#2404433 - 03/05/08 10:49 PM Trick Flow FPR (27001)
ScottStaypuff Offline
Trick Flow 27001
Anybody have one of these or know anybody with one? The price is right and it comes with the 3/8" npt inlet/outlets (to match my fuel rail). Its really made by Aeromotive, hecks in a few dollars cheaper than the aeromotive equivalent and is more compact than the A1000. I rikey the black and its alky compatible to boot. I don't see any issues with it at all, how about you SVA?
#2404534 - 03/05/08 11:15 PM Re: Trick Flow FPR (27001) [Re: ScottStaypuff]
Submission Offline
Loc: Houston, TX
What HP level? Thats probably good to 500 w/ a 3/8" line. The aeromotive equivilent has larger feed and return lines i think, can't remember last installed one a year ago.
interesting the description says red, pic is black, its like they just cut and pasted the aeromotive description.
#2406039 - 03/06/08 12:07 PM Re: Trick Flow FPR (27001) [Re: Submission]
Yes, they have an equivalent to the A1000 as well in black. I'll most likely be running dual 6an lines up front and one into each end of the fuel rail (with regulator at one end dumping extra fuel into a 6an back to tank. I think (E85) fuel supply should be ok as long as I don't overtax the 6an return line. I would at most be doing 500ish, this is in an SRT'd 2.4L bottom end which will hold around 500.
#2406894 - 03/06/08 02:57 PM Re: Trick Flow FPR (27001) [Re: ScottStaypuff]
Submission Offline
Loc: Houston, TX
i've always thought that you needed to be 1 size down from the feed line for the return, so 2 6's you might need an 8 or maybe even a 10. are you saying 2 6's from the tank right?
#2407793 - 03/06/08 07:18 PM Re: Trick Flow FPR (27001) [Re: Submission]
cacasesi Offline
Say my name!
I'm using its big brother, the 5158
I also picked it because it was black and made by Aeromotive. No complaints after over a year's use.
I remember looking at the small one, but it doesn't have a gauge port! Which was a deal breaker for me because I'm lazy. You know the Summit link you put up shows a black picture but lists the color as red... might want to check on that.
#2458609 - 03/20/08 07:23 PM Re: Trick Flow FPR (27001) [Re: cacasesi]
I checked and it is indeed black. They have changed the description too.
#2459923 - 03/21/08 09:04 AM Re: Trick Flow FPR (27001) [Re: ScottStaypuff]
Mr. Knowitall. Offline
**banned**
I hate the walbro. E85 ftw, 420whp worth of e85 ftl. \:\(
This website doesn't do me justice.
#2460130 - 03/21/08 10:41 AM Re: Trick Flow FPR (27001) [Re: Mr. Knowitall.]
That specific regulator (in aeromotive form) has had issues in the DSM circles. They had a mounting kit for mounting it on the engine which is a bad idea and caused a lot of vibration resultant failures. If you do get it mount it on the firewall or similiar even though I hear its illegal for drag racing. This is one of the instances where modern FI cars can't follow rules for carbuerated cars because if you do you have a serious safety issue (a fuel fire).
Aeromotive had some issues with diaphragm failures on most models a few years ago. They have since changed the material used for the diaphragm to handle newer blends of street fuel.
#2460135 - 03/21/08 10:43 AM Re: Trick Flow FPR (27001) [Re: Mr. Knowitall.]
Walbro pumps? If so what is the issue? I've had no issues with OEM walbro pumps when following proper design limitations of the units......
#2461162 - 03/21/08 04:49 PM Re: Trick Flow FPR (27001) [Re: danl]
Sukkoi18 Offline
Loc: Quad Cities IL/IA
I had one go south me as well. I use this now.
http://store.summitracing.com/partdetail...15&autoview=sku
Juiced 2002 Z28
Blown 1989 Mustang GT
#2465240 - 03/23/08 01:33 PM Re: Trick Flow FPR (27001) [Re: Sukkoi18]
I'm going with the bigger one, if only because I can mount the gauge directly on it.
So the basic fuel system layout is:
1) Two pickups in the original canister in the tank made from 3/8" stainless fuel line
2) Out of tank to two 40 micron fuel filters
3) To two Walbro 255's in parallel
4) To a 6an to 8an "Y"
5) To a 10 micron fuel filter
6) To 8an feed line
7) To fuel rail (and 1000cc injectors)
8) To fpr
9) 6an back to tank
Meets my 500whp goal on E85 with room to grow.
#9173968 - 10/31/17 03:26 AM Re: Trick Flow FPR (27001) [Re: ]
HYst Offline
