vice-grips on the adjuster dial of the big vice grips, and slowly twist counter-clockwise to install.
#6287805 - 04/18/12 03:57 PM
[Re: No Runners]
No Runners
Loc: dirty jersey
I got her all apart, but fuck my life I can't get the tiny snap rings back into the center section. Calling it a wrap for the day.
Also, the turbine blades look great, but the shaft has some scoring on it. I'll post pics of everything in a bit.
After taking the turbo apart and looking at the oil passages in the cartridge I can see how mounting the oil feed/drain horizontally wouldn't allow for proper flow. Live and learn.
Edited by Slow Runner (04/18/12 08:17 PM)
#6294298 - 04/21/12 10:18 PM
[Re: No Runners]
theLoon
Loc: MN
Could try a bike shop. Or McMaster Carr. Just think, you could start a sideline business rebuilding Holsets...
 I'm a badge whore
#6294846 - 04/22/12 12:28 PM
[Re: theLoon]
SamuraiSam
Loc: Bellingham, WA
I couldn't help you. I have a 6 plier tray from the Snap-on man that probably cost me a weeks wages, but I've been able to work with some really tiny snap-rings. T25, T28 are a lot worse than that holset.
Edited by SamuraiSam (04/22/12 12:28 PM)
#6301590 - 04/25/12 03:53 PM
[Re: No Runners]
GaragePC
i'd hack that cclip on there with a hand full of Picks and gloves. start at one end and work it around ITS A HOLSET
#6307980 - 04/28/12 06:13 PM
[Re: GaragePC]
GaragePC
go go !
#6313751 - 05/01/12 11:10 AM
[Re: GaragePC]
NVMYMPGZ
Loc: White Plains, NY
How you makin out OP?
#6329101 - 05/08/12 03:29 PM
[Re: rslijetgold]
NVMYMPGZ
All things in their being are good for something.
seeee. even the botts want to see this thing through.
#6355857 - 05/21/12 11:39 PM
[Re: No Runners]
theLoon
Loc: MN
Congratulations dude!
 I'm a badge whore
#6480933 - 07/25/12 10:05 PM
[Re: No Runners]
aerosaaber
Loc: Pittsfield, MA
progress, that's what we like to hear about.
2006 Subaru WRX Wagon (I'm back on boost!) 2001 Subaru Legacy Outback Wagon Limited (sold) 1994 Saab 9000 Aero (gone) http://www.saabrally.com
#6481001 - 07/25/12 10:38 PM
[Re: aerosaaber]
It's not going to spin super easy without oil in there... Don't worry about it.
#6481067 - 07/25/12 11:36 PM
NVMYMPGZ
Don't forget to prime the oil system!
#6491307 - 07/31/12 09:29 AM
[Re: No Runners]
No Runners
Loc: dirty jersey
Here she is all back together.
Old oil inlet New oil inlet (restricted)
#6491375 - 07/31/12 09:50 AM
[Re: No Runners]
What's that restrictor spec out at? It looks awful small even compared to what's on my TDI.
