Page all of 2 12>
#35543 - 10/31/03 11:44 AM 200 whp b16a street build up results
omnimanlsr Offline
i have been working on an NA b16a street build up for the last few months. my goal was to make 200 whp from the 1595cc b16a motor on 91 octane. several people and companies kicked down parts for the build. we basically used a stock bottom end and many more oem parts to reach our goal. we dynoed the 2000 si on 2 different dynoes a few days ago and had an average whp between the 2 of 201 whp. one of the dynoes was very low reading compared to other dynoes in my area. besides that we video taped the entire process and will be releasing it for viewing so ppl will have an example to fallow. the reason i did this is to help prevent ppl from making mistakes or taking a dead end build rout. there is a lot of misinformation on the web sites that are dedicated to honda tuning. this misinformation leads ppl on wild goose chases in their quest for power and needless meandering around. which causes ppl to get lost in a sea of information. seeing is believing and thats why i had everything video taped. it took 9 days @18-20 hours per day. the dynoes will be posted on ef-1/main.com. by the way the compression was 11.5 and we dynoed with a full exhaust and intake. all the video trailers will be veiwable on intertune.tv in a few weeks after we get things edited. stay tuned
intertune tv watch it here: http://www.browndogonline.com/intertune/
#35544 - 10/31/03 11:54 AM Re: 200 whp b16a street build up results
Beave0101 Offline
servant of egosgame
Loc: San Diego
and to follow along...
http://ef-1.zeroforum.com/zerothread?id=171
http://www.honda-tech.com/zerothread?id=639897
just for reference since i"m not sure what tuner shops you were all working with, but for comparisons sake, what two dyno's did you run @ ?
#35545 - 10/31/03 01:47 PM Re: 200 whp b16a street build up results
cruzersi99 Offline
Great work.
186 whp - Church Automotive (Dynapack)
189 whp - Zero Factory (Bosch)
#35546 - 10/31/03 02:15 PM Re: 200 whp b16a street build up results
shivers Offline
Loc: North America
Way to go, Omniman. I've been following the build-up since day one.
2010 G37s
#35547 - 10/31/03 05:19 PM Re: 200 whp b16a street build up results
omnimanlsr Offline
ironically we dynoed on the two dyno's that tune the only 2 all motor 9 sec. cars. which is trackmasters (leslie durst 9.93) and churches automotive testing (ericks racing 9.99) one was a dyno jet and the other was a dynapac. the dyno jet at track masters is a very consevative dyno we made 195 .somthing and churches we made 206.5. i wanted to do a 3rd dyno but we ran out of time. none the less the average beween the 2 reached our goal. both dyno facilities were very helpfull and i thank them for their time and efforts. shawn and bubba are both excellent tuners.
#35548 - 10/31/03 05:52 PM Re: 200 whp b16a street build up results
Beave0101 Offline
servant of egosgame
Loc: San Diego
very interesting, especially since trackmasters has notoriously low numbers, very good work!
#35549 - 11/01/03 11:04 AM Re: 200 whp b16a street build up results
CivicVTi Offline
Loc: Athens , Greece
We wait patiently for your post on how to do this!
Honda Civic VTi '95 EG6 hatch (stock B16A2) B18C6 specR swap (Euro)
#35550 - 11/01/03 01:46 PM Re: 200 whp b16a street build up results
MoesFlashBlueCar Offline
Loc: Pontiac, MI
Good stuff.... but i thought oversized valves and radical cam's were kind of a no no. I woudl like for you to elaborate on that.
I like the setup, and kudo's to you on the number's. But i also noticed that you used ITR head. So the only thing B16 is the bottom end. So im guessing the oversized valve's and some milling of the head got you to 11.5?
None the less, good job. Cant wait to see the vid's. :thumbup:
Edited by MoesFlashBlueCar (11/01/03 01:49 PM)
Esse is percipi AIM: Y2moe99
#35551 - 11/01/03 03:04 PM Re: 200 whp b16a street build up results
MadtownSi Offline
Moderator
Loc: Madison,WI
Oversized valves???? I did not see anything about oversized valves, just high compression valves. Then again I just skimmed the other links.
Omniman,
Great work!!! I can’t wait to see all the video footage you guys took. I’m sure I can learn a great deal from this build up. Once again, very impressive work!! Two thumbs up!!!
--------------------------------- F1 www.donandmikewebsite.com
#35552 - 11/01/03 04:04 PM Re: 200 whp b16a street build up results
Loc: Pontiac, MI
Omniman,
Arent they the same thing's.... or similar. Seeing as you just made that point, i really want someone to explain it to me... i = t3h stupid.
#35553 - 11/01/03 05:18 PM Re: 200 whp b16a street build up results
MadtownSi Offline
Moderator
Loc: Madison,WI
If you look at stock valves you will notice they have a round recessed cut in them. Look at the first pic. Now if valve surface was flat, like in the seconded pic it will raise compression a bit. I wonder if you could actually dome the valve surface to raise compression even more….hmmmm……
Oversized valves allow more air into the combustion camber. They might also raise comp a bit, but I’m not sure about that.
