#4486285 - 02/03/10 07:58 PM Major winter overhaul on the Mustang
I’ve been doing some work to the car lately. Parts have been piling up on the shelf, and I decided to install them all at the same time, so I can feel better about driving my heap. This being me, this of course included handling upgrades, and for the first time since almost 2 years, I installed power upgrades.
Cooling: Even though it’s not summer yet, I’m still looking to get rid of the issues or improve the cooling system while I have time. I decided while I have time, I should shield off the radiator. The car had stock shields, but they were flimsy and plastic, barely doing their job. The new ones were made out of aluminum, and any space between the shield, radiator core support, and ac condenser was filled with foam. Hopefully this will improve the high speed cooling that much more
Transmission: Stock T5 with 181k miles on it… yeah, that about sums it up. Took it to a shop near by to have it rebuilt. They’ve replaced all the syncros, 2nd gear, and 4 bearings. Feels great now.
Suspension: It seems like I have touched everything on the suspension front other than front end bushings. The front still felt very sloppy, so it was time to take care of business. I got lucky, and found a new set of Maximum Motorsports control arms for a good bit less than retail. They came with urethane bushings, and they are also a good 8 pounds a side lighter than factory ones.
I’ve also noticed that the sway bar bushings were shot, so those were replaced as well. While I was there, I’ve changed the sway bar end links to shorter ones, to compensate for the drop, and also to give the brake duct hose a little more room to run (about an inch of extra space).
This brings us to the hose. The old hose I had was very expensive, and very fragile. It was a single ply hose, so at extreme angles, which on a mustang it has to be, the coils inside would move around, hose would lose its shape, and rub through. The new hose is dual ply, and also almost half the cost of the old one. It’s only good for about 350F, but I don’t think that will be a problem really.
Engine work: I finally decided that it was time to install the intake manifold on the car. While I was there, I also got a suggestion that I might as well do roller rockers while I’m there, so since they were pretty cheap, I went and bought those as well. I took the car to FSR Motorsports Creations for the baseline dyno run. Initial dyno put down the peak number of 192 whp, which is ok for the motor with 186k miles on it. After this was done, roller rockers, intake manifold and throttle body were installed, with a lot of snags (cross-threaded fitting in the intake for heater pipe, rockers did not clear stock valve covers, fox valve cover oil filler was right in the path of the throttle body, distributor bushings were busted). After everything was said and done, I took the car back to FSR Motorsports Creations, and redynoed it. Final pull resulted in 220whp, which makes it a 28whp gain. The best part about the modifications was that I lost absolutely nothing on the bottom end power, and peak power has moved significantly, not to mention that I have a lot more power band to work with on the track.
#4486299 - 02/03/10 08:05 PM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
Serendipitous Offline
Loc: Northern California
Nice!
#4486309 - 02/03/10 08:09 PM Re: Major winter overhaul on the Mustang [Re: Serendipitous]
RacerXI Offline
Loc: Dothan, AL
I'm glad to see you're still advancing with the car. Nice numbers on a well used motor also.
Rodney
04 S2000
#4486394 - 02/03/10 08:27 PM Re: Major winter overhaul on the Mustang [Re: RacerXI]
neonmike22 Offline
Loc: Nashville, TN
Hot stuff. Part of me still kinda wants a SN95 5.0 thanks to you. \:\)
Mike Carpenter
'03 Civic Hybrid
#4486569 - 02/03/10 09:04 PM Re: Major winter overhaul on the Mustang [Re: neonmike22]
Good kill on fixing it up and improving on it while you are in there. Are you running a stock radiator?
#4486613 - 02/03/10 09:19 PM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
progressi Offline
I always read your posts.
I like that you bought a platform and stuck with it (what cars did you own before these,I dont know why,but I forget what they were)?
I dig that you are tracking a high mileage domestic and it's not blowing up,because the general public would recommend against that.
I like that you are doing it on a budget as well.
I hope you beat that T5 though,I have a scar on my brow from the bellhousing when the tranny rolled off the jack (my first car and I was bulletproof) and split my skin open. I learned what "literally" seeing red was. lol
#4486650 - 02/03/10 09:32 PM Re: Major winter overhaul on the Mustang [Re: progressi]
 Originally Posted By: Serendipitous
Nice!
