#444959 - 09/13/06 12:52 AM Problems w/a b16 head b18 block into a 00 si
everblink961 Offline
Loc: IN
so as far as i know i hooked everything up right the car starts kinda rough and then if i go to give it gas it dies out. i dont know what im a missing if any thing for the car to run i thought i would just be able to use all the si stuff if im wrong please please tell me
thanks
#444960 - 09/13/06 12:22 PM Re: Problems w/a b16 head b18 block into a 00 si
another member Offline
Loc: Columbia SC
is the timing set right?
The point of war is not to die for your country, but to make the other bastard die for his and not to determine who is right, but who is left
#444961 - 09/13/06 12:37 PM Re: Problems w/a b16 head b18 block into a 00 si
Slurp56 Moderator Offline
Loc: S21
Are the plugs for your MAP and TPS sensors reversed? They are both the same shape/size and are interchangeable.
#444962 - 09/13/06 01:08 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
let me check that im not sure
#444963 - 09/13/06 01:13 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
no its wont start either way
#444964 - 09/13/06 01:14 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
it wouldnt be the ecu would it cause im waiting for a ob1 ecu
#444965 - 09/13/06 01:44 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: S21
Nope, the Si ECU should run it just fine. Even if you dont have the CKF sensor on the new motor, it should still run, just you'll have a CEL.
What year head, block, distributor, and ECU are you running?
Are you able to get the motor to idle, or does it run bad all the time?
#444966 - 09/13/06 01:49 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
00 head 92 block 00 dist. 00 ecu
and if i can get the car to start it will idle fine alittle high but still fine and what about the knock sensor though
#444967 - 09/13/06 01:51 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: S21
It will throw a CEL but it will still run just fine.
How's the timing look on the motor, you have a light?
#444968 - 09/13/06 01:52 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
yea and it looks fine
#444969 - 09/13/06 01:53 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
is there anything that i might still need
#444970 - 09/13/06 02:01 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: S21
Kind of weird deal, What CEL's is it throwing now?
There aren't a whole lot of reasons why the motor would stall only when loaded, usally air starved/restricted or the MAP and TPS plugs are reversed as I suggested above.
The next steps I would take would be to verify the firing order is correct, check the ignition components, and for good measure I'd compression/leak test it.
#444971 - 09/13/06 02:04 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
alright its seems like its not getting air, and i have an aebs intake should i just switch it back to my stock one
#444972 - 09/13/06 02:06 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: S21
That's kind of hard to answer without the car being physically here. Short Answer, It needs all the same pieces that the B16 did.
#444973 - 09/13/06 02:10 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: S21
Ok, we might be onto something here...
Where is your MAP sensor located? Is it on the stock Throttle Body location?
Pull the throttlebody off of the intake manifold and compare the AEBS manifold to the stock one. Are all the same ports/passages in the manifolds?
I'm thinking that maybe the MAP sensor isnt seeing manifold pressure. Though, I've never had my hands on an AEBS manifold either.
#444974 - 09/13/06 02:38 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
ok hold on let me check
#444975 - 09/13/06 03:38 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
ok well they are both the same
#444976 - 09/13/06 08:21 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
ok well now it starts and will idle fine if i hold the gas down i cant get it to idle on its own now any suggestions
#444977 - 09/13/06 09:52 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: S21
Sorry man, without having the car nearby, I am fresh out of ideas.
Is it throwing any CEL's? If so, which ones?
#444978 - 09/14/06 11:28 PM Re: Problems w/a b16 head b18 block into a 00 si
Loc: IN
haha it was just my throttle cable thanks for the help
#8600314 - 03/24/16 08:54 PM Re: Problems w/a b16 head b18 block into a 00 si [Re: everblink961]
RG2LEM1 Offline
Faulty oxygen sensor? Oops, just read it was the throttle cable...
Edited by RG2LEM1 (03/24/16 11:57 PM)
Moderator:  Slurp56, The Mad TitanPaki