#35554 - 11/01/03 06:41 PM Re: 200 whp b16a street build up results
omnimanlsr Offline
there will be a video released in a month that will explain and show how i did this build. the information thats in the video will help better explain how things really work. also all the parts and modifications done to make this kind of power. for the record there was no over sized valves used. we only used a type-r head to save time. all the modifications to the head will be released in the video. there will also be a section on the transmission.
#35555 - 11/01/03 10:56 PM Re: 200 whp b16a street build up results
Loc: Pontiac, MI
Sound's good, i would like to see this, so i can keep a few thing's in mind when im getting ready to do my buildup.
#35556 - 11/02/03 02:48 PM Re: 200 whp b16a street build up results
surubasi00 Offline
Loc: VA
i like how he was allegedy using lots of oem parts...i would love to see a buildup like that on a type R to see how much they could get out of it
Dave
Turns out my dog is allergic to peanuts. - FortCollins
#35557 - 11/02/03 03:00 PM Re: 200 whp b16a street build up results
Bjorn Offline
Loc: Minneapolis
very cool - I hope everything is fully explained in the vid
thanks for doing this - I don't have the cash to experiment, so every little "how-to" post is appreciated
#35558 - 11/03/03 11:40 AM Re: 200 whp b16a street build up results
SiRkid Offline
Loc: On a boosted dog sled
very good stuff. cant wait for the vid.
screw all you b16 haters
http://www.digitallyimported.com "Horsepower is an patch for drivers who dont understand finesse."-exboyracer, some choada on spyderchat dot com
#35559 - 12/04/03 01:29 PM Re: 200 whp b16a street build up results
SimplyTwisted Offline
any news on the video release?
IS250RWD18INCHISPEIBACHDROP6KHIDJOEZINTAKEHKSEXHAUST
#35560 - 12/04/03 01:45 PM Re: 200 whp b16a street build up results
shivers Offline
Loc: North America
Mike has been busy, but he's been making time to edit the video as much as he can.
2010 G37s
#35561 - 12/04/03 03:00 PM Re: 200 whp b16a street build up results
i cant wait to see it
#35562 - 12/06/03 12:09 AM Re: 200 whp b16a street build up results
omnimanlsr Offline
mike is nearly half way done with the editing, so its getting close. i will let everyone know when its complete!
#35563 - 12/06/03 03:20 AM Re: 200 whp b16a street build up results
Kteller8 Offline
Yep i talked to Mike and he said he is getting closer everyday
Steve did some wonderful things and he has so much brain power its amazing!
I would recommend this as a great source for anyone with a b16...
almost makes me want to sell my car and get one. so i too can redo this..
low expense > high hp output .. you win both ways!~!
Import Builders and Rocket Motorsports Products: We Have Pistons, Rods, ValveTrain all Available All Low Prices on Quaife, AEBS, Hondata and so much more!!! Just Click to Visit and Save!!! Accordinglydone.com/Store Custom Mandrel Bent Exhaust 2.25", 2.5", & 3.0" All Available
#35564 - 12/16/03 09:41 PM Re: 200 whp b16a street build up results
SiWheelman Offline
any further updates? I wanna see this setup!
#35565 - 12/17/03 02:01 AM Re: 200 whp b16a street build up results
omnimanlsr Offline
we will have trailers up in the first week of january. from there its all down hill. we really thank you guys for being patient. we shot 23 hours of footage, plus we have to get the website up and running. not my area of expertise, but mike is doing a good job. since this is our first time we are gona be a little inefficient. sorry for the wait.
#35566 - 12/20/03 01:22 AM Re: 200 whp b16a street build up results
Loc: Pontiac, MI
Gooooooooood lordy, did you video tape the whole build up!!!! YAY!!!!! 2 more week's, i wanna see the vid already yo.
#35567 - 12/29/03 08:22 PM Re: 200 whp b16a street build up results
ALkaLi Offline
Loc: Bay Area, CA
this better not be as big of a letdown as ROTK was.
<3 b16a AIM: sMaq25
#35568 - 01/02/04 12:05 AM Re: 200 whp b16a street build up results
#Tuna No Crust Offline
Loc: OC CAli
Your beginnings will seem humble, so prosperous will your future be......
#35569 - 01/18/04 02:22 PM Re: 200 whp b16a street build up results
emissionsux Offline
How hard would it be to get a JDM ITR to 200HP? Good work by the way......shows that it doesn't take much to get good numbers...just knowledge.
#35570 - 01/19/04 10:23 PM Re: 200 whp b16a street build up results
Beave0101 Offline
servant of egosgame
Loc: San Diego
heres a smidget of a slow downloading clip:
http://66.77.170.144/alan/intertune/Intertune2004.avi
Can't decide if it's a funny or embarrasing clip to watch (as a Honda owner)
#35571 - 01/21/04 02:38 AM Re: 200 whp b16a street build up results
*jumping up and down* i wanna see, i wanna see (the final one that is)
that video is funny!
and leaves you intrigued at the same time.
sweetness
#35572 - 02/15/04 09:58 AM Re: 200 whp b16a street build up results
rhettdec Offline
Loc: St. Augustine FL.
what format is the video going to be on? sorry if it was already discussed im lazy.
www.rhettmoxon.com
#35573 - 02/18/04 11:11 AM Re: 200 whp b16a street build up results
Om1kron Offline
Loc: Canoga Park, reppin that 818
can we go ahead and unsticky this godamn post, there is nothing in it and the link in it is dead, no good. No info at all is in this thread just some hoopla about a 200 whp build with no info attached to it.