Thanks guys, and Mike you know you want it haha.
Dan, I'm running a Fluidyne distributor, and I have been for quite some time. Mustangs just run hot, so this is something that I have to deal with.
I've had an LT1 Fbody, and Corrado G60 which I nicknamed NOTAG60
#4486733 - 02/03/10 10:05 PM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
B15Sentra Offline
Loc: Bay Area, CA
So how much faster is your 1/4 mile time?
(good content)
#4487082 - 02/04/10 12:19 AM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
progressi Offline
Crap,I remember you now! I remember FORGETTING that you had a sweet LT1 that you used to post,and you reminded me. Sorry. \:\(
At least if queried I could reply that you have a 5.0/SN95! ;\)
#4487138 - 02/04/10 12:53 AM Re: Major winter overhaul on the Mustang [Re: progressi]
max Offline
Nice work!
I have the Griggs front end stuff on my car now, but one of the C/C plates was defective -- it knocks and binds. I'd send it back but they were huge dicks to deal with so I'll probably just deal with it and buy new parts from Maximum Motorsports down the road.
I hope to get the torque arm on later this year though, it's too damn cold and wet to work on it in the car port these days.
2015 Gear Hauler
#4487901 - 02/04/10 11:00 AM Re: Major winter overhaul on the Mustang [Re: max]
Thanks. Max, be careful mixing Griggs stuff with MM stuff. Griggs suspension has different roll centers than Maximum Motorsports. If you keep the K member and Panhard (or watts link) the same, you should be OK. I'm gonna stick to Maximum Motorsports. I'm already more than half way there anyway.
#4488253 - 02/04/10 12:30 PM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
SiGuyUWP Offline
Ahh yes, this post reminds me I have a heap of a Mustang to deal with in my garage. I haven't even touched it since I bought the thing, no time \:\(
#4488599 - 02/04/10 02:05 PM Re: Major winter overhaul on the Mustang [Re: SiGuyUWP]
hustler Offline
Great update, was unbuttoning stuff last night so I can pull my c4 out. I wanted a gforce t5, but might have to settle for a tko 600. Thats not bad for a high mileage 5.0. I think I pulled 225whp with around the same stuff except I had an e303 cam and it was on a mustang dyno. If you do anything, just save up for some heads, they will give you the biggest bang for the buck.
I like the radiator shields, where did you get those? I've got cooling issues being that I have to use pusher fans, so need to direct air as best as possible.
Looks like you have a little wear on your ds from the ebrake cable stud. Ford poorly designed that, I have the same thing except it wore a groove in my aluminum ds.
#4489853 - 02/04/10 08:57 PM Re: Major winter overhaul on the Mustang [Re: hustler]
Do work son!!!
Hustler, I made the shields myself. I did some measuring with the tape, made a sketch, cut it out of thin sheet of aluminum, and trimmed it while it was on the car, if necessary, which in my case really wasn't. I was surprised how close it was. Here is the template I did for my car. It's all in millimeters.
Drive shaft thing is not the studs, but the cable. It's hanging too low at times, so it rubs on the drive shaft. I already had floor pan welded right where the emergency brake bracket is, because a friend of mine ripped it.
#4489976 - 02/04/10 09:43 PM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
Awesome. On the corral, back in the day, they always said Intake Manifolds without heads would do nothing. Good to see some solid gains (of course, the RR's helped).
#4490116 - 02/04/10 10:40 PM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
max Offline
Yeah, I definitely won't be mixing Griggs and MM stuff in that way. When I said MM stuff, I just meant replacing the Griggs front end package of Koni red's ( ) and coilovers/CC plates with equivalent MM gear (and Bilsteins)
2015 Gear Hauler
#4490148 - 02/04/10 10:54 PM Re: Major winter overhaul on the Mustang [Re: max]
madmatt Offline
I see a Supra in the background \:D yours?
Nice job on the fixes man, bet it drives like brand new now with the new suspension work. Nice gain on the rockers and IM.
