#1329827 - 05/04/07 03:54 PM
Re: Advice on Rear Springs
[Re: Hemix]
Noob4Life
Loc: IL, USA
There's no way for stiffer springs to increase grip in the rear. You are increasing roll resistance by increasing spring rate -> higher roll resistance -> more sprung weight transfer, faster -> loss of grip -> rotation.
The end with more grip obviously has more traction, and would break away later than the opposite end.
If you can't push the rates any higher, you might try dropping the fronts (switch the springs). PLaying with tire pressures might help.
edit2: yeah that was right... My brain is dead from not being used at all today.
Edited by Noob4Life (05/04/07 03:57 PM)
#1356304 - 05/05/07 06:49 AM
[Re: Noob4Life]
Huggy
I'd suggest changing one or all of the following (this is only for a 92-00 Civic ~ go eat nails if you got something else or start your own post): Front spring rates are too high. (seriously ~ no reason for over 400lbs/in unless it's a road race car) Too large of a front anti-roll bar. (I ran a 19mm bar but even the EX 22mm bar is better then the stupid large Si 26mm) Too small of a rear anti-roll bar. (22mm is acceptable I guess ~ I prefered the 25 or 32mm bars though) Too low of rear spring rates. (you can get away with as low as 350lbs/in but the higher the better and contrary to what others will say the higher you go with a larger rear anti-roll bar will equal faster transistions and more grip) Shock dampening is probably way off. (most people couldn't setup a shock to save their live and most companies couldn't build a shock worth a damn anyway ~ go custom built and save the hassle of having shitty equipment.) More toe out in the front. (minimum 1/8" out) Zero toe in rear. (zero toe in the rear just seems to work no matter what)
Kevin - Owner and Driver of Cars -
#1356905 - 05/05/07 02:39 PM
[Re: Huggy]
Noob4Life
Loc: IL, USA
The reason for the high front rates is because those shocks don't have a ton of avialable stroke. The higher rates in the front keep the front end from botting out. Also, many people DD on 560lbs/in springs up front, it's the rear rate that has the larger effect on ride quality.
Too much rear bar will cause you to lift the inside rear around every corner. Also, increasing roll resistance = reduced grip on that end as I said before, I'm not sure where you've found that more roll resistance would give more grip?
Custom valved setups are overkill for a street car. So are coilovers, but since the OP already has a set, there's no reason to overdo it anymore. There's no guarantee a "custom" setup will be any better (see Advanced Designs, unless you enjoy rebuilding your shocks after every season).
If a car is not turning in, toe-in will exacerbate the problem; a touch of toe-out is what will help with turn-in issues.
#1358140 - 05/06/07 01:17 AM
[Re: Hemix]
Noob4Life
Loc: IL, USA
Bumping the rear rates up is going to be an improvement over your existing setup, that is for sure. Damping does play an a role in all phases of cornering, from entry to exit. Generally, damping adjustments made for corner-exit situations will have the same effect on mid-corner situations.
If the car wants to push mid-corner, and you know it is not a problem with the driver (getting on the gas too early, or too hard), then you want to look at increasing front rebound, and increasing rear compression (if available). The same would apply to corner-exit.
Some roll is good, since it sounds like you are fighting understeer already. And since you are already pretty stiff on the front bar, I would not go adding more.
We can't be sure without a shock dyno to look at, but it's possible that Homicide is right and your damping is simply not up to the task of handling those springs. Poor damping can be masked by a host of other handling variables, which sometimes aren't even problems. But due to the difficulty in diagnosing damping problems, people attribute it to other, more noticeable and easily fixed variables like tires, springs, and arb's.
#1358268 - 05/06/07 07:57 AM
[Re: Noob4Life]
Huggy
Lets get one thing straight ~ I'm always right. I'm not in the buisness of lying or spewing bullshit. I'm in the buisness of making vehicles go faster, winning races, and building world class suspensions. I've been doing it for almost 20 years.
If the shocks have too short of travel then ditch them ASAP ~ no reason to run anything over 400lbs/in front spring except on road race cars where ride height needs to be as low as possible. Secondly if don't have a good non-adjustable compression rate on your shocks you have to go to dual adjustable shocks to set the compression damping.
My final note (because I've decided that the 26mm anti-roll bar can be acceptable although it's too damn big) is that you have to decide ~ are you building a race car (for autox) or a street car? Rear spring rate is just way too low. Trust me on any of the Honda Civic/Integra chassis since 92 the higher the more grip and faster transitions.
