Page 1 of 2 12>
#6087911 - 01/25/12 09:00 AM Homeowners: Remove Mixing Valve?
SuPeR-MaRiO Offline
Loc: Toronto, Ontario
So recently I had an issue where the water in my home was only luke warm. I had a Enbridge technician come in to check the tank. He said the tank was full of hot water and that the fault is that of my mixing valve.
For those that don't know what it is, its a valve connected outside of your water heater that adds cold water to the hot water that leaves the tank. There is a code that requires that these valves are in place to prevent people (children, elderly) from burning themselves.
Prior to this incident I never knew about this valve and always wondered why I wouldn't get super hot water out of the pipes (for washing dishes and whatnot).
Anyway, I was thinking of not replacing the valve and simply removing it and adding copper pipe in its place.
Has anyone done this before? Do older homes have these installed as well? This is not part of the water heater, so Enbridge is not responsible for it.
I think the only consequence is that some one could potentially burn themselves or even sue you for burning themselves in your home.
#6087926 - 01/25/12 09:06 AM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
oranjizz Offline
Loc: Ontario, Canada, etc.
How much is the valve vs. straight pipe?
#6087933 - 01/25/12 09:09 AM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
The Postman Offline
A-List Member also The Man
I had one in my old house and I hated the damn thing. No matter how high I turned the gas up on my tank, they water really never got that hot. I also had to replace it after a few years because the mechanism inside became clogged and was slowing the flow of water.
My new house came with one due to this code, but I had it totally removed. I dont have any kids or old people living here. Now, I just keep that hot water tanks temperature dial at the "recommended" setting and the water gets plenty warm.
I kept the valve just in case I ever have to replace it.
No to be rid of these damn low flow taps and toilets.
#6087937 - 01/25/12 09:10 AM Re: Homeowners: Remove Mixing Valve? [Re: oranjizz]
spd-dmn Offline
typically you can also set the hot water temperature on the water heater itself
if you get rid of the mixing valve i highly suggest turning the heat down
#6087954 - 01/25/12 09:18 AM Re: Homeowners: Remove Mixing Valve? [Re: oranjizz]
SuPeR-MaRiO Offline
The valves are about $90 +tax at Home Depot vs. about a foot or so of copper pipe
#6087960 - 01/25/12 09:21 AM Re: Homeowners: Remove Mixing Valve? [Re: The Postman]
SuPeR-MaRiO Offline
Same here
This is what has happened to my now.
#6087963 - 01/25/12 09:23 AM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
Pretty sure my tank doesn't have a mixing valve (it's a new tank, but home is built in '71). I control the temp from the tank itself.
#6087968 - 01/25/12 09:24 AM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
The Postman Offline
Then get rid of it.
It took me a few adjustments of the temperature control on my tank to find the sweet spot that keeps the water hot, but not scalding. It just so happens to be the big green recommend number on the dial.
I had a home inspector do my 1-year and he didnt even notice that it wasnt there.
#6087971 - 01/25/12 09:25 AM Re: Homeowners: Remove Mixing Valve? [Re: spd-dmn]
SuPeR-MaRiO Offline
Yes defintely
#6087981 - 01/25/12 09:29 AM Re: Homeowners: Remove Mixing Valve? [Re: Risky Business]
SuPeR-MaRiO Offline
All tanks will have the temperature control on the tank, this valve is connected outside of the tank, see where the yellow tag is (not my tank)
Some valves are adjustable, some are not.
#6088002 - 01/25/12 09:38 AM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
if you have some mechanical aptitude/can solder you can diy pretty easily.
health and safety bods had this stuff made mandatory. though you should still be able to get decently hot water at the taps/shower. not melt your skin hot but hot.
#6088042 - 01/25/12 09:48 AM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
I don't have that, mine is just straight cold water line into the tank and a hot water line coming out.
#6088058 - 01/25/12 09:51 AM Re: Homeowners: Remove Mixing Valve? [Re: Risky Business]
Eddie_82 Offline
miataist
Loc: Ca�ada
Moi aussi.
Old houses FTW
#6088310 - 01/25/12 11:18 AM Re: Homeowners: Remove Mixing Valve? [Re: Eddie_82]
phoenixrage Offline
Mixing Valve failure? buy new house!
#6088318 - 01/25/12 11:19 AM Re: Homeowners: Remove Mixing Valve? [Re: phoenixrage]
Hatorade Offline
pheggit
I like that!
'07 997.1 GT3
'08 E90 M3
'11 E90 d
#6088650 - 01/25/12 01:12 PM Re: Homeowners: Remove Mixing Valve? [Re: Hatorade]
SW20_MR2 Offline
Loc: Markham, Ontario, Canada
Our mixing valve broke down last year (only 4 years old). The Direct Energy guy said I could just remove it if I wanted and put a pipe, but I opted to replace it cause I don't want our son burning himself when he's old enough to open taps himself.
