Page all of 5 12345>
#3428676 - 01/27/09 12:55 PM Building my Si. forum
Hobkins Offline
Okay for the last couple months I have been looking over these forums reading every post about anything, but in the last month nothing has been happening. It's not picking back up so it's time for me to start some questions... First of many.
I'm looking for around 350 - 400 hp.
1st Question - What manifold should I be looking into? I seen SiAdam had a custom one so that didn't help me much, I heard the ramhorn was top of the line.. but I'm not willing to get rid of my a/c (live in arizona, a/c is a must). Inlinepro was good also so that's what I was thinking.
2nd Question - could a journal bearing turbo even put me to my 350 - 400hp goal? (still new to this)
3rd and last question for now - 10 psi or 13 psi spring? I believe siadam boosted to 22 psi off a 13 psi spring so could a 10 psi get up to around 18 - 19?
I am new to this whole scene and I have read FAQ's so don't trash me for being a newb.
Edited by Hobkins (01/27/09 12:56 PM)
#3429046 - 01/27/09 02:59 PM Re: Building my Si. forum [Re: Hobkins]
SiAdam Moderator Offline
Anything is possible w/bank. So w/that said, what does your budget look like?
1. To keep your a/c you aren't going to be able to run most ramhorn manifolds, so a log is going to be your friend. Inline would probably be your best bet, and will also be a fair amount cheaper than most tubular EL manifolds.
2. Journal or ball bearing does not effect power output, but instead refers to the turbo's reliability and spool up characteristics. I.E. journal bearings are generally cheaper, but typically have a much greater "ramp" rate in regards to spool up as compared to a ball bearing unit that is more smooth. Compare dyno's and you will understand. The trim & wheels of the turbo are where the power is made, not the bearing type.
3. The general rule of thumb is that you can safely double your wastegate spring pressure assuming there are no vacuum/boost leaks present.
Good luck on your project, we will do what we can. Even though I don't have my Si anymore, I still check the forum everyday.
#3429311 - 01/27/09 04:32 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
My income is very very small... Luckily parents supporting me lots still so I don't have many bills. I can basically put my whole pay checks towards my car. I recently just got it all payed off and that was my first goal. Now I have around 1100$ saved up now for kit... still gotta get hondata s300, limited slip, and new stage three clutch?
Awesome, the journal bearing and ball bearing explanation helped me alot.. I knew the ball bearing spooled around 1000 - 1500 rpms faster? but glad that I can still get my goal out of a regular journal bearing.
And what clutch would you recommend? Alls I know is I'm going to need a stage 3.
Yea, I was surprised to see you got rid of your si. I heard about you through my brother (previous owner of my car.) He didn't believe me that you did, but how your s2k is turning out looks like a good decision.
Edited by Hobkins (01/27/09 04:36 PM)
#3430424 - 01/27/09 11:03 PM Re: Building my Si. forum [Re: Hobkins]
jcoosi Offline
Loc: TN
Clutchmaster or ACT clutches are good choices
#3430455 - 01/27/09 11:15 PM Re: Building my Si. forum [Re: Hobkins]
I think I had a CM Stage 3. I would highly recommend it for anything under 500whp.
#3430577 - 01/28/09 12:13 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Alrighty thanks for the advice.
#3431165 - 01/28/09 10:09 AM Re: Building my Si. forum [Re: Hobkins]
Found a thread for you.
http://www.honda-tech.com/showthread.php?t=2095625
#3431432 - 01/28/09 11:39 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Well inlinepro has great power reviews with a/c so that's what I'm going to go with, but I can't find them under 300$ ... Ebay gets one every once and awhile but they also still shoot up past 300. Looks like that's what I'm going to have to dish out for one of these.
#3431930 - 01/28/09 01:53 PM Re: Building my Si. forum [Re: Hobkins]
jcoosi Offline
Loc: TN
Not surprised the inline pro logs can support 600hp easily.I had one but decided going with a Neukin ram horn set up in the end.
#3432106 - 01/28/09 02:39 PM Re: Building my Si. forum [Re: jcoosi]
Hobkins Offline
#3432672 - 01/28/09 05:41 PM Re: Building my Si. forum [Re: Hobkins]
Look @ the thread I posted, they have some ram horns that allow a/c & p/s.
#3433544 - 01/28/09 09:54 PM Re: Building my Si. forum [Re: SiAdam]
jrsi Offline
Loc: Arizona, United States
Hobkins build:
Stock B16A2 Block bored .20 over. SRP 9.1:1 Pistons, Eagle H Beam rods. Stock Crank. All seals and gaskets are OEM Honda.
Head was cleaned all new (stock) valves, stock springs. GSR Cams. Haven't purchased Cam Gears yet...
...I think thats pretty much the majority of it. Still haven't touched the tranny
#3434478 - 01/29/09 09:30 AM Re: Building my Si. forum [Re: jrsi]
jcoosi Offline
Loc: TN
Really no need for cam gears.I had them on my build and they stayed at 0 setting.Other than that looks good.
#3435163 - 01/29/09 12:55 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Okay I reread through it and click on some links but even those guys that run these ram horn manifolds say that most of the time it's quite a tight fit to keep the a/c and ps. Some even say they are worried about it melting the a/c line. Never the less it can be done and I will consider it.
What I was wondering is if I run a smaller inlinepro manifold vs a ram horn would the ram horn add around 30 hp more? I'm not sure I'm just throwing out a number that I could see being relatively close.
Edited by Hobkins (01/29/09 01:00 PM)
#3435284 - 01/29/09 01:30 PM Re: Building my Si. forum [Re: Hobkins]
Typically you sacrifice a little low end power and spool for more power per lb. of boost as compared to a log manifold.
For your goals, an inline would serve you just fine.
Run a 3" exhaust and other supporting mods and you will do ok.
#3438172 - 01/30/09 12:28 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
I'm thinkin that I'm just going to get a used kit ... i don't have money to throw around and if I buy a used set I could just replace certain parts for other parts.
And for the clutch I went on a quick search for them a minute ago and they were going for 500$ on clutchmasters website I'm not complaining lol but I was curious if I should be looking a different place for these clutches? I will do a more extensive search for them after I get off work tonight.
Edited by Hobkins (01/30/09 01:15 PM)
#3457097 - 02/05/09 10:49 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Got a pair of Megan Cam Gears in, but other then that nothing special for me.
Still waiting for that kit to come along my way.
#3457971 - 02/06/09 10:08 AM Re: Building my Si. forum [Re: Hobkins]
Sell the gears, they don't do much unless you are making big power.
I believe I got my clutch a long time ago for cheaper than that...something in the 350-400 range, but I could be wrong.