#4490220 - 02/04/10 11:36 PM Re: Major winter overhaul on the Mustang [Re: madmatt]
Lol, no chance. That's more than I can afford. Just a car that's in for some work over at FSR. The wiring on that car is totally jacked.
Yeah, the car drives great. Feels a lot more responsive, lost most of the slop from the front. Feels almost, dare I say it, like a bimmer.
Go with Koni yellows man. Even single adjustables like the ones I've got are good for a LOT of coil-over spring rate. Trust me, it's nice to have them on full soft when put putting it around town.
#4490737 - 02/05/10 08:10 AM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
max Offline
Yeah, that's what I was hoping to do, but this Griggs package came with reds. Like I said, I'm not to impressed with it.
2015 Gear Hauler
#8984553 - 03/26/17 08:45 PM Re: Major winter overhaul on the Mustang [Re: max]
lcklck16 Offline
20170327lck
http://www.polo-outlet.com.co
http://www.suprashoes.us.com
http://www.mulberrysale.co.uk
http://www.nikeshoes.org.uk
http://www.nikeoutletstore.us
http://www.hermesbirkin.org
http://www.fitflop.in.net
http://www.adidasnmduk.org.uk
http://www.polo-outlet.in.net
http://www.foampositeshoe.net
http://www.niketrainers.me.uk
http://www.herveleger.us.com
http://www.edhardy.us.com
http://www.nikeairmax90.me.uk
http://www.nikefree5.us
http://www.longchampuk.me.uk
http://www.todsoutlet.us.org
http://www.fitflopssale.me.uk
http://www.nikerosheone.us
http://www.mulberrybags.me.uk
http://www.lebronjames.us.com
http://www.kobeshoes.us
http://www.futbol-baratas.com
http://www.airmaxuk.org.uk
http://www.beatsbydrdre.co.uk
http://www.hermesbelts.us.com
http://www.nike-store.org.uk
http://www.nikestore-uk.me.uk
http://www.nikeair-max.me.uk
http://www.pradaoutlet.us
http://www.pradashoes.us
http://www.airmax90.org.uk
http://www.ysloutlet.us.com
http://www.iphone-case.org.uk
http://www.omegawatches.me.uk
http://www.cartier-watches.us
http://www.pandoraoutlet.name
http://www.ugg-outlet.me.uk
http://www.cartier.us.com
http://www.marc-jacobs.us.org
http://www.katespade.org.uk
http://www.nike-airmax2015.us
http://www.cazal.us.com
http://www.ferragamo.eu.com
http://www.fitflopssale.us
http://www.airjordan4.org
http://www.asicsisrael.com
http://www.nikerosherun.me.uk
http://www.cheap-raybans.org
http://www.jordanshoes.us.com
http://www.airforce1.us.com
http://www.toryburch.com.co
http://www.vans-shoes.cc
http://www.airmax90.us.com
http://www.rolex-watches.it
http://www.nike-mercurial.net
http://www.kobe9elite.us.com
http://www.burberryoutlet.ca
20170327lck
#9058134 - 06/15/17 09:44 AM Re: [re] 항상 느끼며 바라보기 [Re: ]
One positive thing that could be said about these spam posts, they do bring back good posts from the past. Kinda like facebook, letting you know what happened on this day like 8 years ago.
#9059776 - 06/16/17 11:57 PM Re: [re] 항상 느끼며 바라보기 [Re: ReplicaR]
Rudi Offline
Actually this post comes back at a great time. I snagged a SN95 Cobra 9 months back and I am slowly going over the car and doing the same things that you did to yours 7 years ago.
synchros are fucked
4th gear sometimes grinds
control arm bushings and ball joints are worn
#9061535 - 06/20/17 04:08 AM Re: Major winter overhaul on the Mustang [Re: Rudi]
That's cool. Did you get the 5.0 or the 32v Cobra? Congrats on the purchase btw, they are neat cars that can be quick with not a lot spent in them. I however have gone way overboard with mine. Here is what it looks like now.
