The PostmanThe Postman
A-List Member also The Man
Yes. 5x114.3. But the S2000 has a different offset for the wheels. S2000 wheels will bolt on, but they will probably rub. You would have to use 4 S2000 front wheels to fit correctly.
The S2000 has some stupidly high offset. IIRC it's up in the +60's. They would not be a good option for an Si. For the Si you should be looking at +45 to as low as +30 depending on the width and your tolerance for torque and bumpsteer.
Well im not actually putting s2k wheels on my car, they are volks te37 that was on a s2k, how do i check the offset on the wheel is it shown somewhere cause the guy has no idea when i asked. thanks