And custom built shocks that are dual adjustable are a must for all cars IMO ~ street, track, autox, drag racing, whatnot. Shocks are the second most important part to any vehicle for handling behind tires. Tires are you feet and shocks are your muscles and you can't go fast without either.
#1358385 - 05/06/07 10:36 AM
[Re: Huggy]
Noob4Life
Loc: IL, USA
So what are you suggesting to the OP, to build a race car or a street car? It sounds like you're suggesting options for both, which can be a little confusing. 336lbs/in in the rear is too soft, 26mm rear bar is ok, double-adjustability is necessary but 400lbs/in in the front is too stiff?
Nobody doubts that more grip = better handling. I'd like to hear how higher rear rates + a stiffer rear arb = more grip in the rear though. Because I'm fairly certain it doesn't work that way.
#1358570 - 05/06/07 12:18 PM
[Re: Noob4Life]
Hemix
Thank you both for the advice and keep it coming as you can:
Homicide - This is my daily driver. I do not have enough money to make a dedicated race car so I have to get as close as I can while keeping my car streetable. Also, I would love to get new dampers but I don't have enough money to drop over $800 (or even $200 for that metter) for a new set of dampers, so I have to work with what I have.
Some more info if it will help at all...The Tein SS dampers are 16-way adjustable and adjust both rebound and compression on the same nob. (Stiffer makes both compression and rebound stiffer together) I know, it's pretty lame, if I knew then what I know now I wouldn't be riding on teins. The shocks on my car have not been dyno'd and finding the perfect damping on them is for the springs, without a dyno, is impossible so I'm just going to deal with it and use them to change the way the car behaves.
So Noob, you're saying that if I add some damping to the front, while it might not give me as much rotation on turn in, it should help with rotation on corner exit and thus mid-corner as well?
"Great scientific achievements are not made by a genius saying 'Eureka'. Great scientific achievements are made by a confused man saying, 'What the f***?'" -Matthew Tearle
#1358694 - 05/06/07 01:28 PM
[Re: Hemix]
Noob4Life
Loc: IL, USA
That is the idea, with the premise being that insufficient rebound damping in the front allows load to be shifted rearwards too quickly, unloading the front tires and causing you to push out of the corner as you get on the gas.
In an ideal situation, everything is should be well sorted out (from the tires to the driver), but since that's hardly ever the case and because we don't know how effective those dampers are, it might not work out that well in practice. I've found that in a few of the race cars that run our coilovers, increasing front rebound does to reduce corner exit understeer. But with rates of 8k/6k, there's only so much you can do.
You say the shocks are adjustable in both compression and rebound, but I'd be curious to see just how much compression is changing with adjustments in rebound. It's pretty shady of a manufacturer to call their shocks double adjustable when what is happening is simply crosstalk (aka unintended changes in compression as a result of reboudn adjustments).
#9129885 - 09/12/17 02:30 AM
[Re: Hemix]
HYst
they sud-denly started Nike Shoes Discount Marketplace to feel very heavy and burdensome.
Cracking my SchoolBook nike air jordan pas cher had Canada Goose Womens Coats been easy. The crack was online Moncler Sale within amonth of ugg clearance the machine showing up, and there was nothing Reebok Outlet Store to it — justdownload newest lebron shoes a DVD image, Pandora Outlet burn it, stick it in the Hogan Outlet SchoolBook, Adidas Superstar and boot itwhile holding down a bunch of different keys at the same time. TheDVD did the rest, installing a whole bunch of hidden programs Christian Louboutin Heels on themachine, programs that North Face Outlet would stay hidden New Nike Shoes even when the ugg factory outlet Board Doudoune Moncler Femme Pas Cher of Eddid its daily remote integrity checks Coach Bags On Sale of the machines. Every now andagain I had to get Nike Kyrie an update for the software to Nike Roshe Run get around the Yeezy Boost Sale Online Board'slatest tests, but Official NHL Jerseys it was a small Adidas Yeezy Cheap price to pay TOMS For Sale to Michael Kors Outlet get a little control Bottes Ugg Femme Pas Cher over Nike Soccer Cleats Boots thebox.