#9063444 - 06/21/17 07:47 PM Re: Major winter overhaul on the Mustang [Re: ReplicaR]
A_Mantis Administrator Online   pandAr
Loc: Valley of the Sun
Thoughts on the "new edge" 99-04 GTs? The earlier ones can be had for around $5k now. How does it stack up vs an SN95 Cobra?
#9063857 - 06/22/17 12:28 PM Re: Major winter overhaul on the Mustang [Re: A_Mantis]
Well, SN95 Cobra could be both Pushrod 5.0 (94-95 240hp) or DOHC 4.6 (96-98 305hp). If it's the DOHC, it will blow the new edge GT away pretty easily. Combine that with better suspension, and much better brakes on the Cobra, and overall 96-98 Cobra is a much better rounded package than a later GT. Having said that, the 99-04 GTs respond incredibly well to boost, meaning that even the basic Kenny Bell kit with exhaust and bolt-ons will crack 400rwhp. Basic suspension packages are pretty cheap, and effective, Cobra brakes can be bought for literally 200 dollars, if you don't mind not having a cobra logo on them (Mach 1 brakes). I would recommend 01+, because they have much better (stronger and easier shifting) transmission.
#9173940 - 10/31/17 03:24 AM Re: michael kors factory outlet [Re: ]
HYst Offline
#9235973 - 01/21/18 09:14 PM Re: michael kors factory outlet [Re: HYst]
Andada
colts jerseys
bengals jersey
minnesota vikings jerseys
green bay packers jerseys
indianapolis colts jerseys
cardinals jersey
raiders jerseys
packers jerseys
converse trainers
nike huarache
oklahoma city thunder jerseys
golden state warriors jerseys
nike huarache
michael kors handbags sale
detroit lions jerseys
pittsburgh steelers jersey
nike factory store
tennessee titans jersey
chiefs jersey
nike factory outlet
yeezy shoes
jordan 8
prada shoes
chicago bulls
saints jerseys
new york knicks jersey
falcons jersey
ed hardy uk
soccer shoes
nike tn
converse shoes
baltimore ravens jerseys
nike air jordan
patriots jerseys
carolina jerseys
chicago bears jerseys
eagles jerseys
new orleans saints jerseys
san diego chargers jerseys
ed hardy clothing
ravens jerseys
giants jersey
nike huarache
moncler jackets
nike factory outlet
cheap snapbacks
nike soccer shoes
nike trainers shoes
chargers jerseys
jimmy choo outlet
skechers shoes
air huarache
true religion outlet
cleveland browns jerseys
hermes belt
broncos jerseys
nike outlet store
clippers jersey
49ers jersey
miami heat
skechers outlet
cleveland cavaliers
nfl jerseys wholesale
new england patriots jerseys
houston texans jerseys
steelers jerseys
air jordan uk
miami dolphins jerseys
kate spade sale
dallas cowboys jerseys
nike blazer
adidas yeezy
jets jersey
denver broncos jerseys
tods outlet
hugo boss outlet
nike outlet store
titans jersey
reebok outlet
dolphins jerseys
oakland raiders jerseys
ecco sandals
cincinnati bengals jerseys
arizona cardinals jerseys
new york knicks
clippers jersey for sale
cheap basketball shoes
bears jerseys
kate spade sale
jimmy choo shoes
philadelphia eagles jerseys
bills jerseys
washington redskins jerseys
san francisco 49ers jerseys
new york jets jerseys
redskins jerseys
jacksonville jaguars jersey
tods shoes
carolina panthers jersey
chicago bulls jersey
texans jerseys
vikings jerseys
coach handbags
lions jerseys
ecco shoes
fitflops sale
seahawks jersey
basketball shoes
salomon shoes
san antonio spurs jerseys
browns jerseys
air jordan 8
hugo boss sale
san antonio spurs
air jordan 4
kansas city chiefs jerseys
cowboys jerseys
miami heat jersey
atlanta falcons jerseys
los angeles lakers jerseys
fitflops shoes
cheap nhl jerseys
boston celtics jersey
nike roshe
boston celtics
new york giants jerseys
discount oakley sunglasses
buffalo bills jerseys
fitflops sale
polo ralph lauren outlet
nike huarache
seattle seahawks jerseys
jaguars jersey