#3458229 - 02/06/09 11:11 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
The gears were not much, not worth to turn around and sell...
I will keep looking for a decent priced stage 3 clutch...
#3459243 - 02/06/09 04:28 PM Re: Building my Si. forum [Re: Hobkins]
hammeredsi Offline
Loc: WA
i believe i payed close to $700 for my centerforce dual friction and a new throwout bearing. just a couple words of insight; its better, and usually cheaper, to do things right the first time than to have to do them twice.
cheap, fast, and reliable. you can only have two out of the three
#3465206 - 02/09/09 12:53 PM Re: Building my Si. forum [Re: hammeredsi]
Hobkins Offline
Well I will prolly end up just ebayin this clutch.. looks like I can pick up a cm stage 3 for about 400 w/ shipping... that's not to bad. i will keep searching.
#3468351 - 02/10/09 12:34 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Now for my ls I'm looking at wavetrac differentials... they are priced at around 750$ ... Curious to know what you guys are running in your setups.. I understand that this piece will be one of the more expensive pieces, I would like to spend less but eh I will get the money one way or another.
#3471110 - 02/11/09 11:35 AM Re: Building my Si. forum [Re: Hobkins]
jrsi Offline
Quaife LSD seems to be standard...
People have run OBX LSD's.. I've heard good and bad...
#3471307 - 02/11/09 12:41 PM Re: Building my Si. forum [Re: jrsi]
Hobkins Offline
ok the Quaife lsd's were about 100 dollars more then the wavetrac.. not that bad of a difference.
#3471918 - 02/11/09 03:15 PM Re: Building my Si. forum [Re: Hobkins]
Obx is what I used.
They are proven to hold the power. 600whp+ cars run them for years.
I paid $365 for mine a few years back.
#3474419 - 02/12/09 12:29 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
How realiable was that obx lsd for for you? I've read some very very old reviews and people say they are junk... but didn't sound like any of them had any personal experience with them... over the years they could have matured a bit.. but who knows, price is still at around 360$...
Edited by Hobkins (02/12/09 12:37 PM)
#3474508 - 02/12/09 12:57 PM Re: Building my Si. forum [Re: Hobkins]
hammeredsi Offline
Loc: WA
have the obx in my si. 365 whp and close to two years without any problems. the first gen obx diffs had problems with not being to remobe the axle once installed so ive heard. heard they shaved down a part of the diff, and the problem has been resolved.
#3474542 - 02/12/09 01:06 PM Re: Building my Si. forum [Re: hammeredsi]
Hobkins Offline
Alright well it sounds good... I'll try and pick up one of these asap.
#3474698 - 02/12/09 01:40 PM Re: Building my Si. forum [Re: Hobkins]
ZERO problems. The first gen obx's weren't all that grat, but as long as you buy new, you are set.
My cousin has the Si now and is pushing for 700whp+ and will still be using the obx.
#3474858 - 02/12/09 02:17 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Well that sounds much better then a 850$ lsd.... I'm sure it will hold my 300 - 350 whp..
#3474982 - 02/12/09 03:07 PM Re: Building my Si. forum [Re: Hobkins]
Knowledge is power.
#3475351 - 02/12/09 05:04 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Yes it is.
I'm trying to get some of my pics of my cam gears up before I put em in.
Edited by Hobkins (02/12/09 07:08 PM)
#3478429 - 02/13/09 04:25 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Okay guys, you buy your kits used or new? and what size exhaust did you run? full 2.5" or what?
Edited by Hobkins (02/13/09 04:26 PM)
#3478774 - 02/13/09 06:52 PM Re: Building my Si. forum [Re: Hobkins]
Most don't buy kits, we piece it together..saves ALOT of money.
As for exhaust...nothing less than 3".
#3478890 - 02/13/09 07:39 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Cheaper to peice it together? SiAdam how much did your turbo, Intercooler, bov, wastegate and piping cost? (I was really going for just the turbo kit itself, nothing else...)
And wow.. full 3" exhaust is a big pipe.. guessing I gotta pick up that soon too.
#3479018 - 02/13/09 08:41 PM Re: Building my Si. forum [Re: Hobkins]
It all depends on your goals.
Garret turbo was a 57 trim. $520
Precision Cooler $400
HKS Bov was $200
Tial 38mm gate $250
Piping was 2.5" for the cooler I bought from summit.
Of course, thats far from a "kit".
#3479276 - 02/13/09 11:37 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Well ofcourse, but those were just the peices I was interested in. Not to bad of prices. Thanks.
Still unsure about how I'm going to go about this... either try to find a decent used kit or I will buy in peices. Thanks for the advice.
#3479364 - 02/14/09 12:46 AM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Tommarow I'm going to buy my cm stage 3 clutch, and my lsd. Again once I get a chance I will post some pics.
#3481131 - 02/15/09 01:08 AM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
I got my new obx lsd and cm stage 3 clutch shipping right now... Still gotta get quite a bit more stuff lol, but finally started getting the peices...
#3487512 - 02/17/09 01:07 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
I was wondering how long my new cm stage 3 clutch will last me? is it something that I will have to replace in 5 months?
#3495171 - 02/19/09 04:43 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
SiAdam you picked up those peices cheap... I'm still looking around to find deals like that.
#3525848 - 03/02/09 08:35 AM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
I got some pics to finally post.
My megan cam gears [img][/img] [img][/img]
My cm stage 3...
[img][/img]
And finally I got a pic of my brothers 350z and my Si. A bit dark sorry.
[img][/img]
Edited by Hobkins (03/02/09 08:36 AM)
#3555103 - 03/11/09 07:09 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Just got my kit in...
Turbonetics t3/t4 .57 trim .63 a/r
Drag exhaust manifold (not to happy with this... will upgrade soon)
38mm Wastegate
Greddy Bov
RC 550cc injectors
2.5" downpipe
Drag i/c about 6.5" height (another peice I'm not thrilled about)
Tapped B Series oil pan
All piping and necessary oil lines
It's a good kit to start me off.. I'm not sure what hp this kit alone will put me at but after I make some adjustments I will have a decent setup.
We've started building my b16 motor but noticed some small peices missing so I'm now waiting on those pieces. my b18c5 will have to stay in my car for a couple more weeks.
Edited by Hobkins (04/02/09 09:00 PM)
#3556034 - 03/11/09 11:35 PM Re: Building my Si. forum [Re: Hobkins]
I'd boost the b18c5
#3556111 - 03/11/09 11:59 PM Re: Building my Si. forum [Re: SiAdam]
cua0 Offline
Loc: Red Deer, Alberta, Canada
hate to tell you this, but it looks like someone pee'd on your driveway
#3557503 - 03/12/09 01:26 PM Re: Building my Si. forum [Re: cua0]
Hobkins Offline
Haha I knew someone was going to comment on that ...