I fired up Uggs For Cheap IMParanoid, the secret instant messenger Discount Air Max that I adidas store used when new pandora charms Iwanted adidas outlet to have an off-the-record discussion right in the Billige Nike Sko middle Moncler Outlet Store of class.
Darryl Cheap Nike Huarache was already ugg store logged in.Once everyone was done, Jolu went to make a key, TOMS STORE and Nike Shoes Sale Store then turnedaway, giving me a sheepish grin. I nike sportschuhe was past my anger with him, though.
He was doing what he had to do. I knew Adidas Soccer Cleats Cheap that no matter what he toms shoes outlet said,he'd Vans Black Sneakers always be there for me. And asics sko we'd been Adidas Neo Discount Sale through the DHS jail togeth-er. Van too. No matter what, Cheap True Religion Jeans that would bind Nike Free Run 5.0 Womens us together forever.
I reebok running shoes did UGG BOOTS FOR WOMEN my key and did the Zapatillas Air Max perp-walk Pandora Style Beads around the gang, letting TOMS SHOES OUTLET everyonesnap cheap uggs a pic. Then Air Max Sneakers I climbed up Air Max Femme on the high 23 IS BACK Store spot Nike Shoes Online I'd spoken from earlierand called for everyone's attention.
"So a lot of you have Nike Air Huarache For Sale noted that zapatillas nike baratas there's a vital flaw in this procedure:
what if scarpe nike this laptop can't Nike joggesko be trusted? Nike Pas Cher Femme What Ugg Outlet Online Store if it's secretly recording our in-structions? What Nike Roshe Run Sale if it's Cheap Louboutin Heels spying on us? new yeezy shoes What if Jose-Luis and I Negozi Pandora can't betrusted?"More good-natured Adidas Superstar Sale Online chuckles. Stone Island Outlet A little cheap uggs for women warmer than before, more beery.
"I Nike Air Max Sale mean it," I said. "If we were Nike Store on the wrong side, this could get chaussure adidas pas cher all ofus — all of you Jordan Shoes Air — into a heap Soccer Boots Outlet nike of trouble. Jail, Abercrombie and fitch store maybe."The chuckles turned more Canada goose dam nervous.
143"So Discount Ray Ban Sunglasses that's why Nike Air Shoes I'm going to do this," I said, nike shoes and picked Jordan Store up a hammerI'd brought from my Dad's Adidas Originals Superstar toolkit. I set the laptop down beside me coach factory outlet online onthe rock Yeezy Men and swung chaussure basket homme the hammer, retro jordans for cheap Jolu following the swing with his key-chain light. Boty Nike Air Crash — I'd always Louboutin Wedding Shoes dreamt Cheap Air Max Trainers of killing pandora jewelry store a laptop with a Moncler Outlet Online ham-mer, and Scarpe Air Max here I was doing Ugg boots Sale it. It felt pornographically good. And bad.
Smash! The nike sneakers screen-panel fell off, Original Ugg Boots shattered converse store into millions of vans shoe store pieces, ex-posing the ジョーダン スニーカー keyboard. I kept Cheap Michael Kors Handbags hitting it, christian louboutin outlet until the keyboard fell Nike Polo Sale off, expos-ing Scarpe Nike Scontate the motherboard and the hard-drive. Crash! I aimed pandora outlet store square for thehard-drive, Air Nike hitting it with everything I had. Air Jordan Retro Sale It took three blows beforethe Discount Christian Louboutin Shoes case split, exposing the fragile media Hugo Boss Sale inside. I Cheap True Religion Jeans kept hitting it untilthere was nothing Nike Air Pas Cher bigger than a fitflops sale uk cigarette lighter, then I put it Canada Goose Outlet all in agarbage bag. The crowd was cheering wildly — loud enough that I actu-ally got worried that Cheap Michael Kors Tote Bag someone far above us might Doudoune Moncler Site Officiel hear over the Pandora Store surf Cheap Michael Kors andcall nike tn pas cher the Uggs Pas Cher Soldes law.
"All right!" botas de futbol I called. günstige nike schuhe "Now, Michael Kors Handbags Discount if you'd like to accompany me, I'm Toms Factory Outlet going Ray Ban Sunglasses Online tomarch Pandora Store this Adidas NMD For Sale down to the Nike Outlet Store sea Adidas Originals Stan Smith and soak it Doudoune Moncler Pas Cher in Nike Huarache Womens Cheap salt water for ten Pandora Official Website minutes."I didn't have any takers Adidas Originals Sale at first, but air force one pas cher then Ange Nike Shox Cheap came forward and tookmy arm in her warm hand and said, "That was Michael Kors beautiful," in my ear andwe marched down to the sea together.
