#6038622 - 01/05/12 08:56 AM
Re: Gauging interest: SVA want to help turbo the 4Runner?
[Re: denham]
denham
Loc: Macungie
blow off valves are not needed, just adding to the cost of your budget setup.
specially with an automatic, forget about it.
Mott - www.sloppymechanics.com "I'm gonna denmah my gf tonight." LNXGUY "Denmah has the most consistently entertaining posts of any member here" - Adam G "denmah: because canada can't be the only country with a moof" - jsmonet "LOL, you really are my hero denmah. You actually do the things the rest of us dream or bullshit about." - 98_1LE
#6038640 - 01/05/12 09:04 AM
[Re: denham]
g96nt
Loc: Annapolis MD
yeah... 7psi, and auto.. just another cost you don't really need. (bov)
2000 Saab 9-5 wagon
#6038649 - 01/05/12 09:07 AM
[Re: g96nt]
ElectronVTEC2
I was thinking about that last night as well. Many people run no BOV on autos without any issue. It's common practice in the turbo Brick world.
2011 Edge (Wife's appliance) EVO IX MR, minor mods
#6038708 - 01/05/12 09:33 AM
[Re: ElectronVTEC2]
No Runners
Loc: dirty jersey
http://www.ebay.com/itm/Holset-HY35-Turb...42&cmd=ViewItem
Thoughts on this turbo? Are these just oil cooled or water and oil? Do you think I'll need an oil restrictor with this turbo?
Also adding check valves to the parts list.
Edited by SC Trojan (01/05/12 09:35 AM)
#6038724 - 01/05/12 09:39 AM
[Re: No Runners]
ElectronVTEC2
I don't know a ton about Holsets but I do know they have some pretty specific oiling requirements in terms of oil feed pressure. Beyond that, you want to give them a very large drain relative to other center housings. It is common practice in the DSM world to run a -12 drain for the HX35/HX40 Holsets. Just about every other turbo uses either a -8 or -10 drain. Nothing major but something to be aware of. You'll want to have some way to monitor oil pressure into the turbo so you can make sure you're not exceeding recommendations.
#6039429 - 01/05/12 12:52 PM
[Re: No Runners]
NVMYMPGZ
Loc: White Plains, NY
Can't I use the oil restrictor to control oil flow to the turbo? What size should the supply line be? http://bit.ly/yzkwhy
#6039486 - 01/05/12 01:09 PM
[Re: NVMYMPGZ]
ElectronVTEC2
Yea, I've seen guys weld the feed line output shut, then use drill bits to gradually drill out the weld until the oil pressure is where they want it at the input to the turbo. You can measure anywhere along the feed line to get your reading, just to be clear.
#6039577 - 01/05/12 01:41 PM
[Re: ElectronVTEC2]
Find the requirements of the turbo and find a similar factory setup. Hell, maybe the feed from a TDI will work for ya, who knows.
#6039601 - 01/05/12 01:52 PM
ElectronVTEC2
DSM feed lines are all factory-restricted as well. Good call, Bill.
#6039653 - 01/05/12 02:14 PM
[Re: ElectronVTEC2]
denham
Loc: Macungie
only buy this oil scavenge pump
http://www.ebay.com/itm/TurboWerx-Base-M...40#ht_545wt_902
all the others fail and suck.
put a check valve on your oil feed, 15psi works great.
use parker hydraulics push lok fittings for the oil return.
#6039658 - 01/05/12 02:15 PM
denham
Loc: Macungie
with whatever turbo you get, if it isnt restricted, its easy to get a ebay t2/3/4/6 feed bracket with a -4an fitting on it that is undrilled or you can drill your own hole to restrict it, .040 is a safe easy bet.
journals usually like .060 max and ball bearings more towards .030
so drilling a .040 for anything will work great.
#6039666 - 01/05/12 02:17 PM
[Re: denham]
denham
Loc: Macungie
eh im not a fan of holset but i know people have run them without issue, i would like to know how big that turbo is...
might be larger than you want.
#6039718 - 01/05/12 02:33 PM
[Re: No Runners]
denham
Loc: Macungie
yeah i can ask my friend with the lift and shit and we can get something organized probably
#6040463 - 01/05/12 07:08 PM
[Re: denham]
g96nt
Loc: Annapolis MD
Find the requirements of the turbo and find a similar factory setup. Hell, maybe the feed from a TDI will work for ya, who knows. with whatever turbo you get, if it isnt restricted, its easy to get a ebay t2/3/4/6 feed bracket with a -4an fitting on it that is undrilled or you can drill your own hole to restrict it, .040 is a safe easy bet. journals usually like .060 max and ball bearings more towards .030 so drilling a .040 for anything will work great.
this was my thought. just get a banjo bolt with a small hole, and drill it out yourself. I just had to do the same thing when I made a S/S line for the Volvo. I bought an ebay banjo bolt setup, and used a drillbit to match the size of the original banjo bolt hole.
2000 Saab 9-5 wagon
#6040687 - 01/05/12 09:38 PM
[Re: g96nt]
denham
Loc: Macungie
ok 57mm isnt that big, it just looks huge from that photo with the big compressor and anti surge housing
#6042538 - 01/06/12 03:28 PM
[Re: No Runners]
It's too bad these weren't easier to find.
#6050245 - 01/09/12 11:11 PM
[Re: No Runners]
ElectronVTEC2
Denmah, what did you do about the PCV on the turbo truck?
What's the issue, is it not setup to handle positive pressure or something?
#6050651 - 01/10/12 08:27 AM
[Re: No Runners]
ElectronVTEC2
Can you just replace that line/valve with a catch can setup, and supply a vacuum (pre-turbo) source to said catch can to create sufficient vacuum to evacuate the crankcase? I've seen some setups on DSMs that replace the PCV with a check-valve system to prevent boost from getting into the crankcase through that system.
#6050734 - 01/10/12 09:27 AM
[Re: ElectronVTEC2]
NVMYMPGZ
Can you just replace that line/valve with a catch can setup, and supply a vacuum (pre-turbo) source to said catch can to create sufficient vacuum to evacuate the crankcase? This is exactly what i did on the e30 to cure some oil burnoff. works great, for a cheap DIY fix.
#6051080 - 01/10/12 11:54 AM
[Re: ElectronVTEC2]
No Runners
Loc: dirty jersey
I've read a lot about both ways of doing it (check valve and catch can setup). Not sure which to do yet. I was hoping someone would say, oh don't worry about it you'll be fine leaving everything stock .