#3557510 - 03/12/09 01:27 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
The b18 is my brothers... wish he would let me boost it.
#3577370 - 03/19/09 02:06 PM Re: Building my Si. forum [Re: Hobkins]
ZIGZAG Offline
pee:p..
nice man when are u gonna start to put everything in!
#3577749 - 03/19/09 03:29 PM Re: Building my Si. forum [Re: ZIGZAG]
Hobkins Offline
Ok well I got the engine built for the most part... still waiting on the gaskets for the back cover and lower cover on the timing belt... once the honda dealer gets them I will finish up the engine part... Onto the tranny we have no idea how to install an lsd I have found some how to's on installing lsd's on honda tech but still. Our local honda dealer doesn't have the tranny gaskets, so we were thinking of just taking it to a shop and having them deal with it all. I'm not sure if this will be worth it though.
#3578106 - 03/19/09 05:14 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Still need to get Hondata s300, walbro 255 fuel pump, 3bar map sensor, and eventually the tune. I'm sure there will be other things that pop up but for now I'm getting close.
#3579136 - 03/19/09 10:52 PM Re: Building my Si. forum [Re: Hobkins]
Tranny gaskets?
What?
#3579161 - 03/19/09 11:00 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
I don't know... some parts that I was told needed to be replaced when you open up your tranny...?
#3579821 - 03/20/09 08:15 AM Re: Building my Si. forum [Re: Hobkins]
You need to find out for yourself what you need, not rely on someone else.
What year is your car again?
#3580412 - 03/20/09 11:01 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
2000, I have been looking around but really haven't found a decent page on the little items in a transmission. Other sites have posts that just go deep into the gearing and such. I haven't had any experience with transmissions so I'm going into this blind, I will go read up in the owner's manual on the basic parts of the tranny.
#3580794 - 03/20/09 01:03 PM Re: Building my Si. forum [Re: Hobkins]
Ok, just checking.
I rebuilt my 99 b16a2 tranny. First I put a lsd into it, then a yr later my counter shaft ripped apart.
I can safely say, there are no gaskets, the tranny cases use Hondabond, and the only "gaskets" aren't really gaskets, they are axles seals.
I just reused mine...but that depends on each application.
Check here.
http://www.hondaautomotiveparts.com/auto...KA5MT&catcgry5=
Scroll down to MT Tranny stuff under system component.
#3580973 - 03/20/09 01:52 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Thanks Adam that link helps alot. As I get more info on the tranny I will decide wether to use my old peices again.
#3583184 - 03/21/09 03:17 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
My build, my little Honda 250R, and then the Si. ;\)
Getting a collection of hondas lol.
[img]
#3591359 - 03/24/09 05:44 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Well the engine is pretty much built just sitting there rapped up now... I finally got the info on my obx lsd after 5 weeks that it has been on back order for 6 months and this company are no longer selling them.
So now I will either buy a tranny with an lsd installed (theres a b16 tranny with a quaife lsd already installed for 800) if I bought that I would try to sell my stock tranny right now for a bit of cash. Or I will just buy an obx lsd and install in my tranny.
#3592086 - 03/24/09 11:01 PM Re: Building my Si. forum [Re: Hobkins]
I think I bought my obx lsd on eBay back in teh day.
#3592145 - 03/24/09 11:25 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Hehe yea I need to figure this out.
My brother might have found someone to buy his motor (that motor is the one inside of my car now) and the guy wants it saturday so my motor (the b16 built) is hopefully going to drop down inside of my Si. Finally!
I can run without an lsd for awhile but I would really like to just have gotten it all built then drop it all in there at once. Eh we will see what happens. Can't wait though!!!
#3599084 - 03/27/09 03:38 AM Re: Building my Si. forum [Re: Hobkins]
terd_civic Offline
Piecing together might be cheaper. Make sure to upgrade your clutch.
#3600241 - 03/27/09 01:52 PM Re: Building my Si. forum [Re: terd_civic]
Hobkins Offline
I already have my kit and clutch, it is cheaper to peice but I got a great deal on a set.
Edited by Hobkins (03/27/09 01:52 PM)
#3600974 - 03/27/09 05:30 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
I've read quite a few posts on alot of different sites about where to place your dump tubes or if people even have them and it's making me wonder what I'm going to do with mine.
I hear poeple that run without one or with a very short one have problems with the exhaust fumes staying in the engine bay and sometimes going into the turbo robbing hp. They say it's very very loud and some people like it that way.
I hear people say it's good to run it down by your oil pan facing towards the rear of the car. Reduces the sound and exhaust fumes in the engine bay.
I haven't heard much people running it into the downpipe but I assumed that's what everyone does.
Anyways I was curious of what you folks here at ClubSi did? and how you liked it?
#3602490 - 03/28/09 12:23 PM Re: Building my Si. forum [Re: Hobkins]
Run it down and underneath your oil pan facing the back of the car.
#3603737 - 03/29/09 12:33 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Sounds good to me Thanks.
#3604495 - 03/29/09 02:01 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Okay this is what is holding me back from finishing this build.
I have seen a few posts on how to install them so I'm not going there.
I'm just curious of how long and what's the difficultly level on installing one of these. Is it possible for an average joe to come along, grab some tools and slap one of these in?
#3605324 - 03/29/09 09:47 PM Re: Building my Si. forum [Re: Hobkins]
I followed a how-to on H-T that was great.
IF you read the info, you can decide if you have the tools/know how to tackle it.
#3615824 - 04/01/09 09:12 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Well my brother and his friend and I going to try to get this thing all built on the 18th... I still don't have my lsd in but I'm thinking we could do it ourselves. Will save me cash and hopefully I will learn something lol.
Unfortunetly we gotta pull my B18 that's in it now and drop that B16 back in then hook it all up and then get the turbo down inside.
Honda-Tech had a great "How to install turbo" thread so I have been studing it and everything doesn't look to bad, looks like the wiring on the ecu and junk will be a pain. But who knows.
I'm getting quite excited about this, and can't wait to finally get this thing running after all this time.
#3618938 - 04/02/09 08:53 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Haha my boost gauge that I got with my kit doesn't sit on 0, it's not off to bad. From what I hear it will reset itself when I hook it up. We'll see. ;\)
And now a random pic of my turbo + drag mani + wastegate. This is how I recieved it, I didn't put it together. I was pretty lazy when I wrapped it.
#3620653 - 04/03/09 01:00 PM Re: Building my Si. forum [Re: Hobkins]
Good way to get started. Don't sweat the gauge, it's just for reference, they are usually off a hair anyway.