It was perfectly dark by the Cheap Air Max sea, and treacherous, even with louboutin heels our key-chain lights. Slippery, Christian Louboutin Shoes Outlet sharp rocks that were Nike Air Sneakers difficult enough to walk oneven without trying Nike Air Women to nike air balance six pounds of smashed Nike Air Max Goedkoop electronics in aplastic bag. I slipped once and thought I was Air max dam going to cut myself up, butshe caught me with a surprisingly strong Canada Goose Online Store grip and kept me ADIDAS NMD SALE ON LINE upright. Iwas Zapatillas Nike Air Max Baratas pulled Cheap Nike Free Run in Timberland Outlet right close to pandora beads her, close enough to smell her perfume,which nike jordan shoes smelled Nike Factory Store like new cars. Chaussure Air Max I love that smell.
"Thanks," I managed, looking into moncler jacket sale the big eyes that were further Nike Air Max Cheap mag-nified by her mannish, black-rimmed glasses. I couldn't tell what colorthey Nike Online Store were in the dark, but I Air max levně guessed something dark, based on her darkhair and olive complexion. She looked Mediterranean, maybe Greek orSpanish or Italian.
I Nike Outlet crouched down Cheap Toms Outlet Store and dipped womens nike air max the bag in the sea, Official Toms Shoes Outlet letting it fill with saltwater. TOMS OUTLET I managed to Pandora Store Sale slip a little and soak my prada outlet shoe, and I Adidas Shoes Discount Marketplace swore and shelaughed. We'd Mens Nike Air Max hardly said a word since we lit out for the ocean. Therewas suivre un envoi something magical in Nike Shox discount Sale our wordless silence.
At Canada Goose Outlet that cheap nike air max point, I Ugg Pas Cher En France had kissed a total of three girls モンクレール レディース in my life, not countingthat moment when I went back to school and got a hero's welcome.
That's not a canada goose jacket outlet gigantic number, but it's New Air Max 2017 not nike mercurial soccer cleats a minuscule Chaussure Nike Pas Cher one, either. Jordan Sneakers For Sale I Cheap Real Jordans havereasonable girl Nike Air Jordan 11 radar, and I think I could have kissed her. She wasn't144h4wt in Discount TOMS the Coach Outlet Store Online traditional sense, but Yeezy Black there's Chaussure Nike Air Max Pas Cher something about zapatos de futbol nike a girl and anight nfl store and a beach, plus Nike Tn Requin Pas Cher she was smart and canada goose jackets on sale passionate The official UGG and committed.
But I didn't kiss her, longchamp bags on sale or take her hand. Instead Cheap Nike Air Huarache we had Boutique Ugg a moment that Ican Nike Air Damen only describe Kobe Shoes Nike as spiritual. The surf, the night, the sea and the rocks,and our breathing. The moment Moncler Outlet stretched. I sighed. This had been quitea ride. I had Jordan Shoes For Cheap a lot of typing to do tonight, Ugg Pas Cher Femme putting all Yeezy Shoes Discount Marketplace those keys Air Max Kopen into mykeychain, signing them and publishing the signed Air Max 90 keys. Starting Nike Factory Outlet the webof trust.
She sighed too.
"Let's go," I said.
"Yeah," she said.
Back we went. nike sb stefan janoski It was chaussures nike pas cher a good night, that night.
Jolu waited after for his brother's friend to come by and Hyperdunk 2014 pick up hiscoolers. I Cheap Toms Shoes Outlet walked with UGGS Outlet everyone else Toms Outlet Online up new jordan releases the Adidas Yeezy Boost 350 For Sale road to the nearest Munistop and got on board. Of course, Cheap Retro Jordans For Sale none Descuentos Nike of us was Nike Air 90 using an issued Munipass. By Michael Kors Clearance that point, Xnetters huarache sneakers habitually cloned someone else's Muni passthree or nike schuhe günstig four times a day, assuming a Boost Yeezy Sale On Line new Moncler Jackets Discount Marketplace identity for every Air Max Pas Cher ride.
Moderator: Huggy, Runnin@Redline Jr, Professor Paki