1991 MR2 Turbo aka "The Myth"...does it really exist?
2006 Mazda3 Sport aka "Reality"...it really does exist...
#6088768 - 01/25/12 02:03 PM Re: Homeowners: Remove Mixing Valve? [Re: SW20_MR2]
LNXGUY Moderator Offline
He'll only burn himself once.
#6088830 - 01/25/12 02:25 PM Re: Homeowners: Remove Mixing Valve? [Re: LNXGUY]
Eddie_82 Offline
miataist
Loc: Ca�ada
Hot water can burn in less than three seconds.
Warning, Spoiler:
#6089049 - 01/25/12 03:55 PM Re: Homeowners: Remove Mixing Valve? [Re: Eddie_82]
Wildout Offline
I have the mixing valve in a new home (2010 build) and my water gets plenty hot where I can't turn it past 3/4 in the shower or it gets really really hot. Sounds more like a defective unit.
#6089087 - 01/25/12 04:09 PM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
robbbby Offline
master electrician
Loc: Canada
remove mixing valve and adjust temperature on tank to your liking.
#6089096 - 01/25/12 04:14 PM Re: Homeowners: Remove Mixing Valve? [Re: SW20_MR2]
Just remove it and adjust the tank to the max heat you want, you will save on heating costs and it won't get hot enough to burn you. That's what most parents do
#6089227 - 01/25/12 05:00 PM Re: Homeowners: Remove Mixing Valve? [Re: SW20_MR2]
its amazing how you survived childhood! ;\)
#6089255 - 01/25/12 05:13 PM Re: Homeowners: Remove Mixing Valve? [Re: Euphoricuck]
Eddie_82 Offline
miataist
Loc: Ca�ada
I see our resident parents have decided to chime on child rearing.
#6089284 - 01/25/12 05:25 PM Re: Homeowners: Remove Mixing Valve? [Re: Eddie_82]
loudsubz Offline
Lol at the mass scaldings before they had the mixing valves
Like mentioned, turn down the water tank temp
#6089503 - 01/25/12 07:12 PM Re: Homeowners: Remove Mixing Valve? [Re: Risky Business]
SW20_MR2 Offline
We're talking about a $70 part here so I'm not gonna stress to much about replacing it. I'm against the total babying of kids today but I'll take some precautions against stuff to prevent easily avoidable injuries.
The Direct Energy guy said that you should maintain your temps a certain level to minimize bacteria growth, so you have to be careful about how low you go.
#6089796 - 01/25/12 10:33 PM Re: Homeowners: Remove Mixing Valve? [Re: SW20_MR2]
JEFFOS Offline
"you running straight pipes on that house bro?"
#6090169 - 01/26/12 08:06 AM Re: Homeowners: Remove Mixing Valve? [Re: JEFFOS]
SuPeR-MaRiO Offline
Got my pops to give me a hand as he's better at plumbing than I am. There were a few hiccups along the way but the job was done. We removed the valve and have lowered the temp in the tank. It'll take a couple of days to cool down as I had the tank cranked up.
#6090210 - 01/26/12 08:47 AM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
dilbert Offline
Loc: SW Ontario
We have one in our place(4yrs old), but it only adds cold if the hot water is too hot. I basically turned our hot water heater down just enough that when the wife is taking a shower, the cold line into the thing stays at room temperature so it's not dumping cold into the hot line.
EDIT: Anyone else fine it funny that 'Super-mario' needed help with plumbing...
Edited by dilbert (01/26/12 08:48 AM)
#6090446 - 01/26/12 10:17 AM Re: Homeowners: Remove Mixing Valve? [Re: SW20_MR2]
I think that's BS personally, but whatever. Anyway, I am pretty sure your son will learn his lesson after getting burnt once, it's not like he can get seriously hurt or something.
#6090553 - 01/26/12 10:49 AM Re: Homeowners: Remove Mixing Valve? [Re: dilbert]
SuPeR-MaRiO Offline
#6090606 - 01/26/12 11:00 AM Re: Homeowners: Remove Mixing Valve? [Re: Risky Business]
the direct energy guy is right...to a degree(hi oh). Its a small issue really and you would have to turn it down quite a bit.
the mixing valve is a better way to do it from an engineering standpoint but i would just leave the temp in a regular range.
#6091118 - 01/26/12 01:27 PM Re: Homeowners: Remove Mixing Valve? [Re: Euphoricuck]
dilbert Offline
Loc: SW Ontario
http://www.treehugger.com/green-food/is-it-safe-to-turn-down-your-water-heater-temperature.html
#6091157 - 01/26/12 01:39 PM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
phoenixrage Offline
LOL!
Guess Luigi was the real plumber.. mario was only for marketing purposes.
#6091613 - 01/26/12 03:48 PM Re: Homeowners: Remove Mixing Valve? [Re: SuPeR-MaRiO]
robbbby Offline
master electrician
Loc: Canada
lol no
#6091669 - 01/26/12 04:00 PM Re: Homeowners: Remove Mixing Valve? [Re: robbbby]
LOL days
Page 1 of 2 12>
Moderator:  c2k, LNXGUY, TheRealCSnapper, The Mad Paki