I would definitely lengthen that downpipe dump.
Good luck.
#3620755 - 04/03/09 01:29 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Yea well the kid that ran this before me ran it like this lol. The dump tube looks like it would have pushed that exhaust right into the block. I know it's not long enough to get all the way under.
Makes for a dirty dirty block... \:\(
#3622583 - 04/04/09 12:42 AM Re: Building my Si. forum [Re: Hobkins]
Not only that, but the turbo tends to suck in spent fumes, reducing it's power output.
#3622684 - 04/04/09 02:17 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Dang Adam, your civic with that c16 at 22 pounds rips at 5k rpms. I can only imagine a pull like that haha.
And 325 lbs of torque is insane.
Edited by Hobkins (04/04/09 02:19 AM)
#3626079 - 04/06/09 01:15 AM Re: Building my Si. forum [Re: Hobkins]
HabaneroSedan Offline
Loc: Phoenix, AZ
who are you going to have tune it? out joe at Locash is renowned as the best, but everyone i know that asks him nowadays gets told to pound sand. tim at xact dyno has done well with my car. authorized hondata and he's in srd so there are mechanics in house as well.
2007 Civic Si Sedan: 10psi Supercharged
#3628766 - 04/06/09 11:19 PM Re: Building my Si. forum [Re: HabaneroSedan]
Hobkins Offline
I'm still looking around, my brother works with a guy just is now just opening up a dyno and tune shop up in Prescott and he will give me a killer deal. Name of shop I'm not familiar with. Whereever I go it will be a long trip because were in Camp Verde.
I got to pick a good one.
On another note, I just recieved my OBX Lsd and still waiting on my Walbro 255, OBD2b to OBD1 Harness, and my map sensor.
#3632148 - 04/07/09 10:54 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Someone on H-T gave me a very nice link to a how to on lsd's. And this is the list that was given of the replacement parts. He said only replace if you need to? Well our Honda Dealer most of the time doesn't have the parts we need so we have to wait a couple days, so I would like to get the right ones ordered now. I'm wondering if I should just play it safe and buy all these replacement peices and take a hit. SiAdam you especially might know of what you need replace and what you don't. Ofcourse I'm still trying to go along the lines of replace only what's needed and my list will very likely be different.
91216-PH8-005 : Clutch Housing Mainshaft Oil Seal
91002-PS1-003 : Clutch Housing Mainshaft Bearing (28x60x15)
91101-P80-008 : Clutch Housing Countershaft Bearing (33x60x20)
91205-PL3-A01 : Clutch Housing Axle Seal (35x56x8)
72mm Mainshaft thrust shim
23927-PG2-A00 : Mainshaft Spring Washer (28mm)
91205-PC9-711 : Gear Housing Axle Seal (40x62x8)
91211-P21-008 : 1st Gear (Lower) Friction Dampener
91212-P21-008 : 2nd Gear (Upper) Friction Dampener
91105-P21-003 : 2nd Gear Needle Bearing
90202-PH8-000 : Countershaft Lock Nut (23mm)
23926-P21-000 : Washer (23mm)
91003-P21-003 : Countershaft Ball Bearing
91102-P21-003 : Countershaft Roller Bearing (25x52.2x15)
#3632682 - 04/08/09 07:55 AM Re: Building my Si. forum [Re: Hobkins]
I'm probably not a good example of who to ask, b/c I only replaced my diff bearings.
When I opened it up, everything looked great. The only reason I ended up replacing a bearing on the diff, was b/c I dented one when I was taking it off. So I ended up buying one to replace it. It ran great for a year, until I broke a countershaft, replaced it that following year and it ran great until I sold it. Even went down the 1320 on a 2step and 30lbs of boost.
#3633895 - 04/08/09 01:50 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
The only time when other's replace the bearings is when they dent them also. I'll just buy them to make sure. And probably will just grab the seals while I'm at Honda. A few $ each seal aint bad.
#3637907 - 04/09/09 09:36 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Now that I'm down to a week till I build my car I'm scrambling to get parts.
Bought s300 with p28 socketed, and now see a deal for a BLOX Intake Manifold for $160 shipped on H-T.
Still need gauges, gauges pod, tranny replacement parts for the lsd install, and possibly a wideband sensor? I'm still learning about it.
#3655133 - 04/16/09 12:09 AM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Do I need two new differential ball bearings ? The two that are on the stock differential will fit the new obx differential right?
Siadam you said you only replaced them because you dented it getting it out. But I'm trying to make 100% sure that they will fit because I'm making one final trip down to honda to get all my parts squared away.
Edited by Hobkins (04/16/09 12:11 AM)
#3657105 - 04/16/09 03:21 PM Re: Building my Si. forum [Re: Hobkins]
I'm pretty sure.
You may also need a shim as well for the new diff.
That has to be measured and then figured out what you need excactly.
#3662269 - 04/18/09 09:31 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Well so far we have installed the lsd, installed the walbro 255, pulled my type R motor, and now have mounted my tranny to engine. \:\) We are now just about to go back out and make sure I got everything on the engine that I had on the type R. Once I make sure everything is the same we will drop it in tonight. Turbo tommarow.
#3662516 - 04/19/09 12:22 AM Re: Building my Si. forum [Re: Hobkins]
Good luck.
#3670278 - 04/21/09 11:53 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Soooo much work we got done this weekend.
Unfortunetly we could not finish installing the b16 back into the car. We have gotten really close. These are some pics that I have taken in the middle of the process.
My Type R motor as it sat.
Getting started.
My beastly forged B16 My dad's 450k mile lx in the background. Brother was playing around seeing how my front bumper looked on it.
When we were pulling this out we were like ... exhuast leak lol?
Yep something's wrong lol.
IF ONLY THINGS CAN STAY THIS CLEAN!!!!!! ;\)
And my latest pic. Still need wiring done, and various other things. And we can't forget the turbo!
Edited by Hobkins (04/21/09 11:55 PM)
#3701659 - 05/04/09 01:53 AM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
More updates now.
Most of engine swap is done. Ecu is in. Turbo + Intercooler done.
STILL NEED to get resister box wired in, gauges hooked up, and I think I'm going to run a longer coupling so I can finish getting my air filter setup done.
AND my cheap ebay wastegate rests right against my A/C lines, I'm sure your wastegate becomes a very high temp while running so do you guys have any suggestions? I'm going to heat wrap them but I think I need something else. Comments VERY much appreciated.
Here's a pic.
Latest pics.
#3702156 - 05/04/09 09:16 AM Re: Building my Si. forum [Re: Hobkins]
Wrap the a/c line with something, or it's surely going to burn that up in no time.