Wayne T. Edwards A.K.A. 137 aim : on3th1r7ys3v3n R.I.P Wilfredo4
#35574 - 02/18/04 11:13 AM Re: 200 whp b16a street build up results
samkarp Offline
Loc: Milwaukee WI
I would but omniman is a moderator of the forum and would likely re-sticky it. I also do not unsticky posts that I did not make sticky in the first place.
~Sam Karp~
SCCA-Milwaukee
"Autocrossers always make good road racers, but road racers do not always make good autocrossers."-T.C. Kline
#35575 - 02/18/04 03:38 PM Re: 200 whp b16a street build up results
oparea Offline
Loc: St Marys
Where the hell is the video or at least a little info on the build?
#35576 - 02/18/04 10:14 PM Re: 200 whp b16a street build up results
omnimanlsr Offline
we are having some time delays with the website. im really sorry for the delay, please be patient. i feel bad enough as it is. but somethings are out of my controll. trust me there is a lot of very usefull information in this video.
sam if you want to unsticky it go a head. the middle of march is our new date. i will repost when i have things in order
im sorry people.
#35577 - 02/19/04 02:20 AM Re: 200 whp b16a street build up results
SeanJohn1802 Offline
Loc: Stockton, CA
im sorry people.
are you the one on honda-tech (ominiman) (sp) that built the first ls-vtec?
• 2006 Honda Civic [color=gray]EX[/color] |[aka Mr. Chunky]| (under warranty)
http://www.NorCalFG.com
#35578 - 02/19/04 01:24 PM Re: 200 whp b16a street build up results
shivers Offline
Loc: North America
Yes, he is the one and only omniman.
2010 G37s
#35580 - 02/24/04 05:25 PM Re: 200 whp b16a street build up results
Om1kron Offline
The post has been updated, so my comments have been removed by myself.
Thank you for the update sir. No hard feelings
Edited by Om1kron (03/12/04 10:05 AM)
#35582 - 02/27/04 02:10 AM Re: 200 whp b16a street build up results
omnimanlsr Offline
#35583 - 03/07/04 12:26 PM Re: 200 whp b16a street build up results
niterdr Offline
is there a list we can get on to get imformation? or just check back here?
#35584 - 03/09/04 03:23 AM Re: 200 whp b16a street build up results
omnimanlsr Offline
here is a link to the intertune tv website. a few trailers will be availible next week. progress is in motion. sorry for the wait.
#35585 - 03/11/04 03:25 PM Re: 200 whp b16a street build up results
gohangotensi Offline
Loc: Irvine, CA
I'm just curious if this setup up is also CA smog legal?
03 Dodge Neon SRT-4
#35586 - 03/11/04 07:20 PM Re: 200 whp b16a street build up results
omnimanlsr Offline
i dont see why it wouldnt if all the emissions equipment was hooked up and the stock ecu had some reprograming for obd-2 compliance.
the header might have to be replaced since its a slip tube.
#35587 - 04/13/04 11:42 AM Re: 200 whp b16a street build up results
bud, light, inhale Offline
coo fuggin sweet trailer man
#35588 - 04/14/04 12:00 AM Re: 200 whp b16a street build up results
vtec_yosh Offline
Omniman, I had a quick question. Why did you go with the m22 cams from RM, instead of the all-so-popular m24a cams? Im looking at doing something like this buildup in my 99 Si, and Im wondering which pair to go with. Thanks!
http://www.memphisracingscene.com
#35589 - 04/14/04 11:56 AM Re: 200 whp b16a street build up results
shivers Offline
Loc: North America
The cams used were from Dynamic Autosport (I don't recall which ones specifically). The M24a is no longer in the RM product line and the M22 cams will be too big for a 1.6L. I've talked with Rocket at lengths about cams, compression, etc. for my current build.
2010 G37s
#35590 - 04/14/04 04:59 PM Re: 200 whp b16a street build up results
Loc: Stockton, CA
m22, m24?? cams?? wtf i never heard of those, someone needs to enlighten me
#35591 - 04/14/04 07:14 PM Re: 200 whp b16a street build up results
vtec_yosh Offline
http://www.m24x.com/bseries.html
im still new to these cams too, go here to check on them a little!
goto http://www.kteller.com to buy them.
Edited by vtec_yosh (04/16/04 12:14 AM)
#35592 - 04/16/04 12:15 AM Re: 200 whp b16a street build up results
vtec_yosh Offline
Know any good place to collect info on the Dynamic autosport cams I cant seem to find any info or a place to buy them.
Thanks!
Page all of 2 12>
Moderator:  Runnin@Redline Jr, Dr. BrokenLimits, Professor Paki
