#6216708 - 03/17/12 08:34 PM
Re: It's March 10th, turbo Neon done by May 10th?!
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
Stock SRT4 clutch for now. uncut. Targeting just over 300hp, should hold fine.
-Matt '95 M3 | '99 Garage Shelf "Life before [CSi] wasn't looking good, I had a small cock, smaller wallet, and had a girl that was getting railed by 5 HUGE black guys." -AZSnake "Ha... yeah if neon ownership teaches you one thing it's how to turn lemons into Country Time." -Spotch "If the market demand for snarky comments is below my current supply of sassy wit I can only assume the market will adjust itself accordingly. Any minute now. Dick." -2000SiRacer
#6217217 - 03/18/12 04:48 AM
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
Yep.
Got a little more done tonight. My motor has a weird piece that bolts onto the oil pump and curves around back behind the oil pan to hold the filter. Think SRT4 oiling, but external to the steel pan.
Well, now I have an intermediate shaft back there, and wanted the clearance... so I went up to a buddy's house with the neck since he's got a bandsaw. Plan was cut the flange off, tap it to NPT, and run remote oil filter.
...well he got creative, and built a tool to hold the bandsawed flange off the neck, chucked it in the lathe, and made a smooth area for O rings to sit on. Gonna order AN fittings tomorrow once I figure out how big I need (looks like 8AN but gotta check), and run the remote oil filter. Should prevent ANY chance of cracking the cast AL with an NPT fitting... just in case.
#6218121 - 03/18/12 08:03 PM
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
Pressfit. Twist and pull. Had to glue mine back in with RTV. Hope it holds.
#6218287 - 03/18/12 09:34 PM
[Re: endo]
Damnit, Laverty
Loc: Bellevue, WA
yeah, it's not so buried anymore. You wouldn't recognize my garage if you saw it these days!
Speaking of which, we're all long overdue for a night over here. Lemme get the kegerator over here and i think i'll declare barbeque night... or better yet, Kiley keeps saying she wants to cook, maybe i'll just be lazy.
Edited by ACR Racer (03/18/12 09:38 PM) Edit Reason: edited for the better lazy plan
#6219130 - 03/19/12 10:53 AM
[Re: scootergeek]
Damnit, Laverty
Loc: Bellevue, WA
Didn't want to convert to SRT oil pump, pickup,etc plus originally built this motor before SRT came out, and crankscraper was fitted to this pan.
#6220726 - 03/19/12 07:34 PM
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
So obviously you're stuck on some of these, but what can you install tonight? Can you make headway on the gauges, etc?
#6221455 - 03/20/12 01:27 AM
[Re: madmatt]
Damnit, Laverty
Loc: Bellevue, WA
OK. Night of little forward progress, but a night none-the-less.
Pulled the front motor mount back out, fettled it into shape slightly. Tonight was the night of "crap, better chase that hole too". I had to run my rethreader down damned near every bolt hole for the FMM assembly; apparently the motor didn't like not having anything threaded there for like 6 years. has the assembly in and out about 6 times, had to fire up the air cutter, too. Tools are awesome.
Ordered a pizza, poured myself a beer and just got down to business. Once that was done, i got the passenger seat bolted in. Now i've got a list of parts to order a mile long.
Gotta get an M16 tap, 2 M16-8AN adapters, 48" of 3AN, a clutch fitting, and a new rear engine mount, plus go pick up 3 M6x1 bolts tomorrow to hold this damned oiler plate in place.
Edit: parts ordered. 75 at Summit, 32 for the engine mount, 20 for the tap. Bleh. I feel broke.
Edited by ACR Racer (03/20/12 02:48 AM)
#6224363 - 03/21/12 02:13 AM
[Re: Damnit, Laverty]
Damnit, Laverty
Loc: Bellevue, WA
Axles are in, at least temporarily. I can now say SRT4 axles fit a 1gen, with 2gen hubs, special intermediate shaft adapter and no control arms
Its nice seeing boxes end up in the recycle bin after years and years.
#6224395 - 03/21/12 03:27 AM
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
I dogged it last night but got the tranny together tonight Quaife and all.
shit I missed this before! Nice! When you bolting it up?
#6224990 - 03/21/12 11:13 AM
[Re: ScottStaypuff]
NVMYMPGZ
Loc: White Plains, NY
I get my turbo oil lines tonight. So then I can pick a spot to have the drain bung welded to the pan and take it to a shop.
Pick a spot above the oil line while the motor is mounted! I made the mistake of picking a spot that looked fine on the bench but with the angle the motor sits in the car its below level.
#6225741 - 03/21/12 02:57 PM
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
I get my turbo oil lines tonight. So then I can pick a spot to have the drain bung welded to the pan and take it to a shop. As soon as that and my intake manifold are back I will assemble the engine and bolt up the tranny then bolt it in the car. A week or two? Then I can really dig in and bolt the wheels on/ plumb the lines, wiring, etc. Matt my ADD probably prevented me from seeing it. Are you Megasquirting?
yes I am. Leaving the stock ECU for some control, but running fuel and spark through the MS.
#6227877 - 03/22/12 11:24 AM
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
Its been at least a year since I built mine, we'll see what i can remember, but of course i'll answer questions. One of my coworkers used to build them when he owned a fab shop, he's forgotten more than i know about 'em. We'll get it figured one way or another.
Progress last night: 0, stuck at work until 1am.
Edited by ACR Racer (03/22/12 11:25 AM)
#6229597 - 03/22/12 11:43 PM
[Re: ScottStaypuff]
Damnit, Laverty
Loc: Bellevue, WA
Oh man! So, yet another night of no progress on the car, since again i'm stuck at work overnight. (Yay deadlines.)
BUT- My Summit shipment got here, and it's almost as if they knew i'd be here, they included a free 5hr Energy in the goodie bag in one of the boxes!! So yeah, unblocked to finish and bleed clutch finally... if i ever get home. Gratuitous pic of awesome parts... stuck at work with me follows.
#6231889 - 03/23/12 10:37 PM
aerosaaber
Loc: Pittsfield, MA
If you bolt the pan down during the welding process, won't that (help) prevent warpage?
2006 Subaru WRX Wagon (I'm back on boost!) 2001 Subaru Legacy Outback Wagon Limited (sold) 1994 Saab 9000 Aero (gone) http://www.saabrally.com
#6232298 - 03/24/12 09:06 AM
[Re: aerosaaber]
ScottStaypuff
I hope the welder will do that. I actually was advised to move the bung over/down a little from the original location. Which requires a new 10an line, doh.
#6233060 - 03/24/12 08:20 PM
[Re: ScottStaypuff]
aerosaaber
Loc: Pittsfield, MA
I'm gonna to go get me the best cut off saw money can buy at Harbor Freight to do my an lines. it will last just long enough to finish the job, so WIN