#3703024 - 05/04/09 01:43 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
You think just a heat wrap will fix it so it won't burn up? My next upgrade is a new exhaust manifold which will be an InlinePro and probably a new tial wastegate. I'm almost sure this will reposition my wastegate away from A/C lines.
So this setup is only temporary but I don't want to have to replace a/c lines after a month of use. ;\)
#3703324 - 05/04/09 02:57 PM Re: Building my Si. forum [Re: Hobkins]
Something is better than nothing.
FYI, unless you go to a ramhorn style mani, or a top mount setup, I wouldn't bother upgrading to another log.
#3705277 - 05/04/09 11:41 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
This drag manifold is horrible... Wastegate is on one runner... mabye inline won't give me power gains but will possibly improve efficiency of my setup who knows.
I don't know you guys are the experienced ones with these. I will have it up and running in a week hopefully, then I will be able to finally start doing some of these part swaps to see power gains...
Edited by Hobkins (05/04/09 11:50 PM)
#3756438 - 05/21/09 11:38 PM Re: Building my Si. forum [Re: Hobkins]
Waylon'sTurbo SI Offline
i have the drag manifold on my Si with a tail wastegate and it looks like i have way more room then what you do i don't have ac but from the looks of the pics my wastegate still would clear the ac lines
#3950149 - 07/31/09 06:55 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Okay I'm sorry, the last few months have been hard and was not easy to work on the car or even buy the parts. Every weekend we chipped a bit of the work off and now finally.. the civic is at the dyno as we speak.
The guy really wanted to learn the base maps and play with the car so it's going to be over there for a few days...
Unfortunetly he played with it for about a day then did some pulls and at most it's running 240whp...? Does this setup sound like a 240whp setup? To me with a 11 psi spring it should be atleast 270+ but that's my guess. Let me hear what your thinking.
Stock B16A2 Block
Bored .20 over
SRP 9.1:1 Pistons
Eagle H Beam Rods
38mm Cheapo Wastegate - 11 PSI Spring
Greddy Bov
RC 550cc injectors
2.5" Downpipe
2.5" Exhaust
Drag I/C 6.5" height
Hondata S300
Walbro 255
Edited by Hobkins (08/02/09 09:50 AM)
#3951947 - 08/01/09 10:38 PM Re: Building my Si. forum [Re: Hobkins]
1l lbs should be more than 240whp imo.
To be honest I can't remember exactly what I made, but I think on 10-11lbs I was putting down ~300whp ??
I think on 18lbs I made 400whp and on 22lbs I made 450whp
#3952391 - 08/02/09 09:46 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
I'm sorry but I forgot to say the tuner only rev'd to about 6500 rmps at most. He only took it up to 6500 probably because we told him it was a whole new moter, with a whole new turbo kit strapped on it, with a whole new EMS running it. H-T members said if I really took it up to 7800 or whatever then it should be close to 300... But I'd be happy with 270+ \:\)
95 Degree weather at 4500 Ft.
Edited by Hobkins (08/02/09 09:48 AM)
#3953342 - 08/02/09 11:12 PM Re: Building my Si. forum [Re: Hobkins]
It would help some....when are you going for a retune?
#4462573 - 01/26/10 09:24 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Wow 4 months gone by now. Oh boy has things changed. I bet for all of us.
I got the tune by a real tuner about 90 miles away down in Phoenix a few months ago and dyno'd at 251.
Sucks but the guy told me my turbo bearings were going out.. or something like that. Guy I bought it from didn't tell me anything about it but what can you do.
It drives great. Not as quick as my brothers 350z but good enough. I still love the car and with a few more upgrades I'm sure I can smoke it.
Edited by Hobkins (01/26/10 11:12 PM)
#4463380 - 01/27/10 08:16 AM Re: Building my Si. forum [Re: Hobkins]
Turn the boost up...I didn't review the thread, but if you are on a stock motor, you can make 400whp on pump gas.
If you want to be ballsy, make 500whp on race..lol.
You shouldn't have ANY problems with a 350z..haha.
#4463420 - 01/27/10 08:31 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
No not stock motor.
Stock B16A2 Block
Bored .20 over
SRP 9.1:1 Pistons
Eagle H Beam Rods
11 pounds of boost
IM thinking I need to open exhaust to full 3" and rebuild that turbo. Possibly a boost controller also not sure yet though.
Edited by Hobkins (01/27/10 08:32 AM)
#4463443 - 01/27/10 08:39 AM Re: Building my Si. forum [Re: Hobkins]
00OldSi Offline
Loc: DC
I have the Drag mani. Probably 1 of the first casted...LOL! If this helps @9.5-11.5psi w/TialWG. I saw 290whp/180wtq...ish.
Me:
155k+ miles BoneStock B16A2 Head/Block, 3mmHG
Drag mani
38mm TialWG
SSQBov
Macgyver MBC
RC 440 cc injectors
3" Downpipe
2.90" Exhaust
SFAC ftmfw! LOL!
Walbro 255
15psi all day = )
#4463452 - 01/27/10 08:41 AM Re: Building my Si. forum [Re: 00OldSi]
00OldSi Offline
Loc: DC
Oh yeah...AC ROCKS!!!!
Happy Hump Day!
#4464040 - 01/27/10 11:25 AM Re: Building my Si. forum [Re: 00OldSi]
Hobkins Offline
15psi all day = )
Wait you running 9.5 - 11.5 on the 290 rating?
#4464116 - 01/27/10 11:49 AM Re: Building my Si. forum [Re: Hobkins]
00OldSi Offline
Loc: DC
Roger...290 ish.
A 3' DP will free your setup a bit. solid 15+ whp if not more.
#4464171 - 01/27/10 12:00 PM Re: Building my Si. forum [Re: 00OldSi]
Hobkins Offline
Yea I have prety much same stuff as yours and S300 running it. I'm just confused why I'm only getting 250ish. I don't really know if I rebuild that turbo and had full 3" from turbo out will give me 50 hp. Because that should be very close if not at a 300whp setup.
#4464914 - 01/27/10 02:10 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
If I were to start putting more money into it again and start upgrading it more I would prolly do it in this order.
Rebuild Turbo
Full 3" Exhaust from turbo out. (If even possible my 2.5" downpipe is very tight it seems like already down there)
Boost Controller
Then Retune and then think about further upgrades.
What do you guys think? I'd imagine I'd be at 300hp at that point. 350 after boost goes to 18 - 19..?
Edited by Hobkins (01/27/10 02:26 PM)
#4467150 - 01/28/10 05:55 AM Re: Building my Si. forum [Re: Hobkins]
hondacivicnut Offline
Loc: England
What's wrong with the turbo? Have the seals failed on it?
#4467233 - 01/28/10 08:02 AM Re: Building my Si. forum [Re: hondacivicnut]
Hobkins Offline
The tuner I took it to said the bearings are going out. Thus taking it longer to spool then it really should?
Edited by Hobkins (01/28/10 08:11 AM)
#4467322 - 01/28/10 08:46 AM Re: Building my Si. forum [Re: Hobkins]
Yea, funked bearings will decrease power output a little, depending, but if they free spin w/your fingers, then I wouldn't think thats the main issue...hard to say b/c I can't see it.
Unless he did some testing, or looked the turbo over, his "excuse" is b.s.
On your setup, you should be making no less than 300whp, w/500whp being your max for reliability on a GOOD tune, which I don't think you are getting imo.
3" exhaust is a MUST on all turbo apps imo.
#4468251 - 01/28/10 01:23 PM Re: Building my Si. forum [Re: SiAdam]
Loc: England
I agree
#4468571 - 01/28/10 02:39 PM Re: Building my Si. forum [Re: hondacivicnut]
Hobkins Offline
I agree also. They say they are best in areas of Hondata and are a big tuning place so I figured they were right. But I don't know for sure. I start spooling near 4200 and hit full boost by 6400 maybe?
If that tells you anything.
#4469682 - 01/28/10 07:46 PM Re: Building my Si. forum [Re: Hobkins]
Nevermind2 Offline
Loc: Baltimore, M.D.
You can't build a better forum than this.
Ladies, PM me about information on how to donate your old socks to a worthy cause
#4470072 - 01/28/10 09:44 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
So do you think it's a bad tune which is causing me this power loss? I mean we took it to one of the few places that seemed real. Mostly because they knew Hondata and others very well.
I can see a 2.5" pipe limiting my power output but I should still atleast be in 270s+ .
I've seen a few people with very similiar setups as me with 2.5" pipes running very near 300hp.
Dunno what's wrong.
Edited by Hobkins (01/28/10 09:45 PM)
#4470743 - 01/29/10 08:28 AM Re: Building my Si. forum [Re: Hobkins]
What turbo again ?
If it's a "smaller" turbo then you have problems somewhere. It could be a turbo issue, or a big boost leak...but somethings up.
/edit - as stated earlier in this post, you aren't going to make good power on 2.5" piping. 3" or go home.
#4471733 - 01/29/10 12:48 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
What turbo again ?
T3/T4 Turbonetics 57 trim .63 A/R
Not a small one but not a big one either. If I had boost leak then it wouldn't let me get up to my full boost at 11 psi right? It does get all the way up to 11.
And I understand that I need 3" but as I said earlier other people's setups are very close to mine with much more power. I'd rather solve this problem and get the right expected power out of it then go throw more money into upgrades that I put onto a tweaked setup.
#4471853 - 01/29/10 01:15 PM Re: Building my Si. forum [Re: Hobkins]
00OldSi Offline
Loc: DC
Does it hold 11psi at full boost and doesnt drop?
damn...thats a low #s for sure. not crazy low but should be around 270s easy.
#4472132 - 01/29/10 02:17 PM Re: Building my Si. forum [Re: Hobkins]
On 11psi I was over 300, 15lbs netted me like 330/350whp iirc.
#4472810 - 01/29/10 05:54 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Hits 11 psi as I said near 6200 and holds till I let off.
So I don't really know. If I find my dyno sheet I'll get a pic up for you guys.
EDIT: I found my dyno sheets but still waiting for the pics to get to my email. Should have the pics up shortly.
Edited by Hobkins (01/29/10 07:30 PM)
#4473535 - 01/29/10 10:44 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
I don't know how to read these as well as most of you so tell me what you think.
#4475766 - 01/31/10 09:54 AM Re: Building my Si. forum [Re: Hobkins]
danova Offline
movie downloads
#4476594 - 01/31/10 06:13 PM Re: Building my Si. forum [Re: danova]
Hobkins Offline
oK great... Answer?
#4477983 - 02/01/10 09:17 AM Re: Building my Si. forum [Re: Hobkins]
00OldSi Offline
Loc: DC
Catless & go 3' straight through should gain you 20-30whp.
#5142980 - 11/01/10 10:11 PM Re: Building my Si. forum [Re: 00OldSi]
Hobkins Offline
Good time to check in,
Well since I boosted the car it's been running for maybe a whole 3 months. Unfortunetly I've ran into my biggest problem yet, started hearing a tiny almost grinding noise every few minutes. I got the car home and now have finally had time to look at it, we've discovered the tranny had leaked out all its oil, we filled it back up and test drove and it was leaking quite a bit. We checked the tranny oil again only to find little metal peices coming out of the tranny.
Well at this point we've pulled the tranny out and sure enough there's something that went horribly wrong inside. We don't know what has gotten shredded up, hopefully not the whole gearing but whatever did cut one of the seals which gave us the leak. My father thinks it was the LSD but we haven't cracked open the tranny yet. I'm to scared to see what I'll find.
#5147134 - 11/03/10 11:48 AM Re: Building my Si. forum [Re: Hobkins]
00OldSi Offline
Loc: DC
You better off finding a used tranny. Rebuilding will be similiar in $$$.
Good luck tho...and try not to break the bank on your hobby tho!
#5147674 - 11/03/10 02:40 PM Re: Building my Si. forum [Re: 00OldSi]
Hobkins Offline
Yea I've been looking around for a used tranny. I really need a new lsd also as I'm getting serious to get this car back up and running reliably with 300whp. I'm leaning towards we installed the lsd wrong which fk'd it up so I will most likely rebuy another obx lsd and take the transmission down to a transmission shop to get it done right.
I pray to God nothing goes wrong with this OBX this time. I swear we put that LSD in right, we followed step by step with a youtube video that a h-t member posted and it went in so right.
New used tranny - $500 - $800
Another OBX LSD - $400
Turbo Rebuild - $200 Minimal (shop quoted me earlier today)
Full 3" exhaust - $400 - $600? Really I have no idea what they are going to charge me but that's what I've heard.
Retune - $600
Total - $2,100 at best. *Long drawn out sigh*
#5149691 - 11/04/10 11:50 AM Re: Building my Si. forum [Re: Hobkins]
00OldSi Offline
Loc: DC
Go with the Thermo 3'. Straight design and comes read to bolt on.
#5150014 - 11/04/10 01:13 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Wait so I'm confused, is that an exhaust I can install myself?
#5150477 - 11/04/10 03:36 PM Re: Building my Si. forum [Re: Hobkins]
00OldSi Offline
Loc: DC
You'll have to get a custom DP and a cat.
I dont have a cat. so it was just DP.
#5151058 - 11/04/10 06:54 PM Re: Building my Si. forum [Re: 00OldSi]
Hobkins Offline
So that's just a straight 3" pipe that fits an 00 civic si?
#5155222 - 11/06/10 07:01 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Possible great news, we pulled apart the tranny to find a crap ton of metal fragments all over the tranny but it's possible that it was just part of the bearings that some shop pressed on.
Crossing our fingers it wasnt the lsd itself.
Edited by Hobkins (11/06/10 07:02 PM)
#5201175 - 11/25/10 11:54 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Ok I've decided to fix it the right way this time. Honda dealership techs were very helpful and told us the only thing that they thought was messed up were the bearings. But we were also told that it's possible some of the small metal shards could have ended up in the gear trees oil passage ways. So we decided to bite the bullet and let honda deal with the tranny, they cleaned it all out and checked it all out then reinstalled the obx lsd the right way with the bearings pressed on the right way. We now have the tranny fully done and put back together.
Now onto a longer story. *takes deep breath* My father was down in Pheonix searching for a clutch plate and was directed from one performance shop to another until he ended up walking into one of Full-Race's manufactoring shops (a company he hadn't heard of). Well after talking to one of the guys up front about my setup the guy went back and got the owner. He said they ended up talking about what I should do with my turbo setup for over an hour and got lots of info straight from the top guys there. Cutting to the chase after ALOT of talking to them personally and getting incredible discouts, I just now ended up walking out of there with ...
A/C Ramhorn
New Tial 44mm W/ 10 psi spring
3" Downpipe
3" Exhaust
Full-race products arent the cheapest stuff we all know but with the level of customer service and quality items I simply couldn't say no. And it's incredibly likely I will be back in there soon looking for more parts. I did have to buy a new wastegate as mine was a generic off brand with a different flange then on my new Ramhorn, but it's nice to have a real tial wg now.
Great staff + incredible products = me broke \:\)
I only have the Ramhorn now as they are making my downpipe now and waiting on the Tial WG and exhaust to ship in from their Cali shop. I'm super excited to get this civic back and on the road as it's way past over due. Let me know what you think.
Edited by Hobkins (11/26/10 12:09 AM)
#5203990 - 11/28/10 01:02 AM Re: Building my Si. forum [Re: Hobkins]
ChewiSi Offline
Loc: Colorah rah
hobkin's, how old are you man?
#5204119 - 11/28/10 08:44 AM Re: Building my Si. forum [Re: ChewiSi]
Hobkins Offline
It sounds like I'm young doesn't it lol. I'm 19.
#5206274 - 11/29/10 12:03 PM Re: Building my Si. forum [Re: Hobkins]
Dude that is young, lol.
#5208471 - 11/30/10 09:52 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Lol yea I guess.
#5272191 - 12/29/10 09:12 AM Re: Building my Si. forum [Re: SiAdam]
winterwinter Offline
very young at that age.
#5756714 - 08/22/11 06:12 PM Re: Building my Si. forum [Re: winterwinter]
Hobkins Offline
Got retuned last Saturday after a few upgrades on the car at Locash in Phoenix.
Parts in red are my new upgrades since last tune.
Stock B16A2
SRP 9.1:1 Pistons
Eagle H Beam rods
GSR Cams
Megan Cam Gears
Clutch Masters Stage 3
Turbonetics t3/t4 .57 trim .63a/r (Bad Bearings) ---> Turbonetics t3/t4 .57 trim .63 a/r (Brand New)
Blox log manifold ---> Full Race A/C Ramhorn
Cheapo Wastegate 11 PSI Spring ---> 38mm Tial Wastegate 10 PSI spring
Greddy Bov
RC 550cc injectors
2.5" Downpipe ---> 3” Full Race Downpipe
2.5" Exhaust W/ Catalytic Converter ---> 3” Thermal Research and Development Exhaust no Catalytic Converter
Drag i/c 6.5” height
Hondata S300
Stock Radiator Fan ---> 13" Spal Puller Radiator Fan
Stock Condensor Fan ---> 13" Spal Puller Condensor Fan
Car more then a year ago got 251 whp / 191 tq. Locash got car to pull 277 whp / 200 tq with new upgrades.
It was around 110 degrees in Phoenix so VERY hot day. Locash also said it was only running at 9 psi because we moved the wastegate vacuum line down to the charge pipe before the intercooler inlet. So we may may the vacuum line back to where we had the first time to get the extra psi.
I would have loved to see a hard copy dyno sheet of 300whp. Hard to shallow the fact that I put 3k into the car for 26 whp even though I know it has gained more then that. I'm having huge regrets I didn't throw a 12 - 13 psi spring in, still don't know what I was thinking when I decided to lower the spring on second wastegate. \:\(
I'm still at a point where I think my numbers are quite low... even for 9 psi / 110 degrees. Going through these B16 Turbo Setups .
Edited by Hobkins (08/22/11 07:35 PM)
#5757272 - 08/22/11 10:46 PM Re: Building my Si. forum [Re: Hobkins]
Why did you stop at only 9 psi?
I would move the w/g reference back to the intake manifold for one. Also, keep in mine, my rods/piston b16a2 made 450-500whp on 21-25lbs for almost 4 yrs. Driving April-October each year.
#5757632 - 08/23/11 06:26 AM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
We are moving the w/g line back up to the manifold. Like I said I really wish I had a 13 psi spring in it now w/ boost controller but now we just got tuned, I can't bring myself to paying another $450 just to raise 4 psi or so... even though I want to very bad.
The small spring was surely a mistake.
Edited by Hobkins (08/23/11 06:26 AM)
#5760126 - 08/23/11 09:49 PM Re: Building my Si. forum [Re: Hobkins]
Hobkins Offline
Still can't drive the car as these poor civics have such a ridiculous theft rate. Especially here in phoenix az .Waiting on an alarm system ... can't wait to drive it even if its only 270 whp aha .
#5760731 - 08/24/11 08:56 AM Re: Building my Si. forum [Re: Hobkins]
You spent 3k for a few whp, whats another 450lol. You can get a manual boost controller if you don't want to spend the coin, be had for less than 60 bucks, even make a generic one for a few bucks, lol.
#5761562 - 08/24/11 01:55 PM Re: Building my Si. forum [Re: SiAdam]
Hobkins Offline
Noo don't pressure me . That car will be sitting for another 6 months if I decide to up some other things .
#6699900 - 11/08/12 02:53 AM Re: Building my Si. forum [Re: Hobkins]
lorainesports Offline
#9045665 - 06/01/17 04:10 AM Re: Building my Si. forum [Re: Hobkins]
lzm Offline
ua shoes
Abercrombie Fitch
pandora uk
sunglasses store
pandora sale
nike shox
ray ban wayfarer sunglasses
Jimmy Choo Shoes
nike shox
Nike Air Jordan
Hockey Jerseys Outlet
wayfarer sunglasses
moncler jacket
north face sale
nike huarache shoes
prada sale
snow boots uk
Nike Jordans
ray ban clubmaster sunglasses
burberry australia
Premier Jewelry - Official
Nike Dunk SB Low
Kate Spade - Online Sale
chrome store
Zales Jewelry
Wave Prophecy 2 Shoes
Kay Jewelers - Official
Prada Sunglasses - Official
pandora rings
Dreamland Jewelry - Official
moncler sale
ugg uk
pandora.com
chrome store canada
prada sunglasses
Hugo Boss Store
Engagement Rings - Official
official michael kors
Nike Free Run
Ray Ban sunglasses
ray-ban aviator
pandora deutschland
Nike Air Max
Football Jerseys Outlet
pandora bracelets charms
Pandora Bracelet - Official
burberry scarf
pandora rings
Sunglasses outlet sale
sunglasses sm
coach usa online
burberry scarf
official kate spade website
Jared Jewelry - Official
yeezy boost 350 white
Nike Hyperdunk Shoes
prada outlet online
ray-ban glasses
Baseball Jerseys Outlet
Prada Outlet
ray ban online
coach australia
pandora uk
gel kayano
ugg uk
Basketball Jerseys Outlet
salomon sneakers
Chanel Outlet
Coach Sunglasses Outlet
chrome store
prada outlet online
top sunglasses
prada outlet woodbury
rayban prescription glasses
tiffany co
sunglasses
Nike KD 8
tracking ups
burberry australia
nike air max 95
ray-Ban sunglasses
abercrombie canada
nflshop com
ray-ban eyeglasses
pandora jewelry sale
the beat
Brighton Jewelry - Official
louis vuitton bags
Coach Handbags
louis vuitton
kate spade italy
Baseball Jerseys Outelt
nike free shoes
mens sunglasses
mcm outlet online
prada outlet online
coach australia
homepage keywords
burberry outlet
balenciaga us
coach outlet us
kate spade outlet store
pandora sale
official coach outlet site
pandora uk
prada online
michael kors watches
Diamond Rings - Official
Prada Shoes - Official
sunglasses
Longchamp outlet
ray ban uk
Hermes Outlet
Wine
Nike Free
prada outlet sale
michael kors australia official
Burberry Australia
Michael Kors Outlet
Nike Air Max
michael kors us
pandora rings
prada outlet bags
pandora uk
shoes sale
Jordan Flight 45 Femme
yeezy boost 350 shoes
piumini moncler replica
Oakley Sunglasses
oakley frogskins sunglasses
Nike Free Run
Oakley Sunglasses
michael kors uk online
coach tennis shoes
chrome store
canada goose sale online
ray-ban sunglasses
Nike Free
louis vuitton us
louis vuitton australia
mk outlet online
burberry outlet online
Oakley Sunglasses
Longchamp tote
burberry purse
softball jerseys
ugg boots
pandora rings uk
Nike Free
spades uk
chanel bag
Nike Free Run
coach handbags sale
BURBERRYburberry australia
Promise Rings - Official
myhermes parcel shop
nike jordan shoes
prada online
rayban sunglasses
Watches
coach watches
kate spade wallet outlet
prada wallet men
Prada bags
pandora rings
coach carter
shop mlb
burberry outlet canada
tiffany co
sunglasses hut
ugg boots
Wedding Rings- Official
Jewelry Armoire - Official
prada us
payless shoes online
poly sunglasses
michael kors outlet bags
pandora uk
nike running
Nike Zoom
Coach outlet online
moncler us
Burberry Shirt - Official
celine outlet online
Premier Jewelry. - Official
official chrome hearts
pandora necklaces
nbastore
prada purses
ray ban polarized sunglasses
sunglasses outlet
coach outlet online sale
oakley holbrook.
prada outlet online
snow boots
pandora uk
pandoracharms
rayban prescription sunglasses
Salomon Speedcross Shoes
lzm6.1
#9079236 - 07/13/17 11:49 PM Re: Building my Si. forum [Re: Hobkins]
ppst Offline
On the field of death, the Moncler Outlet Online shells, in colossal[35] joy, chorused Sac a main michael kors their terrible harmonies, making Vans Black Sneakers the nfl store heavens sonorous with cheap nike air max their Michael Kors Outlet wanton and Nike Shoes Sale Store unbridled frenzy; star-shells, which seemed at ugg factory outlet times Jordan Schoenen to be Air Max Pas Cher fixed Ugg boots Sale on the ceiling of Nike Factory Store the sky, Nike Air Max Cheap oscillated in zapatos de futbol nike a botas de futbol dazzling whirl of Chaussure Air Max red and green—and men Nike Air Max Sale died.... We remained Yeezy Boost Sale Online in Boutique Ugg the Adidas Shoes Discount Marketplace trenches Jordan Shoes For Cheap the Hugo Boss Sale next day. They Nike Online Store were very Cheap Air Max Trainers quiet, nike air jordan pas cher and Cheap Michael Kors Tote Bag we lay at ease nike shoes in Moncler Outlet Store our Air max levně dug-outs, Pandora Official Website read new pandora charms week-old papers, wrote letters and canada goose jackets on sale took turns Nike Store on sentry-go. louboutin heels On 23 IS BACK Store our front lay New Nike Shoes a chaussures nike pas cher dull Ray Ban Sunglasses Online brown, Boty Nike Air monotonous zapatillas nike baratas level TOMS OUTLET and two red-brick Pandora Style Beads villages, Loos and Hulluch. Our barbed-wire Nike Air Huarache For Sale entanglement, twisted Yeezy Men and shell-scarred, cheap uggs showed countless rusty spikes günstige nike schuhe which stuck out ominous and Nike Pas Cher Femme forbidding. A dead German Ray Ban Sunglasses Cheap hung on Adidas Originals Stan Smith a wire prop, his feet Ugg Pas Cher En France caught nike air max running shoes in Zapatillas Air Max a Michael Kors Handbags Discount cheval Descuentos Nike de frise, the skin of Cheap Air Max his Soccer Boots Outlet nike face peeling away from Air Max Sneakers his bones, and his hand clutching Jordan Shoes Air the wire as if for zapatilla adidas support. Nike Roshe Run He had been huarache sneakers out there Boost Yeezy Sale On Line for Nike Shox discount Sale many months, nike jordan shoes a foolhardy Cheap Nike Air Huarache foe who got a Canada Goose Outlet bullet Ugg Pas Cher Femme through his head when christian louboutin outlet examining our defences.
Page all of 5 12345>
